Ok I think we’re doing progress here… but not quite there.
It’s looping into this:
~$ sudo wvdial
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZ
OK
--> Sending: ATE0
OK
--> Sending: AT+CGDCONT=1,"IP","3ireland.ie"
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
CONNECT 7200000
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Thu Nov 25 18:07:46 2010
--> Pid of pppd: 22487
--> Using interface ppp0
--> pppd: (�G[08]X�G[08]@�G[08]
--> Disconnecting at Thu Nov 25 18:07:46 2010
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
--> Auto Reconnect will be attempted in 5 seconds
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
CONNECT 7200000
--> Starting pppd at Thu Nov 25 18:07:51 2010
--> Pid of pppd: 22505
--> Disconnecting at Thu Nov 25 18:07:52 2010
--> Auto Reconnect will be attempted in 10 seconds
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
CONNECT 7200000
--> Starting pppd at Thu Nov 25 18:08:02 2010
--> Pid of pppd: 22538
--> Disconnecting at Thu Nov 25 18:08:03 2010
--> Auto Reconnect will be attempted in 20 seconds
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
CONNECT 7200000
--> Starting pppd at Thu Nov 25 18:08:23 2010
--> Pid of pppd: 22599
--> Disconnecting at Thu Nov 25 18:08:24 2010
--> Auto Reconnect will be attempted in 40 seconds
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
CONNECT 7200000
--> Starting pppd at Thu Nov 25 18:09:04 2010
--> Pid of pppd: 22733
--> Disconnecting at Thu Nov 25 18:09:05 2010
--> Auto Reconnect will be attempted in 80 seconds
--> Sending: ATZ
OK
--> Sending: ATE0
OK
OK
^Z
[1]+ Stopped sudo wvdial
So I just killed it. And the logs at /var/log/messages show:
Nov 25 18:07:46 danicast-laptop pppd[22487]: pppd 2.4.5 started by root, uid 0
Nov 25 18:07:46 danicast-laptop pppd[22487]: Using interface ppp0
Nov 25 18:07:46 danicast-laptop pppd[22487]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 25 18:07:46 danicast-laptop pppd[22487]: CHAP authentication succeeded: Welcome!!
Nov 25 18:07:46 danicast-laptop pppd[22487]: Modem hangup
Nov 25 18:07:46 danicast-laptop pppd[22487]: Connection terminated.
Nov 25 18:07:46 danicast-laptop pppd[22487]: Exit.
Nov 25 18:07:51 danicast-laptop pppd[22505]: pppd 2.4.5 started by root, uid 0
Nov 25 18:07:51 danicast-laptop pppd[22505]: Using interface ppp0
Nov 25 18:07:51 danicast-laptop pppd[22505]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 25 18:07:51 danicast-laptop pppd[22505]: CHAP authentication succeeded: Welcome!!
Nov 25 18:07:51 danicast-laptop pppd[22505]: Modem hangup
Nov 25 18:07:51 danicast-laptop pppd[22505]: Connection terminated.
Nov 25 18:07:52 danicast-laptop pppd[22505]: Exit.
Nov 25 18:08:02 danicast-laptop pppd[22538]: pppd 2.4.5 started by root, uid 0
Nov 25 18:08:02 danicast-laptop pppd[22538]: Using interface ppp0
Nov 25 18:08:02 danicast-laptop pppd[22538]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 25 18:08:03 danicast-laptop pppd[22538]: CHAP authentication succeeded: Welcome!!
Nov 25 18:08:03 danicast-laptop pppd[22538]: Modem hangup
Nov 25 18:08:03 danicast-laptop pppd[22538]: Connection terminated.
Nov 25 18:08:03 danicast-laptop pppd[22538]: Exit.
Nov 25 18:08:23 danicast-laptop pppd[22599]: pppd 2.4.5 started by root, uid 0
Nov 25 18:08:23 danicast-laptop pppd[22599]: Using interface ppp0
Nov 25 18:08:23 danicast-laptop pppd[22599]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 25 18:08:24 danicast-laptop pppd[22599]: CHAP authentication succeeded: Welcome!!
Nov 25 18:08:24 danicast-laptop pppd[22599]: Modem hangup
Nov 25 18:08:24 danicast-laptop pppd[22599]: Connection terminated.
Nov 25 18:08:24 danicast-laptop pppd[22599]: Exit.
Nov 25 18:09:04 danicast-laptop pppd[22733]: pppd 2.4.5 started by root, uid 0
Nov 25 18:09:05 danicast-laptop pppd[22733]: Using interface ppp0
Nov 25 18:09:05 danicast-laptop pppd[22733]: Connect: ppp0 <--> /dev/ttyUSB0
Nov 25 18:09:05 danicast-laptop pppd[22733]: CHAP authentication succeeded: Welcome!!
Nov 25 18:09:05 danicast-laptop pppd[22733]: Modem hangup
Nov 25 18:09:05 danicast-laptop pppd[22733]: Connection terminated.
Nov 25 18:09:05 danicast-laptop pppd[22733]: Exit.
I hope that’s good. :o
