Acer 5755G Problem with internet conectivity
I take it you’ve rebooted ?
if so, what’s the output from:
lsmod | grep wl
If not, please do so, then send the output.
Oh yea, ive rebooted …
Here is what i got from the command u gave :
root@bt:~# lsmod | grep wl
wl                   2642608  0
lib80211               13683  2 lib80211_crypt_tkip,wl
It looks like the driver is loading, and it’s working, as it can see your router … so the problem is with wicd not being able to work with it … prfobably because it’s called eth1 instead of wlan0
I’ll need to do some homework on this … I’ll post back as soon as I find something.
Jst out of interest, can you post the output from:
iwlist scanning
again.
root@bt:~# iwlist scanning
eth1      Scan completed :
          Cell 01 - Address: 00:1E:A6:09:D7:A4
                    ESSID:"dsouza"
                    Mode:Managed
                    Frequency:2.422 GHz (Channel 3)
                    Quality:5/5  Signal level:-26 dBm  Noise level:-91 dBm
                        Group Cipher : TKIP
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    Encryption key:on
                              9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
                              48 Mb/s; 54 Mb/s
          Cell 02 - Address: 64:70:02:CA:2B:E6
                    ESSID:"SelMel"
                    Mode:Managed
                    Frequency:2.427 GHz (Channel 4)
                    Quality:2/5  Signal level:-76 dBm  Noise level:-91 dBm
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: DD990050F204104A0001101044000102103B00010310470010000102030405060708090A0B0C0D0E0F1021000754502D4C494E4B10230009544C2D57523834314E10240003382E3010420003312E301054000800060050F204000110110019576972656C65737320526F7574657220544C2D57523834314E100800020086103C000101104900140024E26002000101600000020001600100020001
                    Encryption key:on
                              48 Mb/s; 54 Mb/s
also i noticed when ever i try to open WICD netwrk mangr i alwys get an error …
"Could not connect to wicd's Dbus interface. Check the wicd log for error messages."
Ahh … now that helps … I’ve helped someone fix that before … just off to find where I posted that.
Yea i know u did … its the first post on this thread …
i tried it as well … il giv u the output in my next post …
this is wat you had suggested before :
root@bt:~# locate wicd.log
/var/log/wicd/wicd.log
root@bt:~# sudo adduser root netdev
The user `root' is already a member of `netdev'.
root@bt:~# sudo /etc/init.d/dbus reload
Rather than invoking init scripts through /etc/init.d, use the service(8)
utility, e.g. service dbus reload
Since the script you are attempting to invoke has been converted to an
Upstart job, you may also use the reload(8) utility, e.g. reload dbus
root@bt:~#
NO … I meant this topic on the Peppermint forum -
http://peppermintos.net/viewtopic.php?p=37225
Try this …
Open a terminal and run:
sudo mv -v /etc/resolv.conf /etc/resolv.conf.backup
sudo ln -s /run/resolvconf/resolv.conf /etc/resolv.conf
sudo rm -v /var/lib/wicd/resolv.conf.orig
sudo service wicd restart
Now see if “Wicd Network Manager” will start from your menus.
To undo -
run:
sudo mv -v /etc/resolv.conf /etc/resolv.conf.broken
sudo mv -v /etc/resolv.conf.backup /etc/resolv.conf
I ran the first part of the commands u gave me … here is the output :
root@bt:~# sudo mv -v /etc/resolv.conf /etc/resolv.conf.backup
`/etc/resolv.conf' -> `/etc/resolv.conf.backup'
root@bt:~# sudo ln -s /run/resolvconf/resolv.conf /etc/resolv.conf
root@bt:~# sudo rm -v /var/lib/wicd/resolv.conf.orig
removed `/var/lib/wicd/resolv.conf.orig'
root@bt:~# sudo service wicd start
 * Starting Network connection manager wicd                              [ OK ]
root@bt:~#
However i noticed tht i only get the error msg wen i initially strt the system and click on wicd netwrk mngr …
so i restrtd the system n i still get the error …
do i need to run the other command to undo as well ? ? ?
tht is :
To undo -
run:
so I take it you’ve rebooted and still get the error ?
and that made no difference … wicd still doesn’t show wireless ?
nope :cry: and im sure there is wireless available
OK, run the UNDO commands, and reboot … I’ll go see if I can find a solution.
Does backtrack have the Synaptic Package Manager in the menu’s … or some kind of package manager ?
What’s the output from:
cat /etc/network/interfaces
Are you still there ?
Yea im still ere … sorry bout tht … my internet just dropped out …
some problem wit the service i guess … no worries … il do wat u tol me to …
first il run the undo commands and restrt ok …
and i tried searching for synaptic package manager in the menus … however no luck …
[u][i][b]To undo[/b][/i][/u] -
run:
root@bt:~# sudo mv -v /etc/resolv.conf /etc/resolv.conf.broken
`/etc/resolv.conf' -> `/etc/resolv.conf.broken'
root@bt:~# sudo mv -v /etc/resolv.conf.backup /etc/resolv.conf
`/etc/resolv.conf.backup' -> `/etc/resolv.con
restrtd laptop
i still get wicd error…
root@bt:~# cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet dhcp
auto eth2
iface eth2 inet dhcp
auto ath0
iface ath0 inet dhcp
auto wlan0
iface wlan0 inet dhcp
In wicd check what’s listed in the settings
preferences > general settings > wireless interface → should be (eth1)
is anything there ?
wireless interface i filled in eth1
and wired interface already had eth0
try rescanning for wireless networks … anything ?
