My daughter is going frantic because she can’t get onto Facebook ::). It suddenly stopped connecting around 6 this evening, it was fine before.
Laptop is Linux, phones and tablet are android and we normally use Chrome. Have tried on Firefox and that won’t connect either. I’ve done the usual clear history/cache and still nothing. I’ve checked if there’s a problem with the site via a couple of Is it down sites, they say it’s running okay.
So what exactly happens if you try to visit facebook ? … the page doesn’t appear ? … you get a 404 error ? … you can see the page but it won’t accept your login details ?
The page doesn’t open at all Mark. After about 30 seconds of just the little circle going round I get the following:
This web page is not available
ERR_CONNECTION_TIMED_OUT
ReloadHide details
Google Chrome could not load the web page because www.facebook.com took too long to respond. The website may be down or you may be experiencing issues with your Internet connection.
Check your Internet connection
Check any cables and reboot any routers, modems or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a programme that is allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don’t believe you should be using a proxy server: Go to the Chrome menu > Settings > + Show advanced settings > Change proxy settings… and make sure your configuration is set to “no proxy” or “direct.”
ping -c 5 31.13.90.2
PING 31.13.90.2 (31.13.90.2) 56(84) bytes of data.
64 bytes from 31.13.90.2: icmp_req=1 ttl=90 time=20.8 ms
64 bytes from 31.13.90.2: icmp_req=2 ttl=90 time=21.1 ms
64 bytes from 31.13.90.2: icmp_req=3 ttl=90 time=20.6 ms
64 bytes from 31.13.90.2: icmp_req=4 ttl=90 time=20.1 ms
64 bytes from 31.13.90.2: icmp_req=5 ttl=90 time=19.7 ms
— 31.13.90.2 ping statistics —
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 19.786/20.528/21.120/0.513 ms
Nope that’s the very definition of a DNS issue … able to connect via IP but not via domain name means there’s a problem with name resolution
(in the browser it appears that it still attempts to resolve the IP to a domain name and fails)
It’s a wireless connection. Yes the network connections opens, with my Sky connection and a few others. No output from ls /etc/NetworkManager/system-connections.
OK, it’s my guess you’ve set the social media block in Sky Shield.
Normally sites that are blocked would display a page saying they’re being blocked by Sky Shield … but sites that use HTTPS (secure connections) do NOT, they just silently fail.
Try disabling Sky Shield altogether, or unblocking social media.
or move from PG to 13 in the settings (social media is blocked by the PG setting)
