Quick question: Is there a simple way to locate packages downloaded from the synaptic package manager?
I downloaded GoogleEarth and managed to run it from a terminal and then later worked out how to create a launcher… all good.
But I’ve just downloaded a program (via synaptic) called Cipher but can’t find a way to run it. I can find it in usr bin, but that’s as far as I can get. Is this a problem with the Cipher program or am I doing something wrong.
This will show you all the files installed from the binary package. Not familiar with this app, but am sure the exec file will be found in /usr/bin or /bin (maybe /sbin but not likely)
