Archiving Commandline style
Hi guys
I’m currently doing an on online course and I’ve got an assignment to backup my home directory to /tmp
here’s he question
What would be a way to back-up all your files and subdirectories found in your login directory and put them into a tarball file out in /tmp called backup.tar ?
the solution according to the courseware is…
tar -cvf /tmp/backup.tar "
This doesn’t work all I get following that command is an > _ at the commmand prompt so clearly I’m not implementing it properly
I’ve no idea what the " at the end signify but if I remove them I get this output
graeme@Linux1 ~ $ sudo tar -cvf /tmp/backup.tar
[sudo] password for graeme:
tar: Cowardly refusing to create an empty archive
Try 'tar --help' or 'tar --usage' for more information.
graeme@Linux1 ~ $
I’ve tried other variations too numerous to mention but I can’t get anything to work, so can any of you commandline gurus give me a clue what I’m doing wrong and why the solution didn’t work
Many Thanks
You’re telling it where to create the tarball, but not what to put in it … try:
sudo tar cvf /tmp/backup.tar /home/graeme
or if you want to suppress the “Removing leading `/’ from member names” message
sudo tar cvf /tmp/backup.tar -C / home/graeme
personally I’d also do it as a gunzip, so
sudo tar cvfz /tmp/backup.tar.gz -C / home/graeme
Looking at it again, I think there was a typo in the coursework command…
I think what you were supposed to do was use the “*” wildcard to compress everything in the current directory … so
make sure your home directory is the current directory:
cd ~
then create the backup with
sudo tar cvf /tmp/backup.tar *
Ok thank you Mark I’m getting the hang of it now but I have a couple of questions
what does the -c and the space between / home mean ?
Many thanks
See:
man tar
(man pages are your friend ;))
the “-C /” = change directory to /
then everything is done as a relative path from there … so there’s no need for the leading / in the path
there’s no need to do this, it just supresses the “Removing leading `/’ from member names” message you get without it.
think of it like this…
if you’re already in / there’s no need to have a full path such as
/home/graeme
instead you can just specify a path relative to your current directory, such as
home/graeme
which removed the need for the leading / it was informing you it was removing.
Ok I understabd this
personally I'd also do it as a gunzip, so
cvfz+ create, verbose, file, compress with gzip ?
But I don’t understand this
if the asterix is a wildcard telling it to compress all the files within the archive where’s the instruction to compress ie z for gzip or j for bz2
should it not be something like
sudo tar cvfz /tmp/backup.tar.gz *
Yeah … if you want a gz or bz2
