Hi
I get the error “/usr/include/c++/5/cstddef:51:11: error: ‘::max_align_t’ has not been declared
using ::max_align_t;
So I should update the libraries because I find this solution: “A workaround until libraries get updated is to include or <stddef.h> before any headers from that library.”
I wrote some command on the Ubuntu terminal such as:
“sudo apt-get install apt-file
sudo apt-file update
apt-file search stddef.h”
Then still the error exist.
Thank you
What are you trying to do when you get that error ?
Make, I wrote “make” in the terminal.
To make what exactly…
You’re not giving anywhere near enough information …
What are you trying to compile ?
Where did you get the source code ?
Which distro / version / architecture (eg. Ubuntu 14.04 64bit) ?
before writing make I wrote “cd”, exactly “cd gen” that gen is folder include c++ codes.
What are you trying to compile?
yes
Where did you get the source code?
I get the source code on a personal page, do you need it?
Which distro/ version/ architecture?
ubuntu-15.10-desktop or server-i386 64bit
fixed the error by adding “includes cstddef>” at the first line of some pages of codes, but now the newer error "narrowing conversion of long long int to long unsigned int inside {} [-Wnarrowing]
the source code relative to it:
// Implements the joint conditional cummulative density functions for CP-nets
// For node j in the lexicographic topological sort as defined by the dag code:
// the table gives P( s, t | n, c, j ).
// The number of rows in each table is the triangular number of min(c, j).
#ifndef TABLES_H
#define TABLES_H
#include <random> // Mersenne Twister
#include <chrono> // Used to initialize MT
const unsigned long int factorial[17] = {1, 1, 2, 6, 24, 120, 720, 5040, 40320, 362880, 3628800, 39916800, 479001600, 6227020800, 87178291200, 1307674368000, 20922789888000};
void random_outcome_pair(uint64_t& o, uint64_t& oo, const unsigned int n, const unsigned int hd = 0);
uint64_t random_k_subset(uint64_t T, const int N, const int n);
class cpnet_ccdf
public:
cpnet_ccdf(const int length);
cpnet_ccdf(cpnet_ccdf &obj);
~cpnet_ccdf();
int length() { return length_; };
void store(double p, const int s, const int t) { P[row_] = p; S[row_] = s; T[row_] = t; ++row_; };
void adjust_last() { P[length_ - 1] = 1.0; };
void print();
friend std::ostream& operator<<(std::ostream& os, const cpnet_ccdf& obj);
friend std::istream& operator>>(std::istream& is, cpnet_ccdf& obj); // test
void random_st(int& s, int& t);
// static uint64_t random_cpt(const int k); // use rand_cpt in degen_multi.cc
void random_node(const int n, int& q, uint64_t& U, uint64_t& A, unsigned long int** cpt, int j);
// void random_node(const int n, int& q, uint64_t& U, uint64_t& A, uint64_t& cpt);
// void random_toporder_node(const int n, const int j, int& q, uint64_t& U, uint64_t& A, uint64_t& cpt);
private:
int length_;
int row_;
double *P;
int *S;
int *T;
// all tables for all available values of (n, c, j, q) go here
class cpnet_dist
public:
cpnet_dist(int maxn, int maxk);
~cpnet_dist();
cpnet_ccdf* dist(int n, int c, int j, int q) { return DIST[n][c][j][q]; };
void init(int n, int c, int j, int q, int len);
void print();
void dump();
void dump(std::string fname);
static void dagcode_to_dag(const unsigned int n, const uint64_t dc[], unsigned int ch_ix[], char ch[], unsigned long imp[]);
static void dc_and_cpts_to_xml(const unsigned int n, const uint64_t dc[], unsigned long int** cpts, std::string working_directory, std::string fname);
void free_cpt(const int n, long unsigned int** cpt);
void generate_random_cpnet(const int n, const int c, uint64_t dc[], long unsigned int* cpt[]);
// void random_toporder_cpnet(const int n, const int c, uint64_t dc[], uint64_t cpt[]);
private:
const int MAX_N;
const int MAX_K;
cpnet_ccdf***** DIST = nullptr;
bool degen_multi( unsigned int m, // number of inputs (indegree)
unsigned int nAsst, // number of rows
unsigned int* C ); // array of outputs defining function
void rand_cpt( unsigned long int cpt[], // Return value
const int k, // Number of parents
const long unsigned int size_cpt ); // Number of rows = d^k
void print_cpt( const unsigned long int cpt[], // CPT to output
const unsigned long int size_cpt ); // Number of rows = d^k
#endif // TABLES_H
I think error got from
It would probably help.
this error solved, I asked about the new fatal_error.
