Another variation on "top"
Just for anyone who’s not come across it … you’re probably familiar with top for monitoring system usage, and maybe also htop which is also mentioned quite a bit online … htop being a more recent and more technical take on top.
There is also a third option that you don’t see mentioned quite so much that is arguably even (!) more technical, but also much prettier, that’s btop.
Maybe worth a look if you’re interested in nice command line tools :slight_smile:
If you prefer a GUI app rather than the terminal there is Mission Center which is available as a flatpak or snap package.
https://missioncenter.io/
Looks nice … is this a local machine only solution, or will it run against containers over a ssh connection?
This is my netdata dashboard … although this does work over the network it seems to be limited to 5 nodes and the collection daemon is pretty heavy. Always looking for something better, in this case, not limited and lighter weight in terms of metric collection.
