WiFi connection
Hi
I have brought my own laptop into work (for some free WiFi ) but it cannot find the connection. My little netbook finds it straight away (ubuntu 10.04) but my Toshiba Equim (Ubuntu 10.10) can’t. How do I search for it?
Thanks
If your wireless drivers are working, and the network is broadcasting it’s SSID, then all you should have to do is click the wireless icon on the top panel, and the network should be listed.
Who set up the netbook ? … what I’m trying to find out is… is the wireless network transmitting its SSID, or did someone have to enter it manually.
For security reasons, the companies wireless may not be broadcasting its SSID, and may also be using MAC address filtering… ie. you’d need to KNOW the SSID, and may need your laptops MAC address adding to the list of devices allowed to connect.
but in answer to the original question… to see available wireless networks:
iwlist wlan0 scanning
Where wlan0 is the name of your laptops wireless interface
you can get the wireless interface name with:
ifconfig
It used to pick up any wifi in the area now it wont show anything. My netbook has an icon in the toolbar with what is available and is currently showing 3 connections (Ubuntu 10.04).
Can you send the output from these 3 commands:
ifconfig
sudo lshw -C network
No, because I can’t get the internet on that machine. I have them both up and running with my netbook being the only machine to find a connection.
Does your laptops wireless work ANYWHERE… if not then either you’ve turned wireless off. or it’s a driver or hardware issue, so I’d need the output to check.
Does
iwconfig
show an active wireless connection ?
iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11abg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
You haven’t given your wireless connection a static IP address at any stage have you?
Does your wireless work at home with the laptop?
I have not given a static ip, not intentionally anyway. I have just taken out my broadband in favour of a dongle which is recognised but does not work.
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (rev 03)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
03:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
*-network
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:1e:33:3a:83:76
capacity: 100MB/s
width: 64 bits
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half latency=0 link=no multicast=yes port=MII speed=10MB/s
resources: irq:43 ioport:4000(size=256) memory:90010000-90010fff memory:90000000-9000ffff
*-network
product: AR5001 Wireless Network Adapter
vendor: Atheros Communications Inc.
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 01
serial: 00:1b:9e:e4:df:33
width: 64 bits
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath5k driverversion=2.6.35-24-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11abg
resources: irq:17 memory:94300000-9430ffff
wlan0 Scan completed :
Cell 01 - Address: 00:50:7F:73:AC:70
Channel:6
Quality=70/70 Signal level=-37 dBm
Encryption key:on
ESSID:“ErnestBennett”
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
18 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=00000623e7035273
Extra: Last beacon: 3292ms ago
IE: Unknown: 000D45726E65737442656E6E657474
IE: Unknown: 010882848B961224486C
IE: Unknown: 030106
IE: Unknown: 2A0100
IE: Unknown: 32040C183060
IE: Unknown: 2D1A6E1017FFFF000001000000000000000000000000000000000000
IE: Unknown: 3D1606070700000000000000000000000000000000000000
IE: Unknown: 3E0100
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : TKIP CCMP
Group Cipher : TKIP
IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
IE: Unknown: 7F0101
IE: Unknown: DD07000C4300000000
IE: Unknown: 0706545720010D10
IE: Unknown: DD1E00904C336E1017FFFF000001000000000000000000000000000000000000
IE: Unknown: DD1A00904C3406070700000000000000000000000000000000000000
IE: Unknown: DD9D0050F204104A0001101044000101103B00010310470010BC329E001DD811B2860100507F73AC701021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020084103C000100
Cell 02 - Address: 00:16:0A:12:DB:CE
Channel:6
Quality=20/70 Signal level=-90 dBm
Encryption key:on
ESSID:“ParagonRT”
12 Mb/s; 24 Mb/s; 36 Mb/s
Bit Rates:9 Mb/s; 18 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000000230062cb36
Extra: Last beacon: 3288ms ago
IE: Unknown: 000950617261676F6E5254
IE: Unknown: 010882848B960C183048
IE: Unknown: 030106
IE: Unknown: 0706474220010D14
IE: Unknown: 2A0100
IE: Unknown: 32041224606C
Group Cipher : TKIP
Preauthentication Supported
IE: WPA Version 1
Group Cipher : TKIP
IE: Unknown: DD0900037F01010008FF7F
IE: Unknown: DD1A00037F030100000000160A12DBCE02160A12DBCE64002C010808
Cell 03 - Address: 00:16:0A:12:E1:CA
Channel:6
Quality=13/70 Signal level=-97 dBm
Encryption key:off
ESSID:“Sweex LW050v2”
Mode:Master
Extra:tsf=0000000f5e5d6670
Extra: Last beacon: 3280ms ago
IE: Unknown: 000D5377656578204C573035307632
IE: Unknown: 030106
IE: Unknown: 07064E4C20010D14
IE: Unknown: 2A0100
IE: Unknown: DD1A00037F030100000000160A12E1CA02160A12E1CA64002C010808
adamandmaureen@adamandmaureen-EQUIUM-L350:~$
