What do I need to do to get my screensaver running/installed?
I’ve downloaded electricsheep_2.1.orig.tar.gz and xscreensaver-5.14.tar.gz because that’s what it said electricsheep needed… but when I unpacked xscreensaver in emelfm and opened INSTALL, it told me to either put in
./configure
sh ./configure
So when I did that, it gave me
current directory: /tmp/.emelfm-unpack/xscreensaver-5.14both times.
command line was: ./configure
checking build system type… i686-pc-linux-gnuoldld
checking host system type… i686-pc-linux-gnuoldld
checking for gcc… no
checking for cc… no
checking for cl.exe… no
configure: error: in/tmp/.emelfm-unpack/xscreensaver-5.14': configure: error: no acceptable C compiler found in $PATH See
config.log’ for more details.
----end-of-output----
The config.log is as follows:[spoiler]This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.63. Invocation command line was
$ ./configure
Platform.
hostname = box
uname -m = i686
uname -r = 2.4.31
uname -s = Linux
uname -v = #6 SMP Fri Oct 21 15:15:54 EDT 2005
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /sbin
PATH: /bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /usr/X11R6/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/games
PATH: /opt/bin
PATH: .
PATH: .
Core tests.
configure:2461: checking build system type
configure:2479: result: i686-pc-linux-gnuoldld
configure:2501: checking host system type
configure:2516: result: i686-pc-linux-gnuoldld
configure:2587: checking for gcc
configure:2617: result: no
configure:2680: checking for cc
configure:2727: result: no
configure:2783: checking for cl.exe
configure:2813: result: no
configure:2837: error: in /tmp/.emelfm-unpack/xscreensaver-5.14': configure:2840: error: no acceptable C compiler found in $PATH See
Cache variables.
ac_cv_build=i686-pc-linux-gnuoldld
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnuoldld
Output variables.
ALLOCA=‘’
ALL_DEMO_PROGRAMS=‘’
APPDEFAULTS=‘’
CATALOGS=‘’
CATOBJEXT=‘’
CC=‘’
CFLAGS=‘’
CPP=‘’
CPPFLAGS=‘’
DATADIRNAME=‘’
DEFAULT_IMAGES_P=‘’
DEFAULT_IMAGE_DIRECTORY=‘’
DEFAULT_TEXT_FILE=‘’
DEFS=‘’
DEPEND=‘’
DEPEND_DEFINES=‘’
DEPEND_FLAGS=‘’
ECHO_C=‘’
ECHO_N=‘-n’
ECHO_T=‘’
EGREP=‘’
EXEEXT=‘’
EXES_OSX=‘’
GETTEXT_PACKAGE=‘’
GLE_EXES=‘’
GLE_KLUDGE=‘’
GLE_LIBS=‘’
GL_EXES=‘’
GL_KLUDGE=‘’
GL_LIBS=‘’
GL_MEN=‘’
GL_UTIL_EXES=‘’
GMOFILES=‘’
GMSGFMT=‘’
GNOME22=‘’
GNOME24=‘’
GREP=‘’
GTK_DATADIR=‘’
GTK_EXTRA_OBJS=‘’
GTK_LIBS=‘’
HACKDIR=‘’
HACKDIR_FULL=‘’
HACK_CONF_DIR=‘’
HACK_LIBS=‘’
HAVE_PAM_FAIL_DELAY=‘’
INCLUDES=‘’
INSTALL_DATA=‘’
INSTALL_DIRS=‘’
INSTALL_PAM=‘’
INSTALL_PROGRAM=‘’
INSTALL_SCRIPT=‘’
INSTALL_SETUID=‘’
INSTOBJEXT=‘’
INTLDEPS=‘’
INTLLIBS=‘’
INTLOBJS=‘’
INTLTOOL_CAVES_RULE=‘’
INTLTOOL_DESKTOP_RULE=‘’
INTLTOOL_DIRECTORY_RULE=‘’
INTLTOOL_EXTRACT=‘’
INTLTOOL_KEYS_RULE=‘’
INTLTOOL_MERGE=‘’
INTLTOOL_OAF_RULE=‘’
INTLTOOL_PERL=‘’
INTLTOOL_PONG_RULE=‘’
INTLTOOL_SERVER_RULE=‘’
INTLTOOL_SHEET_RULE=‘’
INTLTOOL_SOUNDLIST_RULE=‘’
INTLTOOL_UI_RULE=‘’
INTLTOOL_UPDATE=‘’
INTLTOOL_XML_RULE=‘’
JPEG_EXES=‘’
JPEG_LIBS=‘’
LDFLAGS=‘’
LIBOBJS=‘’
LIBS=‘’
LOCK_OBJS=‘’
LOCK_SRCS=‘’
LTLIBOBJS=‘’
MEN_OSX=‘’
MKINSTALLDIRS=‘’
MOTIF_LIBS=‘’
MSGFMT=‘’
NEED_SETUID=‘’
NEW_LOGIN_COMMAND=‘’
NEW_LOGIN_COMMAND_P=‘’
NOGNOME=‘’
OBJCC=‘’
OBJEXT=‘’
PACKAGE_BUGREPORT=‘’
PACKAGE_NAME=‘’
PACKAGE_STRING=‘’
PACKAGE_TARNAME=‘’
PACKAGE_VERSION=‘’
PASSWD_LIBS=‘’
PASSWD_OBJS=‘’
PASSWD_SRCS=‘’
PATH_SEPARATOR=‘:’
PERL=‘’
POFILES=‘’
POSUB=‘’
PO_DATADIR=‘’
PREFERRED_DEMO_PROGRAM=‘’
PTY_LIBS=‘’
RANLIB=‘’
RETIRED_GL_EXES=‘’
SAVER_GL_LIBS=‘’
SAVER_GL_OBJS=‘’
SAVER_GL_SRCS=‘’
SAVER_LIBS=‘’
SCRIPTS_OSX=‘’
SETUID_HACKS=‘’
SET_MAKE=‘’
SHELL=‘/bin/sh’
SUID_EXES=‘’
USE_NLS=‘’
WITH_BROWSER=‘’
XDPMS_LIBS=‘’
XGETTEXT=‘’
XINERAMA_LIBS=‘’
XMKMF=‘’
XML_LIBS=‘’
XMU_LIBS=‘’
XMU_OBJS=‘’
XMU_SRCS=‘’
XPM_LIBS=‘’
X_CFLAGS=‘’
X_EXTRA_LIBS=‘’
X_LIBS=‘’
X_PRE_LIBS=‘’
ac_ct_CC=‘’
bindir=‘${exec_prefix}/bin’
build=‘i686-pc-linux-gnuoldld’
build_alias=‘’
build_cpu=‘i686’
build_os=‘linux-gnuoldld’
build_vendor=‘pc’
datadir=‘${datarootdir}’
datarootdir=‘${prefix}/share’
docdir=‘${datarootdir}/doc/${PACKAGE}’
dvidir=‘${docdir}’
exec_prefix=‘${prefix}’
gnome_open_program=‘’
gnome_url_show_program=‘’
host=‘i686-pc-linux-gnuoldld’
host_alias=‘’
host_cpu=‘i686’
host_os=‘linux-gnuoldld’
host_vendor=‘pc’
htmldir=‘${docdir}’
includedir=‘${prefix}/include’
infodir=‘${datarootdir}/info’
libdir=‘${exec_prefix}/lib’
libexecdir=‘${exec_prefix}/libexec’
localedir=‘${datarootdir}/locale’
localstatedir=‘${prefix}/var’
login_manager_tmp=‘’
mandir=‘${datarootdir}/man’
oldincludedir=‘/usr/include’
pdfdir=‘${docdir}’
pkg_config=‘’
prefix=‘/usr/local’
program_transform_name=‘s,x,x,’
psdir=‘${docdir}’
sbindir=‘${exec_prefix}/sbin’
sharedstatedir=‘${prefix}/com’
sysconfdir=‘${prefix}/etc’
target_alias=‘’
confdefs.h.
#define PACKAGE_NAME “”
#define PACKAGE_TARNAME “”
#define PACKAGE_VERSION “”
#define PACKAGE_STRING “”
#define PACKAGE_BUGREPORT “”
configure: exit 1[/spoiler]
