Download speed painfully slow (SOLVED)
Hi guys
I’ve just installed Peppermint 5 to my daughters PC which I have connected to my network, I’ve been having video streaming problems and I think the problem might be due to extremely slow download speed compared to other PC’s connected to the network, there are 4 PC’s currently connected and the download speed ranges between 12mbps & 26mbps however the PC in question is only reporting 0.48mbps which seems unnaturally slow
The values are taken from this site http://www.bandwidthplace.com/
Any help or suggestions would be much appreciated
is this wireless ?
What does networkmanager say is the wireless connection speed ?
Does it take longer to transfer a large file from your NAS on this PC than others ?
is this wireless ?
Yes USB wireless
On average about 60mbps at the same time the other PC’s record about 108 mbps
Yes much longer I tested it with a 14mb music video it took 1min 20 secs to copy from the NAS to the Home folder while the other 2 PC’s took only 3 secs to do the same thing
Okey dokey, one further thing I’d like you to do befre sending all the connection info
Make sure all PC’s are OFF … reboot the router … fire up this PC and test if wireless has improved (you can ignore your NAS, just have as many PC’s as possible OFF when testing this one).
Then send the connection info:
sudo lshw -C network
ifconfig
iwconfig
Ok I did as you suggested, copying the same music video took only 30 sec this time (still 10 times slower than the other PC’s) connection speed is the same and playing a youtube video is no better,
One thing that was strange although it might not mean anything is before I did anything I tried to connect to the router interface to make sure I could reboot from the PC when ready and it wouldn’t connect nor would it connect with the other PC’s so I had to reboot the router manually, now that it’s been rebooted it’s connecting no problem.
Anyway here’s the outputs you asked for
laura-paul@OurPC ~ $ sudo lshw -C network
[sudo] password for laura-paul:
  *-network
       physical id: 1
       bus info: usb@2:4
       logical name: wlan0
       serial: c8:3a:35:ca:0e:df
       configuration: broadcast=yes driver=rt2800usb driverversion=3.13.0-34-generic firmware=0.29 ip=192.168.2.20 link=yes multicast=yes wireless=IEEE 802.11bgn
laura-paul@OurPC ~ $ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:3438 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3438 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:524866 (524.8 KB)  TX bytes:524866 (524.8 KB)
wlan0     Link encap:Ethernet  HWaddr c8:3a:35:ca:0e:df
          inet addr:192.168.2.20  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::ca3a:35ff:feca:edf/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:24478 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15688 errors:0laura-paul@OurPC ~ $ sudo lshw -C network
  *-network
       physical id: 1
       bus info: usb@2:4
       logical name: wlan0
          TX packets:15688 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:32091403 (32.0 MB)  TX bytes:1729481 (1.7 MB)
laura-paul@OurPC ~ $ iwconfig
wlan0     IEEE 802.11bgn  ESSID:"Network Emegra"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 74:44:01:FA:1A:B8
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=37/70  Signal level=-73 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:56  Invalid misc:294   Missed beacon:0
laura-paul@OurPC ~ $ dropped:0 overruns:0 carrier:0
          Power Management:on
First try this:
sudo modprobe -r rt2800usb
sudo modprobe rt2800usb nohwcrypt=1
did that make any difference ?
What’s the output from:
lsusb
Ok I can’t carry out the instructions because it’s dropping connection constantly and the only way I can reconnect is to reboot and to add to that anytime the network drops out the PC refuses to shut down, it get to the screen Peppermint, Shutting Down , the red progress bar get to about a quarter of the way across and stops and I have to hit the power button, this is not a new problem I have been experiencing this as well as the slow connection but it wasn’t as frequent as it is now.
However I’ve come across another USB adaptor and that seems to be working better, the connection speed seems to be about the same but I copied the music video over in 7 seconds which is much more in line with the other PC’s, youtube videos is better and almost watchable
and now after typing all that I’ve just noticed the network has dropped out again but it popped in again after a few minutes :frowning:
Just checked internet download speed and it seems a little better at 2.64mbps but it’s lower than the upload at 3.07mbps
Okey dokey, are you sure this isn’t just a location issue … is the download speed still rubbish if you move elsewhere ?
With a USB adapter post the output from:
lsusb
ifconfig
iwconfig
iwlist scanning
rfkill list
that covers pretty much everything I should need to know … and really should be posted with any enquiry about wireless (note to self, might be a good idea to post this as a sticky) :slight_smile:
laura-paul@OurPC ~ $ lsusb
Bus 007 Device 002: ID 14cd:8168 Super Top
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 050d:705c Belkin Components F5D7050 Wireless G Adapter v4000 [Zydas ZD1211B]
*-network
physical id: 1
bus info: usb@6:1
logical name: wlan1
serial: 00:11:50:b2:ca:89
configuration: broadcast=yes driver=zd1211rw driverversion=3.13.0-34-generic firmware=4725 ip=192.168.2.20 link=yes multicast=yes wireless=IEEE 802.11bg
RX packets:369310 errors:0 dropped:0 overruns:0 frame:0
TX packets:369310 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:94158819 (94.1 MB) TX bytes:94158819 (94.1 MB)
wlan1 Link encap:Ethernet HWaddr 00:11:50:b2:ca:89
inet6 addr: fe80::211:50ff:feb2:ca89/64 Scope:Link
RX packets:338315 errors:0 dropped:0 overruns:0 frame:0
TX packets:259530 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:397677061 (397.6 MB) TX bytes:60373704 (60.3 MB)
wlan1 IEEE 802.11bg ESSID:“Network Emegra”
Bit Rate=54 Mb/s Tx-Power=27 dBm
Power Management:off
Link Quality=28/100 Signal level=28/100
Tx excessive retries:62 Invalid misc:405 Missed beacon:0
laura-paul@OurPC ~ $ iwlist scanning
wlan1 Scan completed :
Cell 01 - Address: 74:44:01:FA:1A:B8
Channel:6
Encryption key:on
24 Mb/s; 36 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000001347d26911
Extra: Last beacon: 91356ms ago
IE: Unknown: 000E4E6574776F726B20456D65677261
IE: Unknown: 030106
IE: Unknown: 2A0104
IE: Unknown: 2F0104
Group Cipher : TKIP
IE: Unknown: 32040C121860
IE: Unknown: 2D1AFE181BFFFF000001000000000000000000000000000000000000
IE: Unknown: 3D1606051700000000000000000000000000000000000000
IE: Unknown: 7F0101
IE: Unknown: DD7E0050F204104A0001101044000102103B000103104700107D70BC53E951030A126C5E8F3C161C26102100074E657467656172102300074E6574676561721024000631323334353610420007303030303030311054000800060050F204000110110007564D4447343835100800022008103C0001011049000600372A000120
IE: Unknown: DD090010180207F02C0000
IE: WPA Version 1
Group Cipher : TKIP
laura-paul@OurPC ~ $ rfkill list
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
Try temporarily disabling wireless encryption in the router and seeing if that improves anything.
You didn’t answer my question whether this could purely be “location” based … does another laptop give much better results from the same room ?
Ok I’ll give that a try and post back
You didn't answer my question whether this could purely be "location" based .. does another laptop give much better results from the same room ?
Sorry Mark I’ve been distracted today with one thing or another this is not a laptop it’s a desktop PC so I’m limited as to where I can locate it but it’s currently located no more than 3 feet from my PC which has no issues, the router is in the attic and positioned no more than 10 feet away directly above
Many thanks
is that other PC wireless ? … what happens if you try it’s wireless adapter ?
just trying to figure out if it’s the adapter or not.
is that other PC wireless ? .. what happens if you try it's wireless adapter ?
The other PC is wireless but it’s PCI, and unfortunately I don’t have a spare PCI slot on Laura’s PC (my daughter) it’s taken up with a ethernet card but I’ve just thought I do have a USB ethernet adaptor so I can use that and try a PCI wireless card in it’s place
Would that be worth trying ?
Can’t hurt … why do you need an ethernet adapter at all ?
Can't hurt ..
Ok I’ll give that a try tomorrow and post back
I thought you were gonna ask that, I’ll try to explain what I’m trying to do
This PC was running Peppermint 4 so it needed to be upgraded anyway but my daughter asked me if it was possible put all Chloes movies, music videos etc on it and set up a softmodded xbox running XBMC in her bedroom to stream the videos to her TV so the idea is to use the PC as a normal computer and a media server so I need wireless to connect to the internet and ethernet to connect the xbox to the PC
Hope I’ve explained that ok
So far I’m not having much luck, the PC is running fine and although the internet connection could be better it may be as good as I’m gonna get and it’s probably adequate for normal browsing, the main issues I’m having as well as the network problem is getting the xbox to connect to the PC via SMB but that’s a completely different issue so I’ll post a new thread if I get completely stuck
Many thanks for your help so far
What I’m trying to figure out is - is this a problem on the PC/OS itself, or just down to duff network adapters.
So what would be handy is if you remove all network adapters, then remove all entries in this file:
sudo gedit /etc/udev/rules.d/70-persistent-net.rules
so it now just reads:-
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
SAVE the file and shut down.
Now try the network adapter from the other PC in the room in this one … and see if it has the same kinda connection speed as the one you just removed it from.
That way we can say whether it’s purely the adapter or not.
You can always replace the network adapter afterwards.
ok I tried what you suggested and installed the card from my PC but it’s not showing any available networks, it is being detected in the PC
laura-paul@OurPC ~ $ lshw -c network
  *-network
       product: RT3062 Wireless 802.11n 2T/2R
       vendor: Ralink corp.
       physical id: 8
       bus info: pci@0000:00:08.0
       logical name: wlan0
       version: 00
       serial: c8:3a:35:c0:6d:57
       width: 32 bits
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rt2800pci driverversion=3.13.0-34-generic firmware=0.34 latency=32 link=no maxlatency=4 mingnt=2 multicast=yes wireless=IEEE 802.11bgn
       resources: irq:16 memory:dffe0000-dffeffff
Before I done this I tried a PCI wireless card I had lying around to save me taking the one out of my PC and although it connected to the network it made no difference so I then followed you instructions again and installed the one from my PC
Ok I got the card working by deleting all the connections in the network manager and rebooting and the difference in the download speed is amazing
before the best I could get was about 2.2mbps but normally less than 1mbps but after installing the card from my PC it recorded 49mbps which is faster than any of the other PC’s have recorded
Cool … are we done here, or do you want to try deleting them again, and going back to the second USB card, and see what happens ?
Yeah we’re done thanks,
I’m just gonna leave things as they are I’ll leave the spare PCI card in my PC for now it’s recording a slower download speed but not as low as it was recording in Laura’s PC but I can get a better card at a later date
Many thanks I’ll mark this solved
