Chromium and kwallett
Whenever I start up Chromium for the first time after a boot-up, I get asked for my kwallet password.
All of my info Chromium info is saved on Google, not in kwallet. I have checked the command line that launches the program and I deleted the switch to select which wallet system to use. I have checked kwallet to see what info is being stored in it for Chromium and nothing is being saved there, although an entry for Chromium does exist. If I close Chromium and restart it I do not get asked again for the password. All of my wifi info is stored in kwallet, so the kwallet is opened up for that, without a password request, so the system has been already used. I have the checkbox to not close kwallet checked.
Anyone else have this problem and fixed it?
openSuse 12.2, 64-bit, Chromium v25
Hi vserghi, and welcome to the forum :slight_smile:
Can you post the contents of:
kate ~/.profile
kate /etc/chromium-browser/default
kate ~/.kde/share/config/kwalletrc
kate ~/.profile
does not exist
does not exist
[Auto Allow]
Default=KDE Dæmon,Kopete,Chromium,KDE Wallet Manager
[Auto Deny]
Default=
[Wallet]
Close When Idle=false
Close on Screensaver=false
Default Wallet=Default
Enabled=true
First Use=false
Idle Timeout=10
Launch Manager=false
Leave Manager Open=false
Leave Open=true
Prompt on Open=false
Use One Wallet=true
Run:
and move “Chromium” from “Auto Allow” to “Auto Deny”
so so the finished kwalletrc reads:-
[Auto Allow] Default=KDE Dæmon,Kopete,KDE Wallet Manager
[Auto Deny]
Default=Chromium
[Wallet]
Enabled=true
First Use=false
Idle Timeout=10
Leave Open=true
Use One Wallet=true
SAVE the file … REBOOT … test Chromium.
Or you can turn kwallet off altogether by changing
Enabled=true
to
Enabled=false
Saving the file, and rebooting.
as documented here:
Thanks, I’ll give it a go tonight.
I have considered switching off kwallet before, but then if I do, how would I connect to my wireless router without having to re-enter the password all of the time?
Network manager should remember your router password ???
You’re right, network manager remembered the password. I know in a previous openSuse release, kwallet managed it, it has obviously changed since then. Didn’t even think to try it without kwallet active ::slight_smile:
Many thanks, kwallet is now disabled and I don’t get that stupid request now.
BTW, moving Chromium to the Auto Deny section did not work.
Ah well … whatever works, right ? :wink:
