banko
5 June 2014 09:03
1
Hi again
since I started using Linux about 5 years ago, I’ve never been interested in wine because I’ve always found software ran ok in linux or the linux alternative was just as good or in some cases better.
BUT
I was put on to FastStone image viewer (which is free software) and which is miles better than others of the same ilk (picasa etc) and in some ways is easier to use than Gimp but without the layers.
SO
How do I get it to run in wine, bearing in mind I have never used wine.
any help welcomed
forgot to say, running Linux Mint 17 Mate 32 bit
We can give it a shot if you like … but according to the WINE AppDB it doesn’t work very well in WINE:-
Latest version (?):
marked as Bronze … so it will install, but a lot of functions may not work as expected.
All versions:
4.8 is marked as “Silver” … so a few glitches can be expected.
See here for what the Platinum, Gold, Silver, Bronze, and Garbage maintainer ratings mean:
http://appdb.winehq.org/help/?sTopic=maintainer_ratings
Let us know if you still want to have a go
banko
5 June 2014 12:27
3
Hi mark.
thanks for getting back so quick,
I never thought I would use wine, but I’m so taken with this program, I will give it a try,
the silver one looks ok, and I would be grateful if you could walk me through it,
If it does’t work, nothing lost
many thanks
Okey dokey … let’s install wine1.7 (latest) which requires you to add a PPA … open a terminal and run:
sudo apt-get remove --purge wine
that command may fail (if you haven’t already got WINE installed … but just carry on below:
sudo add-apt-repository ppa:ubuntu-wine/ppa
then:
then:
sudo apt-get install wine1.7 winetricks
did that all go well ?
banko
5 June 2014 14:42
5
carried out your instructions, went ok.
wine is showing in the application list,
but if I click on it nothing happens.
is that correct?
If you just try and run the FastStone setup.exe (or whatever the .exe file is called), it should run as normal (hopefully!)
Wine on it’s own doesn’t do anything, you still need to run the Windows executable
banko
6 June 2014 06:58
7
Right - I’m a little confused ;D (not hard I know)
Don’t I have to download FastStone, or does wine pick it up from somewhere.
Embarrassed to say I not sure how to run the .exe
Any help, greatly appreciated
Yeah, just download faststone, and double-click the fastsone.exe to install it … the same as you would in Windows.
banko
6 June 2014 13:21
9
Hi Mark. chemical fan.
Just letting you know, I’ve managed to do it
Its easy when you know how(or have good people who give you there time and help)
AND it’s working perfect so far
So another big THANKS (and I guess, thats another bottle I owe you)
You need to stop saying that … or I may just take you up on it
Happy to hear it’s working
just loaded faststone under wine in fedora 31, cfg wine with windows 10 and it is running flawlessly… (so far)
