Perhaps I am doing something stupid but when I run system config-printer it gives the reply no command ‘system’ found
Degsy
Degsy
Sorry … typo … should read:
system-config-printer
Fixed above too.
T hanks Mark,
This shows No devices found - I mean the hp-setup command.
is there an option to browse for the printer ?
Sorry about the delay, Saturday was a busy day, lots to do. Anyway, there was no "browse2 option but tried the manual option and after setting the IP address the Printer was found and so I can now print again.
I would appreciate your advice now on how to get the Scan option working, tried again from the Printer Control Panel but that just said “No Computer Found”.
Cheers,
Degsy
Now used Xsane and this works fine, thanks very much Mark for your help previously, will be back with further questions as they crop up.
Degsy
Ideal …
(and NO, that’s not some kind of new electronic croupier from Apple)
