Bricscad Stopped working
Hi
I am using the Trial version of Bricscad that was working fine. Since I updated to Ubuntu 14.04 to will no longer open existing files. The program just shuts down. I have downloaded the New version of Bricscad (V15). This one opend 2d drawing but if I try to create a 3d drawing the program just close’s down.
Any Idears why?
Thanks
Mark
Which version of Bricscad worked, and in which version/architecture of Ubuntu ?
How did you upgrade to 14.04 … upgrade or clean install ?
What’s the output from:
sudo lshw -C display
Hi.
It was an upgrade from 12.10
output is
mark@mark-Aspire-5755G:~$ sudo lshw -C display
[sudo] password for mark:
no talloc stackframe at …/source3/param/loadparm.c:4864, leaking memory
*-display
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:51 memory:d1400000-d17fffff memory:c0000000-cfffffff ioport:3000(size=64)
Firstly the memory leak problem… what’s the output from:
dpkg -l | grep libpam-smbpass
sudo apt-get remove --purge -s libpam-smbpass
Hi
output is
mark@mark-Aspire-5755G:~$ dpkg -l | grep libpam-smbpass
ii libpam-smbpass:amd64 2:4.1.6+dfsg-1ubuntu2.14.04.7 amd64 pluggable authentication module for Samba
mark@mark-Aspire-5755G:~$ sudo apt-get remove --purge -s libpam-smbpass
Reading package lists… Done
Building dependency tree
accountsservice-ubuntu-schemas accountsservice-ubuntu-touch-schemas
gsettings-ubuntu-touch-schemas indicator-network libofono-qt1
libonline-accounts-client1 libqgsttools-p1 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5systeminfo5
libsystemsettings1 libubuntu-download-manager-client0
libubuntu-download-manager-common0 libubuntu-download-manager-priv0
linux-headers-3.13.0-49 linux-headers-3.13.0-49-generic
linux-image-3.13.0-49-generic linux-image-extra-3.13.0-49-generic
packagekit-tools python3-gnupg qtdeclarative5-folderlistmodel-plugin
qtdeclarative5-qtmultimedia-plugin qtdeclarative5-systeminfo-plugin
signon-keyring-extension suru-icon-theme system-image-common
system-image-dbus ubuntu-download-manager ubuntu-keyboard-data
ubuntu-mobile-icons ubuntu-touch-sounds ubuntuone-credentials-common
The following packages will be REMOVED
libpam-smbpass*
0 to upgrade, 0 to newly install, 1 to remove and 16 not to upgrade.
Purg libpam-smbpass [2:4.1.6+dfsg-1ubuntu2.14.04.7]
OK, run:
sudo apt-get remove --purge libpam-smbpass
now do you still get the “memory leak” error when you run:
Also it probably wouldn’t hurt to remove those orphaned packages:
sudo apt-get autoremove
Now I doubt if either of those have fixed the Bricscad issue … but you never know, so can you check/confirm if you still have the problem with Bricscad ?
Hi.
No Memery leak now
*-display
physical id: 2
version: 09
width: 64 bits
Yes Bricscad problem still there. Sorry.
OK, wanna try the 3.16 kernel and updated graphics stack ?
If so, open a terminal and run:
sudo apt-get install --install-recommends linux-generic-lts-utopic xserver-xorg-lts-utopic libgl1-mesa-glx-lts-utopic libegl1-mesa-drivers-lts-utopic
then REBOOT
then check if that helped, and post the output from:
uname -a
Frade not. Bricscad V11 will not open at all now. I just get a small circal spinning then that diapears and nothing. Bricsacad V15 works in 2D but not in 3D soon at I try to open 3D or go to 3D it closes the program.
Output is
mark@mark-Aspire-5755G:~$ uname -a
Linux mark-Aspire-5755G 3.16.0-37-generic #51~14.04.1-Ubuntu SMP Wed May 6 15:23:14 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
You might want to read this:
https://www.bricsys.com/common/support/forumthread.jsp?id=25970
Hi
Thank you. That seems to have sorted out the 3D in V15. But it is horibley slow and poor even drawing a straight line is slow.
For Bricscad v11 would it be worth uninstalling and reinstall? If so how do I do that?
Can’t hurt to try
dpkg -l | grep bricscad
locate -i brics
first is
mark@mark-Aspire-5755G:~$ dpkg -l | grep bricscad
ii bricscadv11 11.3.16 all Bricscad is the number one DWG CAD alternative offering a complete and recognizable feature set to professional users. Bricscad reads and writes the DWG format and offers high compatibility with AutoCAD® 2010
ii bricscadv15 15.1.21 amd64 BricsCAD is the number one DWG CAD alternative offering a complete and recognizable feature set to professional users. BricsCAD reads and writes the DWG format and offers high compatibility with AutoCAD
Bit of a long one this!
Second is
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG21.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG27.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG29.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG31.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG37.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG39.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG41.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG47.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHRBRG49.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JHXNTFLG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JIS12512.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JIS12513.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JIS1256.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISFL90.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISFL90H.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISFL90Z.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISFLAT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHN1A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHN1B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHN2A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHN2B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHNC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHNTA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHNTB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISHNTUB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISOV90.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISOV90H.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISOV90Z.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPAN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPANH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPANZ.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPRLPA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPRLPB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISPRLPC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISRCW.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISSCW.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISSPRPN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISSQWL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISSQWS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JISTPRPN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLANGLE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLCHAN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLHAT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLKWSHA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLKWSHAB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLKWSHB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLKWSHC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLLIPC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLLIPZ.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLSHAPEU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLTSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JLZ.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JOILSL1.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JOILSL2.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORINGG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORINGP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORINGV.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORNGGA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORNGGB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORNGGC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORNGGD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JORNGGE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JPNHRVT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JPRLKEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG03D.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG302.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG303.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG320.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG322.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG323.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG511.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG512.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG513.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG514.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG522.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG523.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRBRG524.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRNDST.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JROUND.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRTPIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRTRNGCE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRTRNGCI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JRTRNGE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSLDKEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSNPRVT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSNPRVTS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSOCHEX.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSPLINE1.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSPLINE2.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQBAR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQBLTF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQBLTL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQBLTR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQBLTSF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQNUT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSQPIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSSCRCP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSSCRCUP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSSCRDP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSSCRFP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JSSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTISO355.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG2C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG3.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG30.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG31.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG32.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG3C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG3D.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG4.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG5.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRBRG7.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRHST.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTRNDST.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JTSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JVPACKF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JVPACKH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWDFKEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWING1.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWING2.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWING3.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWING3L.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWING4.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/JWSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LKWSHHLE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LKWSHHLH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LKWSHHLR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LKWSHRHL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LYRDEF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/LYRMAP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MCSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MM-CTR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MM-SPLN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MM-STD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MM-THD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100FC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO100TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120FC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO120TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140FC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO140TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160FC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO160TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200FC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO200TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO240A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO240B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO240C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO240DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO240DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO25B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO35A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO35B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO35DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO35FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO35TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO40A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO40B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO40DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO40FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO40TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO41A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO41B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO50A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO50B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO50DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO50FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO50TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO60TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80A.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80B.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80C.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80DB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80DC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80FB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80TB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MO80TC.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MORSE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/MTSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS600.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS601.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS602.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS603.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS604.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS605.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS606.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NAS6232.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHCPL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHFJAM.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHFLG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHHF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHHFJM.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHHJAM.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHHSL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHJAM.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHMS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHSL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTHTHK.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTLHFLG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTSQ.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTSQH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTSQMS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/NUTTHSL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OV90MI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OV90MS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVIA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVTI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVTIA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVTII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVUI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVUIA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVUII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/OVUS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANIA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANMI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANMS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PANS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMBS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMBSO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMBSOA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMBSOS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMCLS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMCLSS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHAP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHNP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMFHSP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSOA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSOAU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSOS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSOSU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSOU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMSS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMTFH.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PEMTFHS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PINDWL.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PINDWLU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PINSPR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PINSQE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PINSTR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PLUG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PNHRVT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PRLKEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/PULLEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RECTPIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RHCS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RHI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RHII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RHS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RNDBAR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/RNDPIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SC-ANS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SC-ISO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SC-JIS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL0.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL1.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL2.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL3.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL4.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL8.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SFTSEAL9.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SHOULDER.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SOCKET.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SPRKT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SQBOLT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SQNUT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SQPIPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SS6SCO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SS6SCU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SS6SFT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SS6SHD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSHXCO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSHXCU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSHXFT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSHXHD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSLCO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSLCU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSLFT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSLHD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSQCO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSQCU.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSQFT.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SSSQHD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/STANDARD.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/STNDOFF.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/STSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SZ-ANS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SZ-ASM-I.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SZ-ASM-M.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/SZ-ISO.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TABLE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TAGTRANS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG10.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG11.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG12.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG13.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG14.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG70.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG71.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG72.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG73.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG74.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG90.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG91.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG92.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG93.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG94.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/THRBRG95.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TPIPETAP.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG02.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG03.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG13.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG20.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG22.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG23.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRBRG29.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRUSSI.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRUSSIA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRUSSII.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/TRUSSS.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/USER-1.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/VIEW1ANG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/VIEW3ANG.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHA.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHB.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHER.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHERN.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHERR.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WASHERW.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WDFKEY.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WELDIM.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Support/en_US/Xhardware/Tbl/WTSHAPE.TXT
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default-cm.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default-imperial.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default-m.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default-mm.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default3D-imperial.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/Default3D-metric.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/STB-cm.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/STB-imperial.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/STB-m.dwt
/opt/bricsys/bricscad/v15/UserDataCache/Templates/en_US/STB-mm.dwt
/usr/bin/bricscadv11
/usr/bin/bricscadv15
/usr/share/applications/bricscadv11.desktop
/usr/share/applications/bricscadv15.desktop
/usr/share/doc/bricscadv11
/usr/share/doc/bricscadv15
/usr/share/doc/bricscadv11/changelog.Debian.gz
/usr/share/doc/bricscadv15/changelog.Debian.gz
/usr/share/icons/gnome/48x48/mimetypes/gnome-mime-application-x-bricscadv11
/usr/share/icons/gnome/48x48/mimetypes/gnome-mime-application-x-bricscadv15.png
/usr/share/menu/bricscadv11
/usr/share/menu/bricscadv15
/usr/share/mime/application/x-bricscad.xml
/usr/share/mime/application/x-bricscadv15.xml
/usr/share/mime/packages/bricscadv11.xml
/usr/share/mime/packages/bricscadv15.xml
/usr/share/pixmaps/bricscadv11.png
/usr/share/pixmaps/bricscadv15.png
/usr/src/linux-headers-3.13.0-51/sound/aoa/fabrics
/usr/src/linux-headers-3.13.0-51/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.13.0-51/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.13.0-52/sound/aoa/fabrics
/usr/src/linux-headers-3.13.0-52/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.13.0-52/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.16.0-37/sound/aoa/fabrics
/usr/src/linux-headers-3.16.0-37/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.16.0-37/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-23/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-23/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-23/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-25/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-25/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-25/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-26/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-26/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-26/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-27/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-27/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-27/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-29/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-29/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-29/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-31/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-31/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-31/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-32/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-32/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-32/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-33/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-33/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-33/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-34/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-34/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-34/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-35/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-35/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-35/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-36/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-36/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-36/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-38/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-38/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-38/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-39/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-39/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-39/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-40/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-40/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-40/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-41/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-41/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-41/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-48/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-48/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-48/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-49/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-49/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-49/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-54/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-54/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-54/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-55/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-55/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-55/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-61/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-61/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-61/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-70/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-70/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-70/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-74/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-74/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-74/sound/aoa/fabrics/Makefile
/usr/src/linux-headers-3.2.0-80/sound/aoa/fabrics
/usr/src/linux-headers-3.2.0-80/sound/aoa/fabrics/Kconfig
/usr/src/linux-headers-3.2.0-80/sound/aoa/fabrics/Makefile
/var/bricsys
/var/bricsys/BricsCADV15.lic
/var/crash/_opt_bricsys_bricscad_v11_bricscad.1000.crash
/var/crash/_opt_bricsys_bricscad_v11_bricscad.1000.upload
/var/crash/_opt_bricsys_bricscad_v11_bricscad.1000.uploaded
/var/lib/dpkg/info/bricscadv11.list
/var/lib/dpkg/info/bricscadv11.postinst
/var/lib/dpkg/info/bricscadv11.postrm
/var/lib/dpkg/info/bricscadv15.list
/var/lib/dpkg/info/bricscadv15.md5sums
/var/lib/dpkg/info/bricscadv15.postinst
/var/lib/dpkg/info/bricscadv15.postrm
/var/tmp/bricsys
Do you know what processor is in this computer?
OK, normally BricsCAD v11 won’t install in 14.04 as it depends on libglew1.5 (which isn’t available in 14.04), but it appears quite happy to run with libglew1.10 (which is) … so I’ve created a modified .deb package (only change is an edited control file with the dependency change).
Also, BricsCAD v11 is 32bit so you’ll need to install some required 32bit multiarch dependencies.
If you want to install BricsCAD v11, let’s start off by uninstalling the version you already have installed, and cleaning up a little … open a terminal and run:
sudo apt-get remove --purge bricscadv11
if that finishes without error run:
cd /opt/bricsys/bricscad
sudo rm -rf v11
Now let’s reinstall it with my edited package … run:
cd ~/Desktop
wget -O Bricscad-V11.3.16-3-en_US-edited.deb --no-check-certificate https://owncloud.linux.uk/index.php/s/HMiliawI9Ujlod6/download
you’ll now find a package on your desktop called “Bricscad-V11.3.16-3-en_US-edited.deb” … double click it to install it (it’ll probably need to pull in libjpeg62 as a dependency but this should be automatically installed for you).
Once that’s installed, you’ll need to install the required 32bit multiarch dependencies, so back in a terminal run:
sudo dpkg --add-architecture i386
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 libcups2:i386 libglu1-mesa:i386 libgtk2.0-0:i386
Once finished, try running BricsCAD Version 11 from the command line:
bricscadv11
Finally test it runs from the menu.
Mark - on creating your own deb, do you have any easy information on doing this? I’ve looked into this in the past, but always ended up really confused, and thinking “how can it be this complicated when compiling is comparitively easy?”
@Markems0
Please see my previous response:
http://linuxforums.org.uk/index.php?topic=12442.msg101663#msg101663
@chemicalfan
If you mean simply extracting the contents of a .deb … making some changes … and repacking it.
Maybe this will help
Place the original.deb in a temporary directory somewhere, and “cd” into that directory…
Extract has to be done in 2 steps, first extract the package contents (the unpacked-dir in the folloing commands will be automagically created and can be called whatever you like), then unpack the /DEBIAN directory:
dpkg-deb -x original.deb unpacked-dir
dpkg-deb -e original.deb unpacked-dir/DEBIAN
then make any changes you want to in the unpacked-dir directory
(in this case I just edited the /DEBIAN/control file to change the dependency)
Rebuilding the custom .deb:
dpkg-deb -b unpacked-dir original-edited.deb
be aware some packages (specially large ones) may appear to stall during rebuilding … but give em time … also be aware that when repacked they may be smaller than they previously were (as in this bricscad case), I assume it just used a better compression algorithm.
Is that what you were after ?
Be aware - you can distribute this .deb, but there’s no way to get this .deb onto launchpad … as I’ve said before, launchpad only accepts properly formatted source code, it then builds the packages itself against the version of Ubuntu you specified in the “changes” file.
(this stops package maintainers from including pre-compiled malicious binaries without making the source code available for peer review)
For this reason it’s generally not a clever idea to accept .deb packages from someone you don’t know and trust … think about it, I could have easily included a keylogger in the custom bricscad .deb and it’d be given elevated privileges at install time.
(I haven’t BTW :wink: )
Launchpad PPA’s don’t stop someone packaging malicious code (a reason in itself to be careful with getting software from non official PPA’s), but they do force the author to divulge the source code.
That is what I was after, perfect! Thanks Mark :slight_smile:
When it comes to Launchpad, theoretically you’d just pull down the relevent file, and then request a merge back in to the maintainers? Or is that just git?
@Markems0
@chemicalfan
That’s git
launchpad doesn’t display the separate files … just the source code as a src archive and the built package … though yeah I suppose you could just ask the maintainer to make an y changes.
but what I meant was there is no way for you to create your own launchpad PPA and upload this modified .deb “as a package”, you’d need to modify the source and upload that for rebuilding.
Nearly forgot … you’re welcome :slight_smile:
Hi.
Sorry for the delay in trying this, I have been working away in the old DDR.
I have now done the removal and downloaded the file but after downloading is complet the laptop freezes and I have to reboot (REISUB) The file in in my desktop folder but when I try to install I get “The installation of a package which violates the quality standards isn’t allowed. This could cause serious problems on your computer. Please contact the person or organisation who provided this package file and include the details beneath.” and the install stops.
What do I do next? I can click ingore and install anyway or do I need another file to install from?
Mark
