Drivers for Epson SX130 printer
I have upgraded to Peppermint 6 using the tutorial about installing Pep 5 on an Acer.
I have most things sorted ok but I have came to a halt with the printer.
I found the following that I used before
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
iscan-data_1.26.0-1_all.deb
iscan_2.29.3-1~usb0.1.ltdl7_i386.deb
but I downloaded the first part and ran that but I only get an error 404 for the other 2 parts
Is there another source for updates ?
take care
Don W
Try these links
iscan_2.30.1-1~usb0.1.ltdl7_i386.deb
iscan-data_1.36.0-1_all.deb
I don’t think you need ths, but I’ll link to it anyway
epson-printer-utility_1.0.0-1lsb3.2_i386.deb
I get an error when I have tried to install the first part ( epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb )
Error: Failed to satisfy all dependencies (broken cache )
EDIT I have 2 instances of ‘Package Installer’ in the toolbar that won’t delete.
EDIT EDIT I have moved upstairs and connected the printer.
I have used Menu>System Tools>Printers and loaded the Epson Printer and printed the usual Test Page.
Thanks for the help Mark. I was trying to get these bits and pieces to work on my own (with your help actually) as most of these things I have asked about before, so they must be on the forums.
I need a method of finding them, should I search using posts by don watson including google, wifi. printer, etc.
you’ve lost me…
Are you still having problems installing ? … if so, can you post the output from:
then put those 3 files on your Desktop … then post the output from:
sudo dpkg -i ~/Desktop/epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
and post the output from that too.
Hi Mark
The first part gives this
don@ldwatson ~ $ sudo apt-get update
[sudo] password for don:
Ign http://ppa.launchpad.net trusty InRelease
Ign http://extras.ubuntu.com trusty InRelease
Hit http://ppa.launchpad.net trusty Release.gpg
Ign http://archive.canonical.com trusty InRelease
Ign http://gb.archive.ubuntu.com trusty InRelease
Hit http://extras.ubuntu.com trusty Release.gpg
Ign http://gb.archive.ubuntu.com trusty-updates InRelease
Ign http://gb.archive.ubuntu.com trusty-backports InRelease
Hit http://archive.canonical.com trusty Release.gpg
Hit http://ppa.launchpad.net trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty Release.gpg
Hit http://extras.ubuntu.com trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty-updates Release.gpg
Hit http://ppa.launchpad.net trusty/main amd64 Packages
Hit http://extras.ubuntu.com trusty/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports Release.gpg
Hit http://extras.ubuntu.com trusty/main i386 Packages
Hit http://ppa.launchpad.net trusty/main i386 Packages
Hit http://archive.canonical.com trusty/partner Sources
Hit http://ppa.launchpad.net trusty/main Translation-en
Ign http://security.ubuntu.com trusty-security InRelease
Hit http://archive.canonical.com trusty/partner amd64 Packages
Hit http://archive.canonical.com trusty/partner i386 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse Sources
Hit http://archive.canonical.com trusty/partner Translation-en
Hit http://gb.archive.ubuntu.com trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty/restricted Sources
Hit http://security.ubuntu.com trusty-security Release.gpg
Hit http://gb.archive.ubuntu.com trusty/universe Sources
Hit http://gb.archive.ubuntu.com trusty/main amd64 Packages
Ign http://extras.ubuntu.com trusty/main Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty/restricted i386 Packages
Hit http://security.ubuntu.com trusty-security/multiverse Sources
Hit http://gb.archive.ubuntu.com trusty/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty/main Translation-en_GB
Hit http://security.ubuntu.com trusty-security/main Sources
Hit http://gb.archive.ubuntu.com trusty/multiverse Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty/restricted Translation-en_GB
Hit http://security.ubuntu.com trusty-security/restricted Sources
Hit http://gb.archive.ubuntu.com trusty/universe Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse Sources
Hit http://gb.archive.ubuntu.com trusty-updates/main Sources
Hit http://security.ubuntu.com trusty-security/universe Sources
Hit http://gb.archive.ubuntu.com trusty-updates/restricted Sources
Hit http://gb.archive.ubuntu.com trusty-updates/universe Sources
Hit http://gb.archive.ubuntu.com trusty-updates/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/restricted amd64 Packages
Hit http://security.ubuntu.com trusty-security/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse amd64 Packages
Hit http://security.ubuntu.com trusty-security/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/restricted i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse i386 Packages
Hit http://security.ubuntu.com trusty-security/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/main Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/universe Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main Sources
Hit http://gb.archive.ubuntu.com trusty-backports/restricted Sources
Hit http://gb.archive.ubuntu.com trusty-backports/universe Sources
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse Sources
Hit http://security.ubuntu.com trusty-security/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse amd64 Packages
Hit http://security.ubuntu.com trusty-security/restricted i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/restricted i386 Packages
Hit http://security.ubuntu.com trusty-security/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main Translation-en
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse Translation-en
Hit http://gb.archive.ubuntu.com trusty-backports/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe Translation-en
Hit http://security.ubuntu.com trusty-security/main Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse Translation-en
Hit http://security.ubuntu.com trusty-security/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/universe Translation-en
Reading package lists… Done
don@ldwatson ~ $
This is the other result
don@ldwatson ~ $ sudo dpkg -i ~/Desktop/epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
Selecting previously unselected package epson-inkjet-printer-201101w.
(Reading database … 237603 files and directories currently installed.)
Preparing to unpack …/epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb …
Unpacking epson-inkjet-printer-201101w (1.0.0-1lsb3.2) …
dpkg: dependency problems prevent configuration of epson-inkjet-printer-201101w:
epson-inkjet-printer-201101w depends on lsb (>= 3.2).
dpkg: error processing package epson-inkjet-printer-201101w (–install):
dependency problems - leaving unconfigured
don@ldwatson ~ $
I have used Menu>System Tools>Printers and loaded the Epson Printer SX130 under ‘Network’. It is printing at the moment.
OK, can you run:
sudo apt-get remove --purge epson-inkjet-printer-201101w
sudo apt-get install lsb
then double click on the epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb file and click the “Install” button
did it install without error ?
Sorry Mark,
It came up with the same error
what happens if you run:
sudo apt-get -f install
does that fix things ?
I ran that and it produced this
don@ldwatson ~ $ sudo apt-get -f install
Building dependency tree
linux-headers-3.16.0-37 linux-headers-3.16.0-37-generic
linux-image-3.16.0-37-generic linux-image-extra-3.16.0-37-generic
don@ldwatson ~ $
Do I need to run the other 2 parts now ? ( iscan_2.30.1-1~usb0.1.ltdl7_i386.deb and iscan-data_1.36.0-1_all.deb ) ?
if you get a any return from:
dpkg -l | grep epson-inkjet-printer-201101w
then yeah … install the other 2 packages
If nothing is returned, let me know.
I get this
don@ldwatson ~ $ dpkg -l | grep epson-inkjet-printer-201101w
rc epson-inkjet-printer-201101w 1.0.0-1lsb3.2 i386 EPSON Stylus NX130 Series - Epson Inkjet Printer Driver
don@ldwatson ~ $
Is that safe for me to install the other 2 packages now ?
yep, go for it :slight_smile:
You should also be good to go in your cribbage topic now too
Sorry Mark,
When I double click on Iscan package installer it says 'Error: Dependency is not satisfiable: iscan data
install iscan-data first … THEN iscan :wink:
In other words … install them in this order
The iscan-data went in ok but the iscan is still throwing up an error.
Error: Failed to satisfy all dependencies ( broken cache ) ?
try:
again
it’s these damn alien converted packages ::slight_smile:
I used the instructions and now have this. I think I will stop now as I don’t remember what I am looking for. :-\
Correcting dependencies… Done
libatk1.0-0:i386 libcairo2:i386 libexif12:i386 libgd3:i386
libgdk-pixbuf2.0-0:i386 libgphoto2-6:i386 libgphoto2-port10:i386
libgraphite2-3:i386 libgtk2.0-0:i386 libharfbuzz0b:i386 libieee1284-3:i386
libjasper1:i386 libltdl7:i386 libpango-1.0-0:i386 libpangocairo-1.0-0:i386
libpangoft2-1.0-0:i386 libpixman-1-0:i386 libsane:i386 libusb-0.1-4:i386
libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libvpx1:i386
libxcb-render0:i386 libxcb-shm0:i386 libxcomposite1:i386 libxcursor1:i386
libxinerama1:i386 libxpm4:i386 libxrandr2:i386 linux-headers-3.16.0-37
linux-headers-3.16.0-37-generic linux-image-3.16.0-37-generic
The following packages will be REMOVED
iscan:i386
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 1,487 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 240021 files and directories currently installed.)
Removing iscan (2.30.1-1~usb0.1.ltdl7) …
Processing triggers for man-db (2.6.7.1-1ubuntu1) …
Processing triggers for mime-support (3.54ubuntu1.1) …
Processing triggers for desktop-file-utils (0.22-1ubuntu1) …
Processing triggers for libc-bin (2.19-0ubuntu6.6) …
don@ldwatson ~ $
Is this ok ?
I’ll have a look at this in the morning … need sleep
can you confirm you’re on the 32bit kernel with ten output from:
uname -a
and I’ll try testing the drivers installation myself.
