Wifi adaptor
Hi everybody,
I’m looking for a wifi adaptor which works out-of-the-box with Ubuntu 10.04.3 LTS and in the nearby future with Xubuntu 11.10. Can anybody recommend me a good wifi adaptor?
Many thanks in advance!
Erm USB, PCIe, PCI, or PCMCIA … and does it need to be Wireless N ?
This may help:
https://help.ubuntu.com/community/WifiDocs/WirelessCardsSupported
anything that works in Ubuntu 11.10 should also work in Xubuntu 11.10
I need an USB adaptor which supports 802.11-n protocoll.
This posting:
http://linuxforums.org.uk/index.php?topic=9845.msg70712#msg70712
says the EDUP EP-N8508 Micro Wireless Adapter (802.11n) worked “out of the box” in 11.10 … can’t say how well it would work in 10.04 though.
Your best bet would probably be to find a model that suits your needs, then check the Ubuntu forums for known issues … though “most” USB adapters can be made to work, just a matter of how much work is involved.
Need post! But the proiblem is, I live in The Netherlands and some of the Wifi adaptors advised can’t be bought in Holland. Even this EDUP can’t be bought…
But i’ll keep searching!
