Was the stuff I copied what you expected to see then?
Do you think it could be my PC it only has 512mb of RAM could that be an issue. I didn’t want to put it on my friend’s laptop until i was sure it was OK
but maybe this old PC is not up to the job?
It probably downloaded to your Downloads directory … so start your file manager, then enter the Downloads directory … then double-click it … gdebi should start … then click the “Install” button.
once installed, you should find it in the menu’s at:
doug@doug-System-Name ~ $ google-chrome
[0501/145206:ERROR:nacl_helper_linux.cc(236)] NaCl helper process running without a sandbox!
Most likely you need to configure your SUID sandbox correctly
Yeah I’ve read that and it explains the Chrome issue, but now I think the original problem is that the latest flashplayer requires SSE2 to work which I’m pretty sure the AthlonXP doesn’t support, in which case we’ll have to go back to flashplayer 11.1
If you’re asking if flashplayer should work directly from the LiveUSB … erm I’m not 100% sure … I think so, as Peppermint are licensed distributors of the Adobe flashplayer, but I can’t guarantee it.
If your friends PC can boot from a LiveUSB, and you create a LiveUSB with persistence … then even if it’s not included, it should be installable (onto the LiveUSB).
When I get home later I’ll carry out your instructions and let you know how it goes.
Is the fact that when I first boot up the PC I get strings of instructions or code scrolling for several seconds indicative of
this old PC being an issue or could it be the file I put on the disk has got corrupted maybe. It does boot OK after a couple
of times,however?
I need to say sorry again for causing so much trouble. :-[
First of all did Marks instructions get your flashplayer working ?
When you say it boots ok after a couple of attempts does that mean it fails to boot when all this text is scrolling on the screen, does it crash, do you have to switch off and restart.
You do not need to say sorry this is a forum to help people with Linux issues that’s what we’re here for and we enjoy doing it, you have had an unfortunate start to using Linux and it’s not typical one, but stick with and I’m sure Mark will get it sorted out for you
doug@doug-System-Name ~ $ sudo apt-get remove --purge flashplugin-installer google-chrome
[sudo] password for doug:
Reading package lists… Done
Building dependency tree
Note, selecting ‘google-chrome-stable’ instead of ‘google-chrome’
The following packages will be REMOVED
flashplugin-installer*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 139 kB disk space will be freed.
Do you want to continue [Y/n]? y
Unquoted string “pa” may clash with future reserved word at /usr/lib/perl/5.14/Encode/Alias.pm line 1.
Bareword found where operator expected at /usr/lib/perl/5.14/Encode/Alias.pm line 1, near “pa”
Segmentation fault
dpkg: unrecoverable fatal error, aborting:
unable to open files list file for package `linux-firmware’: Input/output error
touch: cannot touch ‘/var/lib/update-notifier/dpkg-run-stamp’: Read-only file system
sh: 1: cannot create /var/lib/update-notifier/updates-available: Read-only file system
E: Problem executing scripts DPkg::Post-Invoke 'if [ -d /var/lib/update-notifier ]; then touch /var/lib/update-notifier/dpkg-run-stamp; fi; if [ -e /var/lib/update-notifier/updates-available ]; then echo > /var/lib/update-notifier/updates-available; fi ’
E: Sub-process returned an error code
E: Sub-process /usr/bin/dpkg returned an error code (2)
doug@doug-System-Name ~ $ mkdir -p ~/.mozilla/plugins
mkdir: cannot create directory ‘/home/doug/.mozilla’: Read-only file system
doug@doug-System-Name ~ $ cd ~/.mozilla/plugins
bash: cd: /home/doug/.mozilla/plugins: No such file or directory
doug@doug-System-Name ~ $ wget https://dl.dropboxusercontent.com/u/11876059/flashplayer-11.1-32bit.tar.gz
–2014-05-02 16:01:44-- https://dl.dropboxusercontent.com/u/11876059/flashplayer-11.1-32bit.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)… 54.235.246.251, 54.243.130.97, 54.243.172.108, …
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|54.235.246.251|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 6455886 (6.2M) [application/octet-stream]
flashplayer-11.1-32bit.tar.gz: Read-only file system
Cannot write to ‘flashplayer-11.1-32bit.tar.gz’ (Success).
doug@doug-System-Name ~ $ tar xvf flashplayer-11.1-32bit.tar.gz
tar: flashplayer-11.1-32bit.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
Not that I understand it but looking at the output of the instructions Mark gave me clearly there is something wrong either with the file I have on the disk
or with the PC I’m using either way I feel I’m wasting your time on what looks like a hopeless case.
Perhaps if I try using the USB flash drive I created with my friends laptop without loading it onto the HDD and see if everything else works OK then maybe
I could add flash player afterwards? I can’t boot up from a flash drive on this ancient artefact I’m using.
In answer to your question after it has scrolled through umpteen pages of text/code/instructions it stops and I have literally to switch it off and re-boot it.
After two or maybe three attempts it finally loads Peppermint OK.
In truth the answer is I don’t know can I check the HDD somehow?
I think the reality is I’m wasting your time and Graeme’s because either the PC is faulty or the file is corrupted either way
it’s clearly more than just a minor fault.
I’ll try using the USB stick in my friend’s laptop over the weekend (probably Sunday) and see what happens. I did include persistence
(is that the correct word?) so if I understand correctly does that mean I can add software to the USB provided it’s less than the
persistence amount I specified at the start? Or maybe I’ve just misunderstand what persistence really means!!!
I’d like to get this up and running as it seems quite good and if I can get it running safely on my friend’s laptop it will save her some money too hopefully.
I’ve just remembered the only problem is her laptop has only 512mb RAM but she’s happy to buy more memory and it seems easy enough to fit, perhaps best to get that first do you think?
Anyway thank you both again I do appreciate all your efforts.
