Ok, the first three steps came back saying there were 0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
Got to Ctrl + Alt + F3
After that the screen goes black, but there was no console or text and nowhere to type raxial or the password, so kind of got stuck there.
Ctrl+Alt+F1
Ctrl+Alt+F2
Ctrl+Alt+F4
Ctrl+Alt+F5
Give you a black background with text ?
if not … what happens if you do Ctrl+Alt+F3, the hold the A key for a while … does a bunch of A’s eventually appear … jjust trying to figure out if the text is there, but off screen.
BTW,
Ctrl+Alt+F7
will bring you back to your desktop
EDIT: Just a thought - might this issue no longer be an issue if I were using a different version/flavour Linux?
I did all of that, reboot, click Driver Manager, enter password, nothing happens/opens.
Here’s what came up in Terminal:
raxial@Skynet ~ $ sudo apt-get install ppa-purge
[sudo] password for raxial:
Reading package lists… Done
Building dependency tree
E: Unable to locate package ppa-purge
raxial@Skynet ~ $ sudo add-apt-repository ppa:xorg-edgers/ppa
You are about to add the following PPA to your system:
== Xorg packages fresh from git ==
Currently supported releases are Trusty/14.04, and Utopic/14.10
xserver 1.16 is now in for utopic, beware that fglrx does not support it yet!
WARNING: Do not use this PPA with the precise X backport stacks, aka if you fresh install of 12.04.2 or newer. You can switch back to a compatible one by installing xserver-xorg-lts-precise instead if you do want to use these packages but horrible things will happen if you don’t.
To revert to official packages, install the ppa-purge package and run “sudo ppa-purge xorg-edgers”.
== Important notice ==
This PPA is currently meant to be used as a whole. Please do not individually install packages from it, add it to your sources and let your package manager pull in every update. The packages here build against each other and compile different features based on whats available at build time. Do not assume that because it lets you install a DDX with just the driver and libdrm update that it will work. These packages are made with scripts that use the the current packages as the base, so some dependencies can be wrong and your package manager will not resolve that for you. If you want to individually install something from here, grab the source and rebuild it in your current environment instead.
** Please do not publish instructions for how to install from this archive without linking to this page! Anyone using packages from this archive is expected to read this page first and it is recommended to check back occasionally for notice on problems that may arise. **
More info: xorg-edgers fresh X crack : “xorg crack pushers” team
Press [ENTER] to continue or ctrl-c to cancel adding it
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.O6suH1n1BV --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 8844C542
gpg: requesting key 8844C542 from hkp server keyserver.ubuntu.com
gpg: key 8844C542: public key “Launchpad PPA for xorg crack pushers” imported
gpg: Total number processed: 1
gpg: imported: 1 (RSA: 1)
raxial@Skynet ~ $ sudo apt-get upgrade
Reading package lists… Error!
E: Type ‘Linux x64 (AMD64/EM64T) Display Driver | 340.17 | Linux 64-bit | NVIDIA is not known on line 1 in source list /etc/apt/sources.list.d/additional-repositories.list
E: The list of sources could not be read.
E: The package lists or status file could not be parsed or opened.
raxial@Skynet ~ $ sudo apt-get dist-upgrade
Calculating upgrade… Done
raxial@Skynet ~ $
Okay, that brings this: cat /etc/apt/sources.list.d/additional-repositories.list
Then this:
raxial@Skynet ~ $ sudo apt-get update
raxial@Skynet ~ $
“NO … I doubt if ANY flavour will have the 340 drivers in their repos yet.” ~ Fair 'nuff
Sorry I missed all that, staff away day on Friday :-[
It’s possible to run with the Intel graphics in place, at least on a non-EFI machine (can’t see what difference EFI makes), as it’s what I’m running on my laptop. Although if this is a desktop, it’s a different ballgame as your monitor will probably be plugged into your nVidia card (why wouldn’t it?!)
