And I’m not talking about the Police … (if that reference doesn’t make sense you’re under 40 so just ignore it … )
I’ve been trying to track down a problem with my home LAN for the last few weeks … it’s a little intermittent and I’ve had different results with different routers. Essentially the network works Ok, but then at certain times (generally late at night) connectivity becomes erratic. Moreover, connectivity “to my local router” becomes erratic. i.e. I can see other machines on my network but not the router. Switching to an identical but new router doesn’t solve the problem, but switching to a different make of router does, although the alternate make isn’t a good solution for me.
After a little while I twig that something else on the network is “sometimes” using the same IP address of the router. Impossible obviously, I wouldn’t be so stupid as to have another device with the router’s IP (!)
Nevertheless, arp -na when I can ping the router shows one MAC address, and arp -na when I can’t ping the router shows another.
Something is on my network!
So, I switch off all other devices one by one. They’re all off.
Something is still on my network.
I look at what’s left … I have a “homeplug device” (ethernet over mains) plugged in, but the PC on the other end is turned off. I unplug it.
Network back to normal.
Deduction :: the homeplug was picking up an IP address from outside the building which happened to be the same IP address as my router … I would have to guess from a neighbor … although given it must be bleed through beyond my fuse box and meter, it “could” be from almost anywhere in the local area. Why does the new router not fix the problem, obvious, same default address (192.168.1.254). Why does the alternative make fix the problem, different default IP, 192.168.1.253.
The implications of this are mind-boggling. Lots of people use homeplug devices, partly because they’re so easy to use. One of the reasons they’re so easy to use is that they are plug and go, no security, they rely on the local mains partitioning to separate out properties so the homeplug can’t talk outside the property. This feature clearly doesn’t work, we’re back to the good’ol days when nobody used any security on their WiFi !!
Anyone out there using homeplug devices? Beware, you might find your neighbor is reading your mail!
