My choice would be Peppermint 4 any KDE based distro may be a bit on the heavy side for that spec, I’ve recently installed Peppermint 4 on a netbook with similar spec and it flies
but the only way to tell for sure would be to either give us the full model number so we can check the spec/hardware … or even better, create a LiveUSB stick, boot to it, and post the output from:
Just try and boot a live USB - if it working (including wireless networking), 3D works, you’re golden.
Bummer that she’s used to KDE, as it’s not a good plan on a netbook. THAT said, there is a Plasma Netbook KDE desktop, which doesn’t run badly. Worth testing out!!
Mark’s probably got the instructions set up on a copy-paste, so we’ll wait for them…
Meanwhile, I’ve run Unity fairly happily on a equal spec netbook, but it really flew on Xfce, so I’d lean more towards Peppermint on that (LXDE-based, so even lighter). Mint MATE should be ok, but I’d still lean towards Peppermint
Yeah, Peppermint or one of the other light distros … take it from me, Mint/Ubuntu on an N270 and 1GB of RAM will feel slow by comparison, they’ll run but they won’t compliment the hardware, more they’ll highlight its shortcomings.
The Wireless will probably need tweaking as it’ll need the lpphy firmware installing … but as long as you can attach temporarily with an ethernet cable, that’s an easy fix.
I assume I just download the latest Peppermint and burn the iso as per usual - (this will have to be to a usb stick btw, no optical drive) so are there any particular issues to watch out for? Best method etc? And yes Mark, there is a connection for an ethernet cable.
Also, is Peppermint a ‘fork’ of Mint (a Mint lite, as it were), or is the name just a coincidence?
in fact you can follow that tutorial EXCEPT for stages 8, 9, 10, and 11 (which are specific to the AA1 netbook)
Also, is Peppermint a 'fork' of Mint (a Mint lite, as it were), or is the name just a coincidence?
Mint is a derivative of Ubuntu
Lubuntu is Ubuntu with the LXDE desktop environment
Peppermint is a derivative of Ubuntu/Lubuntu … but it also uses some of the Mint software, such as the software Manager.
Peppermint was started by the guy who used to build the Mint LXDE version.
Peppermint unlike Lubuntu doesn’t strictly stick to the LXDE environment … we cherry pick a bit, as in we use the Xfwm4 window manager from Xfce, bits from Mint, bits from Gnome, and bits of our own.
The story goes that the name was chosen as Kendall (who did the Mint LXDE version) and Shane saw it as a “spicier” Mint LXDE
What app did you use to create the Peppermint LiveUSB ?
What app did you use to create the Mint LiveUSB ?
My mistake I’d chopped the 1 off the end of the MD5 … it’s fixed above now.
This is a problem with the bootloader as added by the USB creator application … not the ISO image … have you tried formatting the USB stick before using the USB creator software ?
you could also try a different LiveUSB creator application.
such as this one for Windows:
or even just try the same one again … sometimes the LiveUSB creators can be a bit funny.
Is this a different USB stick to the Mint one ? … I know the Acer Aspire One doesn’t like certain USB sticks.
Ok! Peppermint now up and running on the mini with extras installed, no problem!
Very impressed so far with speed and stability. One issue, the wireless card is not recognised (ref: Chemicalfan and Broadcom), wired connection works flawlessly.
@Mark - you mentioned something about installing ‘lpphy firmware’ and it’s an easy fix?
Had a thought Mark - is it worth rolling that firmware into the default install? Would save a bunch of troubleshooting for newcomers, and wouldn’t add too much bloat.
Kinda thinking ahead to Peppermint 5 (the BIG one for people jumping ship from XP, imo)
It used to be you couldn’t have the lpphy firmware and the standard firmware installed at the same time … I’m pretty sure it all comes as a single package now … though I don’t know if it’s installed in Ubuntu/Lubuntu by default now or not.
The firmware used to be considered proprietary so couldn’t be rolled into the ISO image … but “Additional Hardware” (jockey) would detect a b43 adapter and offer you the drivers … problem WAS that it always seemed to download the non-lpphy firmware so lpphy cards wouldn’t work (the 2 packages USED to conflict) … I gather since 13.10 thats fixed now and ALL the firmware now comes as a single package, so I guess “Additional Drivers” will sort it for you.
I also know Broadcom were open sourcing some of their drivers … but I’m pretty sure these weren’t included, so they’re highly unlikely to be rolled into the ISO … “Additional Drivers” makes it easy though (as long as your wired connection works).
So it was a licensing issue? That’s kinda crappy, considering it’s the first thing a user is going to want to do. Pretty sure that Mint comes with the Nvidia drivers on the ISO, and I’d assumed that Broadcom could do the same?
Anyway, if it’s fixed in future, I guess my solution has already been implemented
