i installed linux mint 21 onto my laptop, allwent well as it was supposed todo. then i tried to set uo the internet conection, i found all i had was a wired option and NO wireless option.
how do i get this option. it seems i have a lesser kernal, i have trien to upgrade the kernal to 6.2, but it all failed.
is there any program or data i can use via the terminal that will rectify this issue. im now stuck with a desktop i cant moved from with no internet facility…
First of all, it’s unlikely to be an issue with the Operating System itself in terms of the kernel or kernel version, UNLESS you have a bleeding edge brand new laptop that has some new fancy WiFi hardware that’s only supported in the latest Linux Kernel. In this instance, I’d recommend trying the latest version of Ubuntu (or Fedora) on the laptop via a Live CD or bootable USB key. (just to see if this fixes the issue)
Thoughts;
Many laptops have physical switches to enable and disable wireless connectivity, speaking from experience, make 100% sure this hasn’t been accidentally knocked into the “disabled” position
Check the interface isn’t blocked (typically there is a physical hardware switch AND a software switch)
Command line tools
Check available interfaces
# iwconfig
lo no wireless extensions.
enp19s0 no wireless extensions.
wlp7s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=15 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Check what is blocked
# rfkill list all
2: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
For anything that is blocked that you wish to use;
# rfkill unblock 2
# rfkill list all
Soft blocked: no
Hard blocked: no
Bring the device up
ifconfig wlp7s0 up
See what networks it can see …
iwlist wlp7s0 scanning
If this gives you something, then the desktop WiFi setup should be able to take over and connect you up.
If none of that helps, we might need a little more information … make and model of Laptop would be a good start …
hi mad, i get what your saying, so i did as you typred. i didnt get the same result as you. soft and hard are not blocked, byt my bluetooth soft is blocked.
i did the iwlist but it says it doesnt allow scanning
so im lost again…
Ok, that was the device name on my laptop, you need to look at the output from iwconfig for your device name. If you dont use the correct device name, then none of the above is going to help much.
It should list the devices it can see, for example on my RPi5;
$ iwconfig
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Power Management:on
So in this case my WiFi interface is called “wlan0” , whereas on my laptop it was called “wlp7s0” …
So if you do “rfkill list” you should see a “phy0” device if can see the wifi, in which case “iw dev” will give you it’s real device name. You would also try “rfkill unblock all” to try to enable everything …
its an asus aspire v5 571 series
model no ms2361
i took a screen shot of the data in the network part it said this
device 1: realtek RTL8111/8168/8411 PCI express gigabit ethernet
driver: r8169 v: kernel port:2000 bus ID:02:00.2
IF: enp2s0f2 state:down mac:
device 2: broadcom BCM43228 802.11a/b/g/n vendor: foxconn
driver:bcma-pci-bridge v: N/A bus ID: 03:00.0
Ok, so it sounds like either your wired connection has problems, so either you’re going to need to install the driver from your installation media, or you’re going to need to get a wired connection to the Internet. One way or another, the machine needs software that’s not currently present on the machine.
so how can i wire it up to get the software.
can i di it if i join two pcs together.
i have another laptop with linux mint on it, if i join them together will that work. via usb
the instalation media was a usb stick
