Best way to edit my GRUB thing?
Hello, I’m fairly new with Ubuntu 10.04 and have got it all set up to what I need from Ubuntu but there’s 1 thing I want to do. Edit my GRUB booting thing.
I’m on the first version GRUB that comes with Ubuntu 10.04 but I’ve heard there’s a GRUB2 but is harder to edit, what do you suggest?
I’ve YouTubed it and came across an application called KGRUBEditor (for GRUB that comes with Ubuntu 10.04), although I have no idea on how to install it on my Ubuntu so I was hoping you guys could help! Or is there a different better way to edit it that you would recommend over the KGRUBEditor.
Thanks, Joe.
AFAIK Ubuntu 10.04 uses GRUB2 by default not legacy GRUB… what are you trying to achieve ?
Mine says “GNU GRUB version 0.97” at the top like in the image below. I’d like to rename some of the options of it because it all looks messy.
http://www.ime.usp.br/~jose/mac2166/ubuntu/snapshots/grub.png
OK, editing of legacy GRUB’s menu is done by manually editing the /boot/grub/menu.lst file.
WARNING: first make a backup of this file.
To create a backup, enter this command into a terminal:
sudo cp /boot/grub/menu.lst /boot/grub/menu.lst-backup
then if anything goes wrong, you can boot from a LiveCD and replace the file.
If you need help, post the contents of the /boot/grub/menu.lst file here, and explain what you are trying to acieve.
