Creating Filesystems with Openmediavault (Solved)
It has finally booted
Good … do those commands work ?
Looks like you’ve done it Mark it’s updated and installed :slight_smile:
Do you want to carry on and get wireless working tonight … or tomorrow … up to you as I’ll be online for a couple of hours yet.
Ok if you don’t mind going on we’ll try to get it working tonight
Thanks :slight_smile:
OK :slight_smile:
What’s the output from:
ip link
does it mention wlan0 or wlan1 or similar ?
Screenshot attached
is the USB wireless adapter plugged in ? … if so, unplug it … wait 10 seconds and replug it … then run:
ip link
now does it mention wlan0 or wlan1 or similar ?
It mentions wlan0
OK, run:
nano /etc/network/interfaces
and make it read:-
# The loopback network interface
auto lo
# The primary network interface
# auto eth0
# allow-hotplug eth0
iface eth0 inet static
    address 192.168.2.150
    netmask 255.255.255.0
    gateway 192.168.2.1
    dns-nameservers 192.168.2.1
# The wireless network interface
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
    address 192.168.2.151
    gateway 192.168.2.1
SAVE the file … now reboot without the ethernet cable … and see if you can log on using 192.168.2.151 wirelessly.
Be sure to comment out the
auto eth0
allow-hotplug eth0
lines :wink:
Unfortunately I can’t log in to the Web GUI or ssh
I don’t know if it means anything but I’mm getting quite a few failures highlighted in red during boot pertaining to NFS & samba
OK, run:
and try making it read:-
auto lo
# auto eth0
# iface eth0 inet static
#     address 192.168.2.150
#     netmask 255.255.255.0
#     gateway 192.168.2.1
#     dns-nameservers 192.168.2.1
auto wlan0
    gateway 192.168.2.1
Then rebooting and trying the wireless on 192.168.2.150
so you’re commenting out ALL the lines for the first interface … changing the wireless address to 192.168.2.150 … and also removing the line:
allow-hotplug wlan0
It’s freezing on
“Starting NFS common utilities: statd” again
But I’ll leave it and it will probably boot eventually like the last time :slight_smile:
Does that mean you’re off for the night ?
Finally booted but still no Web GUI or ssh :slight_smile:
Lets call it a day and we can take it up again later your head must be spinning with this, I know mine is :slight_smile:
OK … you can bung the interfaces file back to how it was when it was working on ethernet if you like:
auto lo
auto eth0
allow-hotplug eth0
    gateway 192.168.2.1
and reboot.
and I’ll no doubt see you tomorrow … where we’ll try work out what’s up with samba and NFS
Ok I’ve re-edited the /etc/network/interfaces file back as per your last post and rebooted, so as it stands now with only the usb wireless adaptor connected, I cannot connect to the Web GUI or ssh.
There is still a lot of errors showing up during the boot sequence mostly pertaining to samba & NFS services and it hangs at the line “Starting NFS common utilities: statd” for a considerable time before eventually booting.
Anyway I’m off to work, hopefully we can sort this out later today
Thanks for your help and patience so far
As it is it’ll only be working with the ethernet cable till we can work out why that wireless section in /etc/network/interfaces didn’t work, and where these SAMBA and NFS errors are coming from.
but it would be most helpful if we could first work out how to copy and paste from PuTTY.
(the screenshots aren’t searchable, I can’t copy/paste from them, and they take up unnecessary room on the server)
According to the PuTTY manual:-
PuTTY's copy and paste works entirely with the mouse. In order to copy text to the clipboard, you just click the left mouse button in the terminal window, and drag to select text. When you let go of the button, the text is automatically copied to the clipboard
So you’d just use your left mouse button to drag-select the text you want to copy, then release the left mouse button … then go to your web browser and paste in the normal way.
Does this work ?
The best way to accelerate a Windows PC = 32 f/s²
Quote PuTTY's copy and paste works entirely with the mouse. In order to copy text to the clipboard, you just click the left mouse button in the terminal window, and drag to select text. When you let go of the button, the text is automatically copied to the clipboard
Does this work ?
Nearly… it depends on what you consider the normal way, normally I would right click then select paste from the dropdown menu but with Putty I have to middle click then paste, anyway the important thing is it works so I’m good to go
Thanks
Any reason for using PuTTY? Judging by the screen shots, are you not using Peppermint?
If you are then you could try using ssh (might haveto install ssh or openssh-client
Also the copy paste issue might be down to the terminal emulator you are using
I personally find Terminal from XFCE very useful, but Lxterminal from LXDE is also good
