sudo apt-get remove --purge bcmwl-kernel-source :
Reading package lists… Done
Building dependency tree
libecryptfs0 libdmraid1.0.0.rc16 libdebconfclient0 ecryptfs-utils cryptsetup
rdate bogl-bterm dkms libdebian-installer4 linux-headers reiserfsprogs
dmraid python-pyicu linux-headers-3.2.6
The following packages will be REMOVED:
bcmwl-kernel-source
0 upgraded, 0 newly installed, 1 to remove and 149 not upgraded.
1 not fully installed or removed.
After this operation, 2,867kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database … 280264 files and directories currently installed.)
Removing bcmwl-kernel-source …
Removing all DKMS Modules
Done.
update-initramfs: deferring update (trigger activated)
Purging configuration files for bcmwl-kernel-source …
Processing triggers for initramfs-tools …
update-initramfs: Generating /boot/initrd.img-3.2.6
root@bt:~/bcmwl-kernel-source# dpkg -i *.deb
Selecting previously deselected package bcmwl-kernel-source.
(Reading database … 280215 files and directories currently installed.)
Unpacking bcmwl-kernel-source (from bcmwl-kernel-source_5.100.82.112+bdcom-0ubuntu3_amd64_ID4365.deb) …
Setting up bcmwl-kernel-source (5.100.82.112+bdcom-0ubuntu3) …
Loading new bcmwl-5.100.82.112+bdcom DKMS files…
First Installation: checking all kernels…
Building only for 3.2.6
Building for architecture x86_64
Building initial module for 3.2.6
Done.
wl.ko:
Running module version sanity check.
Original module
No original module exists within this kernel
Installation
Installing to /lib/modules/3.2.6/updates/dkms/
depmod…
DKMS: install Completed.
ERROR: Module b43 does not exist in /proc/modules
ERROR: Module b43legacy does not exist in /proc/modules
ERROR: Module ssb does not exist in /proc/modules
ERROR: Module bcm43xx does not exist in /proc/modules
ERROR: Module brcm80211 does not exist in /proc/modules
ERROR: Module brcmfmac does not exist in /proc/modules
ERROR: Module brcmsmac does not exist in /proc/modules
ERROR: Module bcma does not exist in /proc/modules
hi, evn i have a problem with the wireless network detection and ive tried the steps uve mentioned… i get stuck on the one below :
root@bt:~# sudo apt-get remove --purge bcmwl-kernel-source
libdmraid1.0.0.rc16 python-pyicu libdebian-installer4 cryptsetup
libecryptfs0 reiserfsprogs rdate bogl-bterm ecryptfs-utils libdebconfclient0
dmraid
bcmwl-kernel-source*
0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
4 not fully installed or removed.
After this operation, 2,589kB disk space will be freed.
(Reading database … 252990 files and directories currently installed.)
Done.
Setting up beef (0.4.3.5-bt1) …
WARNING: You don’t have /root/.gem/ruby/1.9.2/bin in your PATH,
gem executables will not run.
Successfully installed bundler-1.3.5
1 gem installed
Installing ri documentation for bundler-1.3.5…
Installing RDoc documentation for bundler-1.3.5…
/var/lib/dpkg/info/beef.postinst: line 5: bundle: command not found
dpkg: error processing beef (–configure):
subprocess installed post-installation script returned error exit status 127
Setting up se-toolkit (4.2.1-bt0) …
svn: OPTIONS of ‘http://svn.trustedsec.com/social_engineering_toolkit’: could not connect to server (http://svn.trustedsec.com)
dpkg: error processing se-toolkit (–configure):
Setting up w3af (1.2-bt2) …
tar: pybloomfiltermmap-0.2.0.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Exiting with failure status due to previous errors
/var/lib/dpkg/info/w3af.postinst: line 4: cd: pybloomfiltermmap-0.2.0: No such file or directory
python: can’t open file ‘setup.py’: [Errno 2] No such file or directory
svn: Repository moved permanently to ‘p/w3af/code - Revision 6655: /trunk’; please relocate
dpkg: error processing w3af (–configure):
beef
se-toolkit
w3af
E: Sub-process /usr/bin/dpkg returned an error code (1)
thnks for the reply… really grateful … however im really sorry i dnt know how to remove the following tht uve suggested …
And how do i see which distro/version im using… when i strt up the device i get an option of Ubuntu 3.2.6 … is tht of any help ???
Firstly, you appear to be running an old version of Ubuntu that no longer recieves any updates … don’t you think it would be a better idea to wipe the HDD and install a more recent distro ?
Anyway … let’s start from the beginning …
Open a terminal and post the output from these commands:
Im not sure about the version tht im using however since u say its old il update it soon …
Following is the output tht i got from the commands u gave me to execute :
