Creating Filesystems with Openmediavault (Solved)
GOOD … ok reboot, don’t go into the webUI … just run the apt-get install command.
Started ok got to the part where I had to select [Y/n] I selected “Y” then a lot of error messages mainly “Temporary failure resolving 'ftp.debian.org
OK, can you post the output from:
cat /etc/apt/sources.list
ping -c 5 google.com
Sorry i cant get copy/paste to work in Putty I’ll need to work on that.
Hope a screenshot is ok
ping returned “unknown host google.com
OK, run:
nano /etc/apt/sources.list
and REMOVE the line we added at the bottom.
Then find the line:-
deb Index of /debian/ squeeze main
and change it to
deb Index of /debian/ squeeze main contrib non-free
SAVE the file.
now run:
apt-get update
apt-get install firmware-atheros wpasupplicant
did that work ?
[Once again sorry about the screenshots but it’s the only way I can get outputs back to you, but I’ve increased the font, hope that makes it easier :slight_smile:
First did you remove the bottom line we added to sources.list ?
and secondly … do either of these pings work ?
ping -c 5 173.194.34.135
No I never removed any lines
Unknown host google.com
7 packets transmitted 5 received
Just checked I missed that instruction I’ve removed it now sorry
Ok
Can you take a screenshot of:
cat /etc/network/interfaces
Screenshot attached
OK, run:
nano /etc/network/interfaces
and make it read:-
The loopback network interface
auto lo
The primary network interface
allow-hotplug eth0
iface eth0 inet static
address 192.168.2.150
netmask 255.255.255.0
network 192.168.2.0
broadcast 192.168.2.255
gateway 192.168.2.1
dns-nameservers 192.168.2.1
SAVE the file … then REBOOT
then run:
apt-get update
did it work ?
Just getting the same error messages as before, also I can’t ssh ( no route to host)
if you want to give it a break for tonight it’s ok with me :slight_smile:
ignore the last post
I couldn’t remember if I rebooted but I must have because I’m getting the same problem also I’m seeing a lot of error messages highlighted in red mostly relating to samba, I’m gonna check to see if I followed your instructions editing the /etc/network/interfaces file
huh ?
I double checked I edited the /etc/network/interfaces file and I did make a mistake I had dns-nameserver instead of dns-nameservers so I fixed that and rebooted but I’m having the same problems, there are quite a few error messages highlighted in red during boot mainly referring to NFS & Samba, I can’t log in via ssh (no route to host) and it still wont update and it wont log in to the Web GUI.
The problem seems to be worse since we edited the /etc/network/interfaces file
OK, edit it back to:-
# The loopback network interface
auto lo
# The primary network interface
auto eth0
allow-hotplug eth0
    gateway 192.168.2.1
SAVE the file, and then REBOOT.
now does:-
apt-get update
work ?
It’s freezing on boot on line
Starting NFS common utilities: statd (flashing cursor)
damn it … have you got a livecd ?
damn it .. have you got a livecd ?
Yes peppermint 3 :slight_smile:
