It still won’t work I sent it from my web based mail the server recived it but not thunderbird I’ve posted to flicker again with the settings I tried port 993, 995 and 110
From what I know, Virgin Media only support retrieval of mail, on Windows OS Mail clients. I don’t understand why, but I’m pretty sure the POP3, & SMTP settings are these.
My outgoing server (SMTP) requires authentication: enabled
Use same settings as my incoming mail server: enabled
Incoming server (POP3): 995
This server requires a secure connection (SSL) enabled
Outgoing server (SMTP): 465 or 25
Server Timeouts (Greater than 1 minute, 5 is recommend)
I hope this somewhat helps. I really couldn’t make out what the other issues were, to me it was like you opened one of two Mozilla Apps, from which you had pressed “Get Help Online” and somewhere between that, it made a command of somewhat to a terminal which would open with an error message. :o Like I said it’s hard to make out what your problem is. You need to be more specific, and no offence, but help us help you, be clearer with the english :-\
A Global account, is an account with 2 or more email addresses, from which, if you press “Get Mail” thunderbird will retrieve mail from all accounts, not just a single account.
thank you I now have email the blank terminal still comes up but dosen’t appear to affect anything, it was a mix of global and the arrow I didn’t relise because it was in advanced
