WiFi connection not working with peppermint 3 on Asus eee PC900
I’m a newbie. My wifi does not seem to work only LAN is working. Here’s the output I got following recommendations from the previous post:
mikaela@mikai ~ $ sudo lshw -C network
[sudo] password for mikaela:
*-network
product: L2 Fast Ethernet
vendor: Atheros Communications Inc.
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth0
version: a0
serial: 00:1f:c6:74:88:7f
capacity: 100Mbit/s
width: 64 bits
capabilities: pm msi pciexpress vpd bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=atl2 driverversion=2.2.3 duplex=full firmware=L2 ip=192.168.1.4 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:43 memory:fbfc0000-fbffffff memory:fbfa0000-fbfbffff
mikaela@mikai ~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
mikaela@mikai ~ $ iwlist scanning
I don’t know how to resolve this problem. Any help will be highly appreciated.
What happens if you run:
sudo rfkill unblock all
in a terminal ?
If wireless springs to life … be sure to do a full system update by running:
sudo apt-get upgrade
Now wireless will hopefully survive a reboot.
If the above DOESN’T work …
What’s the output from:
rfkill list
Is there a hardware switch for wirless on the EeePC 900 … it may be a physical switch, or it may be a key combo, such as Fn+F8
[b][EDIT]
SOLVED on the Peppermint forum (Where the OP had also posted):
http://peppermintos.net/viewtopic.php?f=12&t=5562
“sudo rfkill unblock all” and a full system update fixed the issue[/b]
