Is this what you are looking for ?
don@ldwatson ~ $ uname -a
Linux ldwatson 3.16.0-40-generic #54~14.04.1-Ubuntu SMP Wed Jun 10 17:30:45 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
don@ldwatson ~ $
don@ldwatson ~ $
Crud … no wonder they’re throwing a wobbly, we’ve been trying to install the 32bit drivers in 64bit Peppermint.
OK, run:
sudo apt-get remove --purge iscan
sudo apt-get remove --purge iscan-data
sudo apt-get remove --purge epson-inkjet-printer-201101w
did those complete without error ?
If so, I’ll post links to the 64bit drivers in a bit.
Thanks Mark,
Carried out the request and it seems quite happy so far.
OK, let’s download these 3 files and install them in this order (any problems, stop and tell me what they are):
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_amd64.deb
iscan-data_1.36.0-1_all.deb
iscan_2.30.1-1~usb0.1.ltdl7_amd64.deb
Carried out your suggestion and there are no problems showing
So are you able to add the printer now ?
Thanks Mark,
I have the Sx 130 installed ok, and the the Photosmart 7580, thanks very much.
The Epson SX 130 is an all-in-one, can I get the scanner working ?
menu > Graphics > Image Scan! for Linux
maybe ?
Or isn’t that there ?
:-[ Thanks Mark :-[ I could have sworn it wasn’t there last night ?
It is working fine thanks
Can I go and check out the cribbage now ?
take care
Don W
PS I will need to raise the spectre of WiFi again. I will wait for a little while.
Sure … the bsdgames should install fine now
