I have loaded a few programmes into the Sound and Video folder in my search for a programme to download the .mp4 files from my Toshiba Camileo video camera.
Some of these programmes do not do what I want, so what is the best way to remove them ?
I have a large HD but I don’t like having unused/useless programmes on my system.
Don W
EDIT I have used the Package Manager to locate and remove some unwanted files.
If you’ve removed the main applications through the package manager, it would probably be a good idea to now run:
apt autoremove
and let it remove any orphaned dependencies
Thanks Mark,
I used the package manager and removed the programmes I didn’t want.
I have just used apt -autoremove.
Will I need to shut down and restart to confirm that the programmes are removed, as I still see icons in the menu for programmes I have deleted.
Don W
no
There are a num ber of ways to check if someting is installed or not
Personally I search the dpkg listing … lets say I want to check the status of gedit:
dpkg -l | grep gedit
if the output begins with
ii - it’s installed
rc - it’s been removed, but the config files are still present
nothing returned - it’s not installed
another way would be to see if the box is green in in Synaptic
If you have any applications which are obviously not installed, but are still showing in the menu they’ve probably copied a .desktop launcher to
~/.local/share/applications
removing that will remove it from the menu
If unsure what to do, post the output from:
ls -a ~/.local/share/applications
and mention which apps are in the menu yet not installed.
watson ~ $ ls -a ~/.local/share/applications
. ddchess.desktop entanglement.desktop gmail.desktop mahjong.desktop solitr.desktop
… display.im6.desktop expressbypixlr.desktop googlecalendar.desktop onlineuserguide.desktop
audacity.desktop editorbypixlr.desktop firstpersontetris.desktop googledrive.desktop peppermintforum.desktop
don@ldwatson ~ $
audacity I removed this morning but still shows an icon in Sound and Video menu
Don W
EDIT I also deleted ImageMagick and it is still on the Graphics folder and still works
Remove the superfluous launchers … by runnng:
rm -v ~/.local/share/applications/audacity.desktop
rm -v ~/.local/share/applications/display.im6.desktop
they should now be gone from the menu.
Thanks Mark,
I have done that and all is well
Don W
