How Install .rpm from different location
Hi all,
I am new in Linux. I have installed Red Hat 5 in VMWARE.
How can I install .rpm in Linux Red Hat version 5 which path is [nauvm@localhost linuxpackage]# and also by USB. Means If I have .rpm into the linuxpackage folder that is situated in Linux home then how I can fire the following command. e.g:
rpm -Uvh libXp-1*
How Can I install oracle software (i.e: 10201_database_linux_x86_64.cpio.gz) from the above path and also by DVD. Means If I have Oracle software into the OraSoft folder that is situated in Desktop then how I can fire the following command. e.g
gunzip 10201_database_linux_x86_64.cpio.gz
cpio -idmv <10201_database_linux_x86_64.cpio
Thanks
Easiest way … change directory (cd) to where the .rpm is located first … THEN run your command … so either:
cd ~/linuxpackage
or the FULL path:
cd /home/<username>/linuxpackage
THEN run your command:
rpm -Uvh libXp-1*
Same thing for the other path:
cd ~/Desktop/OraSoft
or FULL path:
cd /home/<username>/Desktop/OraSoft
Now the system is in the correct folder … run the command.
another way would be to pass the path to the rpm command, as in -
rpm -Uvh ~/linuxpackage/libXp-1*
or with the FULL path:
rpm -Uvh /home/<username>/linuxpackage/libXp-1*
