I recently updated from 12.04 to 14.04. Things worked fine for a while, but today… not.
The log in screen comes up as normal (maybe a bit slower than usual), I can log in and the desktop appears as normal apart from no top menu bar and no side launcher. I have a cursor.
I’ve tried the classic ‘turn it off and on again’ several times without success. I tried to reinstall via the command line as advised here, again no success.
If you hold Shift after turning on the PC … so you’re presented with the GRUB menu.
Are you able to boot if you select either a previos kernel, or recovery mode > safe graphics mode ?
If not … boot to the login screen (but do not log in) then hit Ctrl+Alt+F3 … log in in text mode with your usersname and password, then post the output from:
Options are:
*Ubuntu
Advanced options for Ubuntu
Memory test (memtest86+)
Memory test (memtest86+, serial console 115200
Open wormhole to alternative reality.
Sorry, just occurred to me… I’m online via another laptop. The one with the issue will not connect which. I should have mentioned earlier, but was being thick. :-[
I logged in as ‘me’ and followed your instructions. From the second command line on various warnings, permissions denied and even a few ‘fatals’ were returned.
