I have a Toshiba Satellite 350-17P laptop, 64 bit running Windows 7 that I want to dual boot with Peppermint 6.
I have successfully installed Peppermint alongside win7 and am happy with that so far.
I now want to install DraftSight in Peppermint and started to install from a previous thread I made concerning this but it is not going well.
When I run the first command I get this
jack@jack ~ $ sudo apt install libaudio2:i386 libxt6:i386 libgtk2.0-0:i386 lib32z1 lib32ncurses5 lib32bz2-1.0 lib32stdc++6 libgl1-mesa-glx:i386 libglu1-mesa:i386
[sudo] password for jack:
Reading package lists… Done
Building dependency tree
libaudio2:i386 is already the newest version.
libaudio2:i386 set to manually installed.
libxt6:i386 is already the newest version.
libxt6:i386 set to manually installed.
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.4)
Recommends: libgl1-mesa-dri:i386 (>= 7.2)
jack@jack ~ $
Can you help me here please
