Hi Guys! Any Puppy enthusiasts out there?
I’ve installed Puppy (Lucid) on a HP Compaq Mini Netbook and I’m struggling to get the wi-fi running.
The network manager ‘sees’ wireless (wlan0) but won’t connect properly even after setting it up with the correct keys etc. In fact, sometimes it connects for a minute or two, then drops, or doesn’t connect at all on startup. After it drops, a search states ‘no wireless networks available’… ???
Mark provided a replacement for the Broadcom b43 software when I had this issue after installing Peppermint.
(OK, with the netbook connected to your router with an ethernet cable (so it has an active interweb connection), open a terminal and run:
sudo apt-get install b43-fwcutter firmware-b43-lpphy-installer
When that’s finished … REBOOT
Did wireless come to life … ie. if you click the networkmanager icon in the system tray (by clock) does it list your network ?)
I’m assuming that this software will work the same in Puppy as it is changing the wireless card software not the o/s?
The problem is this file doesn’t appear anywhere in the Puppy Package Manager and Puppy doesn’t use ‘sudo’ or ‘apt-get’ to download via the Terminal and I can’t find out the correct command or method to install it! (I found references to ‘wget’ on the internet but that isn’t in PPM either!) Any ideas please?
Thanks in advance, as always!
Rich
