I am running Ubuntu 16.04 on a Thinkpad T500.
When attempting to print to my HP 7610 it didn’t appear on the printer list so I checked System-Settings/Printers but there was nothing listed and the Add button was greyed out. Clicking on Help/Troubleshooting produced the message: CUPS Service Stopped The CUPS print spooler does not appear to be running. To correct this, choose System->Administration->Services from the main menu and look for the ‘cups’ service.
However, I see no Administration->Services option.
Browsing the web I found several other queries about this problem and tried a couple of the suggested solutions: keith@T500:~$ sudo /etc/init.d/cups start
[sudo] password for keith:
keith@T500:~$ sudo service cups restart
Failed to restart cups.service: Unit cups.service is masked.
But all to no effect.
I tried visiting [b]http://localhost:631/printers/[/b] but it wasn’t available.
I have made no changes to the system other than the usual updates, and would be very grateful for suggestions.
keith@T500:~$ service unmask cups.service
unmask: unrecognized service
keith@T500:~$ service cups start
Job for cups.socket failed. See “systemctl status cups.socket” and “journalctl -xe” for details.
keith@T500:~$
keith@T500:~$ sudo apt-get install --reinstall cups cups-browsed cups-client cups-common cups-daemon cups-server-common
Reading package lists… Done
Building dependency tree
Setting up cups-client (2.1.3-4ubuntu0.3) …
Setting up cups (2.1.3-4ubuntu0.3) …
Updating PPD files for cups …
keith@T500:~$ sudo systemctl daemon-reload
keith@T500:~$
Then I tried:
System-settings/printers: Tried to print test page but:
Printer state: “Idle - File “/usr/lib/cups/filter/hpcups” not available: No such file or directory”
keith@T500:~$ service cups status
? cups.service - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2017-09-20 17:25:29 BST; 8min ago
Docs: man:cupsd(8)
Main PID: 8930 (cupsd)
CGroup: /system.slice/cups.service
??8930 /usr/sbin/cupsd -l
??9361 /usr/lib/cups/notifier/dbus dbus://
Sep 20 17:25:29 T500 systemd[1]: Started CUPS Scheduler.
Sep 20 17:25:31 T500 systemd[1]: Started CUPS Scheduler.
Sep 20 17:25:52 T500 systemd[1]: Started CUPS Scheduler.
keith@T500:~$ file /lib/systemd/system/cups.service
/lib/systemd/system/cups.service: ASCII text
keith@T500:~$
Is the missing file /usr/lib/cups/filter/hpcups the problem?
sudo apt-get install --reinstall printer-driver-hpcups had no effect but your comment re hplip GUI caused me to check that it was still installed - which of course it wasn’t since my catastrophic computer crash a while ago, when I clearly had forgotten to re-install it, although the printer has been working flawlessly up to yesterday. It’s interesting, though, that that last command didn’t supply the missing file.
I’ve installed HPLIP it now and all is well. Very many thanks for your advice, Mark. As usual!
My issue seems to be a tad different…
using mint tara
hp dj 3634
printer was working about 1 month ago, then cups updated to 2.0.0 from 1.7x
now cups won’t start, hplip doesn’t think cups is even installed so it fails.
tried updating hplip to newest as of post time, still same issue.
Active: failed (Result: start-limit-hit) since Thu 2019-06-06 10:01:29 EDT; 1
Docs: man:cupsd(8)
Process: 14953 ExecStart=/usr/sbin/cupsd -l (code=killed, signal=TERM)
Main PID: 14953 (code=killed, signal=TERM)
Jun 06 10:01:29 ph3arr3tus systemd[1]: cups.service: Service hold-off time over,
Jun 06 10:01:29 ph3arr3tus systemd[1]: cups.service: Scheduled restart job, rest
Jun 06 10:01:29 ph3arr3tus systemd[1]: Stopped CUPS Scheduler.
Jun 06 10:01:29 ph3arr3tus systemd[1]: cups.service: Start request repeated too
Jun 06 10:01:29 ph3arr3tus systemd[1]: cups.service: Failed with result 'start-l
Jun 06 10:01:29 ph3arr3tus systemd[1]: Failed to start CUPS Scheduler.
Sorry about the delay, thanks for getting back to me, I finally was able to log into this site after finding password… and still having same issue.
output is "root 795 0.1 0.0 103376 9116 ? Ss 21:33 0:00 /usr/sbin/cupsd -l "
as a side note if relevant
Mint sees the Canon Pixma TS3320 printer as Device URI: usb://Canon/TS3300%20series?serial=9354
Knoppix sees it as Dev URl - usb://Canon/TS3300%20series?serial=935489&interface=1
printer does work in Knoppix
Actually got back in… changed printer url to knoppix settings & works again for now, now for the scanner…
that problem stems from something about libc6 needs a major version update…
