Hi everyone,
I’ve just installed Ubuntu 10.10 on a desktop I built and I’m having a problem with a network card, so I’d appreciate some help. I think it’s a driver issue, but I cannot be sure. I’ve tried going through a few instructions I found online, but couldn’t get it to work. I’ve put the output from some of the commands I ran below:
lshw output
*-network UNCLAIMED
description: Ethernet controller
product: Atheros Communications
vendor: Atheros Communications
physical id: 0
bus info: pci@0000:03:00.0
version: c0
width: 64 bits
capabilities: bus_master cap_list
configuration: latency=0
resources: memory:fea00000-fea3ffff ioport:e000(size=128)
lspci output
00:00.0 Host bridge: Advanced Micro Devices [AMD] Device 1705
00:01.0 VGA compatible controller: ATI Technologies Inc Device 9644
00:01.1 Audio device: ATI Technologies Inc Device 1714
00:10.0 USB Controller: Advanced Micro Devices [AMD] Hudson USB XHCI Controller (rev 03)
00:10.1 USB Controller: Advanced Micro Devices [AMD] Hudson USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices [AMD] Hudson SATA Controller [IDE mode] (rev 40)
00:12.0 USB Controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:12.2 USB Controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:13.0 USB Controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:13.2 USB Controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices [AMD] Hudson SMBus Controller (rev 13)
00:14.1 IDE interface: Advanced Micro Devices [AMD] Hudson IDE Controller
00:14.2 Audio device: Advanced Micro Devices [AMD] Hudson Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] Hudson LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] Hudson PCI Bridge (rev 40)
00:14.5 USB Controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:15.0 PCI bridge: Advanced Micro Devices [AMD] Device 43a0
00:15.1 PCI bridge: Advanced Micro Devices [AMD] Device 43a1
00:18.0 Host bridge: Advanced Micro Devices [AMD] Device 1700 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices [AMD] Device 1701
00:18.2 Host bridge: Advanced Micro Devices [AMD] Device 1702
00:18.3 Host bridge: Advanced Micro Devices [AMD] Device 1703
00:18.4 Host bridge: Advanced Micro Devices [AMD] Device 1704
00:18.5 Host bridge: Advanced Micro Devices [AMD] Device 1718
00:18.6 Host bridge: Advanced Micro Devices [AMD] Device 1716
00:18.7 Host bridge: Advanced Micro Devices [AMD] Device 1719
03:00.0 Ethernet controller: Atheros Communications Device 1083 (rev c0)
ifconfig output
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:108 errors:0 dropped:0 overruns:0 frame:0
TX packets:108 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:8304 (8.3 KB) TX bytes:8304 (8.3 KB)
