2nd Hard drive
Hi All - I came across an old 40GB HDD when having a spring clean and thought it might come in useful as extra storage. 2 issues…
1 The 2nd HDD is fitted but I can’t access the files. The system ‘sees’ it (/dev/sdb) but I can’t find a way to mount it. Any ideas, please?
2 The ribbon cable can only cope with 2 drives and I have only 1 connection on the motherboard (Foxconn 945 7MC series) so I can connect the 2nd HDD only at the expense of the Optical Drive. Are there ribbon cables available that will accommodate 3 drives from 1 outlet? (There is a floppy connector but it is a different size to the HDD connector).
Linux Mint 13 KDE 2GB RAM
Thanks in advance
Rich
There are no ribbon cables with 3 connectors … it’s a function of IDE specification that the bus itself only supports 2 drives per channel … a master and a slave.
Anything else would need to be connected via the SATA sockets … but obviously that would require SATA drives.
Your only other option would be to bung the 40Gb IDE drive in an external USB HDD enclosure.
Or a SATA ↔ IDE converter, like this:
Can’t say I’ve ever tried one of these, and it would probably be just as cheap to buy an SATA DVD drive.
[END EDIT]
Mounting the drive -
Can you post the output from:
sudo fdisk -l
sudo blkid
and just for fun:
mount
Hi Mark! As requested -
$ sudo fdisk -l
Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders, total 312581808 sectors
Disk identifier: 0x0007c372
/dev/sda1 * 2048 976895 487424 83 Linux
/dev/sda2 978942 312580095 155800577 5 Extended
/dev/sda5 978944 20508671 9764864 83 Linux
/dev/sda6 20510720 28321791 3905536 82 Linux swap / Solaris
/dev/sda7 28323840 140058899 55867530 83 Linux
/dev/sda8 223635456 312580095 44472320 83 Linux
/dev/sda9 140060672 223625215 41782272 83 Linux
Partition table entries are not in disk order
Disk /dev/sdb: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders, total 78165360 sectors
Disk identifier: 0x09ae09ad
/dev/sdb1 * 63 20482874 10241406 7 HPFS/NTFS/exFAT
/dev/sdb2 20482875 78156224 28836675 f W95 Ext’d (LBA)
/dev/sdb5 20482938 78156224 28836643+ b W95 FAT32
sudo blkid
/dev/sda1: UUID=“3cfce3c0-00db-4e23-ab2f-5f11249a7575” TYPE=“ext4”
/dev/sda5: UUID=“23169251-61bc-44a2-8731-9fb01dcc425d” TYPE=“ext4”
/dev/sda6: UUID=“3c69d8d2-7142-4931-a324-628f0d6edc4b” TYPE=“swap”
/dev/sda7: UUID=“a1785252-0966-49e7-901b-1bd561203788” TYPE=“ext4”
/dev/sda8: UUID=“0a77f7a3-c800-4bf9-b095-e39849dbba76” TYPE=“ext4”
/dev/sda9: UUID=“53b7cf2f-f895-4ff1-9ca0-f631f5878fab” TYPE=“ext4”
/dev/sdb1: UUID=“2CD80615D805DDC8” TYPE=“ntfs”
/dev/sdb5: UUID=“124B-15FD” TYPE=“vfat”
$ mount
/dev/sda9 on / type ext4 (rw,errors=remount-ro)
tmpfs on /tmp type tmpfs (rw,noexec,nosuid)
I suppose it’s a bit academic really - if the mobo doesn’t support another drive, I have to choose between an Optical or a Slave!! It would be good to see what’s on the 2nd HDD though… I think it might be XP Pro… but I could always wipe it and keep it in reserve in case my main HDD goes kaput!
Rich
Read my last posting again … I added some bits to it.
You CAN add an optical drive (or other HDD’s) … but they would need to be connected via the SATA sockets.
Which distro/version are you running ?
Thanks Mark - duly noted - I’ll have a ‘google’!
Mint 13 KDE 2GB RAM
If you just wanna see what’s on them
Doesn’t the KDE file manager allow you to just click on the drive in the left hand panel to mount it ?
If not, the drive contains 2 usable partitions
/dev/sdb1 which is an NTFS partition
/dev/sdb5 which is a FAT/32 partition
so let’s manually mount them (this will not survive a reboot)
First create 2 mount points in /media
sudo mkdir /media/ntfs-partition
sudo mkdir /media/fat-partition
Now to mount them
sudo mount -t ntfs /dev/sdb1 /media/ntfs-partition
sudo mount -t vfat /dev/sdb5 /media/fat-partition
Are they now available in your file manager at
[quote author=Mark Greaves (PCNetSpec) link=topic=11564.msg93116#msg93116 date=1396027044]
Doesn’t the KDE file manager allow you to just click on the drive in the left hand panel to mount it ?[quote]
Mark, the drive doesn’t appear anywhere in the left hand panel… The 2 new directories do appear in file manager but there is nothing relevant in the files - just some Windows system stuff and a few default bits and pieces.
I’d like to format the drive and make it available for storage but without it being ‘seen’ by File Manager, how do I accomplish that? Bearing in mind I don’t want to format my main drive…!!!
Cheers
Rich
Install and use gparted to format the drive. (be careful to select sdb)
if you need help … just ask :slight_smile:
