dpkg error
Hi guys
I’m trying to install an application with LXLE 32bit non pae but I’m being prevented with an error message prompting me to run this command
 sudo dpkg --configure -a
when I run this command It downloads nautilus-dropbox to 100% then hangs
Here’s the terminal output
graeme@laptop1:~$ sudo dpkg --configure -a
Setting up nautilus-dropbox (0.7.1-2) ...
Downloading Dropbox... 100% o share and store your files online. Want to learn more? Head to http://www.dropbox.com/
What are you trying to install … and where from ?
Does LXLE even use nautilus as the file manager ?
What are you trying to install .. and where from ?
I’m trying to install Entangle from the repos
No it uses pcmanfm, but I must have found nautilus-dropbox from the repos and attempted to install that previously but I can’t remember
OK run:
sudo apt-get remove --purge nautilus-dropbox
now try installing Entangle.
If you want dropbox installing, let me know and I’ll look into it … but please let me know if LXLE is based on Ubuntu 12.04 ?
I tried that earlier but I just go round in circles
graeme@laptop1:~$ sudo apt-get remove --purge nautilus-dropbox
[sudo] password for graeme:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
graeme@laptop1:~$
What happens if you run:
sudo dpkg --purge nautilus-dropbox
That sorted it Mark and I’ve now managed to install entangle
Thank you :slight_smile:
No problem :slight_smile:
