I have a programme that has stopped working properly. I spoke to their technical support and they advised to uninstall and reinstall as a first step.
I have found the programme in the menu but if I right click on it there is no option to uninstall. How do I go about this?
Thanks in advance
There are various way to uninstall in Linux
via the terminal
sudo apt-get remove <program name>
if you want to remove any configuration files associated with the program (complete removal)
sudo apt-get remove --purge <program name>
or you can go into synaptic package manager find the program right click and you will see an option to un-install there
Good luck
graeme
There should also be an option to uninstall it in the Mint Software Manager.
It may help if you mentioned the applications name
… then we could give a command sequence to uninstall/reinstall.
It’s one I installed a couple of weeks ago, FamilySearch Indexing. It’s a genealogy programme.
You say that as though we should know about your installing it ?
Did you get it from here:
https://www.familysearch.org/volunteer/indexing
(as a file called Indexing_unix_3_17_7.sh)
If so …
Open a terminal and run:
sudo updatedb
then post the output from:
locate indexing.vmoptions
locate iude-launcher.properties
“You say that as though we should know about your installing it ?”
Sorry I didn’t realise you wanted the whole caboodle, I read it as you wanted to know what it was called.
Yes that is th .sh file I installed?
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Antarctica/Rothera
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Antarctica/Syowa
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Antarctica/Vostok
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Aden
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Almaty
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Amman
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Anadyr
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Aqtau
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Aqtobe
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Ashgabat
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Baghdad
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Bahrain
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Baku
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Bangkok
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Beirut
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Bishkek
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Brunei
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Choibalsan
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Chongqing
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Colombo
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Damascus
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Dhaka
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Dili
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Dubai
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Dushanbe
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Gaza
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Harbin
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Ho_Chi_Minh
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Hong_Kong
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Hovd
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Irkutsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Jakarta
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Jayapura
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Jerusalem
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kabul
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kamchatka
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Karachi
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kashgar
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kathmandu
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kolkata
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Krasnoyarsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kuala_Lumpur
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kuching
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Kuwait
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Macau
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Magadan
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Makassar
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Manila
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Muscat
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Nicosia
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Novokuznetsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Novosibirsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Omsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Oral
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Phnom_Penh
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Pontianak
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Pyongyang
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Qatar
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Qyzylorda
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Rangoon
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Riyadh
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Riyadh87
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Riyadh88
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Riyadh89
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Sakhalin
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Samarkand
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Seoul
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Shanghai
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Singapore
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Taipei
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Tashkent
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Tbilisi
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Tehran
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Thimphu
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Tokyo
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Ulaanbaatar
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Urumqi
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Vientiane
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Vladivostok
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Yakutsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Yekaterinburg
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Asia/Yerevan
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Azores
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Bermuda
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Canary
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Cape_Verde
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Faroe
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Madeira
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Reykjavik
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/South_Georgia
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/St_Helena
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Atlantic/Stanley
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Adelaide
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Brisbane
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Broken_Hill
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Currie
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Darwin
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Eucla
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Hobart
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Lindeman
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Lord_Howe
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Melbourne
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Perth
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Australia/Sydney
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+1
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+10
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+11
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+12
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+2
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+3
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+4
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+5
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+6
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+7
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+8
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT+9
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-1
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-10
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-11
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-12
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-13
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-14
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-2
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-3
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-4
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-5
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-6
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-7
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-8
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/GMT-9
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/UCT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Etc/UTC
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Amsterdam
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Andorra
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Athens
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Belgrade
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Berlin
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Brussels
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Bucharest
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Budapest
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Chisinau
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Copenhagen
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Dublin
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Gibraltar
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Helsinki
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Istanbul
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Kaliningrad
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Kiev
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Lisbon
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/London
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Luxembourg
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Madrid
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Malta
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Minsk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Monaco
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Moscow
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Oslo
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Paris
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Prague
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Riga
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Rome
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Samara
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Simferopol
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Sofia
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Stockholm
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Tallinn
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Tirane
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Uzhgorod
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Vaduz
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Vienna
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Vilnius
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Volgograd
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Warsaw
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Zaporozhye
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Europe/Zurich
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Antananarivo
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Chagos
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Christmas
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Cocos
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Comoro
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Kerguelen
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Mahe
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Maldives
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Mauritius
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Mayotte
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Indian/Reunion
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Apia
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Auckland
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Chatham
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Easter
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Efate
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Enderbury
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Fakaofo
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Fiji
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Funafuti
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Galapagos
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Gambier
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Guadalcanal
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Guam
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Honolulu
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Johnston
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Kiritimati
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Kosrae
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Kwajalein
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Majuro
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Marquesas
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Midway
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Nauru
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Niue
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Norfolk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Noumea
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Pago_Pago
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Palau
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Pitcairn
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Ponape
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Port_Moresby
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Rarotonga
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Saipan
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Tahiti
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Tarawa
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Tongatapu
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Truk
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Wake
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/Pacific/Wallis
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/AST4
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/AST4ADT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/CST6
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/CST6CDT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/EST5
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/EST5EDT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/HST10
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/MST7
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/MST7MDT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/PST8
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/PST8PDT
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/YST9
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/jre/lib/zi/SystemV/YST9YDT
/home/tanya/.icedtea/cache/10/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/10/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/10/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/10/http/indexing.familysearch.org/iis-apps/apps/indexing.jnlp.info
/home/tanya/.icedtea/cache/10/http/indexing.familysearch.org/iis-apps/apps/iude.jnlp.info
/home/tanya/.icedtea/cache/11/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/11/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/11/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/11/http/indexing.familysearch.org/iis-apps/apps/iude-launcher34-java5.jnlp.info
/home/tanya/.icedtea/cache/12/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/12/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/12/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/12/http/indexing.familysearch.org/iis-apps/apps/iude-launcher-java5.jnlp.info
/home/tanya/.icedtea/cache/13/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/13/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/13/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/13/http/indexing.familysearch.org/iis-apps/apps/iude-launcher34-java5.jnlp.info
/home/tanya/.icedtea/cache/3/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/3/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/3/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/3/http/indexing.familysearch.org/iis-apps/apps/indexing1.jnlp.info
/home/tanya/.icedtea/cache/4/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/4/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/4/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/4/http/indexing.familysearch.org/iis-apps/apps/iude-launcher.jnlp.info
/home/tanya/.icedtea/cache/5/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/5/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/5/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/5/http/indexing.familysearch.org/iis-apps/apps/iude-launcher34.jnlp.info
/home/tanya/.icedtea/cache/6/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/6/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/6/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/6/http/indexing.familysearch.org/iis-apps/apps/iude.jnlp.info
/home/tanya/.icedtea/cache/7/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/7/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/7/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/7/http/indexing.familysearch.org/iis-apps/apps/iude-launcher-uninstall.jnlp.info
/home/tanya/.icedtea/cache/8/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/8/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/8/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/8/http/indexing.familysearch.org/iis-apps/apps/iude-launcher36.jnlp.info
/home/tanya/.icedtea/cache/9/http/indexing.familysearch.org
/home/tanya/.icedtea/cache/9/http/indexing.familysearch.org/iis-apps
/home/tanya/.icedtea/cache/9/http/indexing.familysearch.org/iis-apps/apps
/home/tanya/.icedtea/cache/9/http/indexing.familysearch.org/iis-apps/apps/iude-launcher-java5.jnlp.info
/usr/share/freemat/help/html/variables_indexing.html
/usr/share/freemat/help/text/indexing.mdc
/usr/share/freemat/toolbox/test/bbtest_indexing.m
tanya@VGN-NS30E-S ~ $ locate iude-launcher.properties
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/iude-launcher.properties
OK, try running:
/home/tanya/.FamilySearchIndexing/indexing.familysearch.org/uninstall
if that works, but says there were a few things it couldn’t uninstall … then run:
rm -rv /home/tanya/.FamilySearchIndexing
On the first command I get - /home/tanya/.FamilySearchIndexing/uninstall
bash: /home/tanya/.FamilySearchIndexing/uninstall: No such file or directory
Oops I missed a bit … the first command should read:
Also fixed in last my posting.
Tanya
10
Had to use both commands but it’s now uninstalled completely.
Thank you.
