Zombie Process
Now a Days i am in searching for a solution/culprit of HIGH CPU UTILIZATION of my Oracle ERP (EBS 12) on Operating System Oracle Linux 6.5.
On Top command i can see that zombie process and major zombie process are
root 1404 0.0 0.0 0 0 ? Z May10 0:00 [ps]
root 1520 0.0 0.0 0 0 ? Z 06:48 0:00 [ps]
root 59572 0.0 0.0 0 0 ? Z May10 0:00 [sh]
root 59674 0.0 0.0 0 0 ? Z May10 0:00 [sh]
i ran ps aux
attached is the result.
MY Question is are the Positive Zombies ? Are the reasons for HIGH CPU UTILIZATION.
unlikely because they’re all dead child processes, but it might be a good idea to find out which parent process isn’t cleaning up it’s children
ps -ef | grep 1404
ps -ef | grep 1520
ps -ef | grep 59572
ps -ef | grep 59674
should give you a clue what the parent process(es) are … then (where feasible) just restart the parent process.
If top is showing zero cpu usage, what does “load average” say?
  • if this isn’t low, it sounds like something crashed in the kernel, in which case you’ll need a reboot …
Well CPU is not Zero (Please See Screen Shot as attachment)
Can you please not add files/images as attachments unless specifically asked to do so by forum admin.
Instead please use a hosting site, such as
http://imgur.com
for images, and then post the URL of the image here, and enclose the URL in IMG tags
TIA :slight_smile:
