Heres the report.
[spoiler]hp-check[2273]: info: :
Initializing. Please wait…
Ubuntu
11.10
scheduler is running
1.5.0
Linux Petes-ubuntu-pc 3.0.0-12-generic #20-Ubuntu SMP Fri Oct 7 14:56:25 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
hp-check[2273]: info: :---------------
hp-check[2273]: info: SYSTEM INFO |
hp-check[2273]: info: :[01mBasic system information:[0m
hp-check[2273]: info: :Linux Petes-ubuntu-pc 3.0.0-12-generic #20-Ubuntu SMP Fri Oct 7 14:56:25 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
hp-check[2273]: info: :[01mDistribution:[0m
hp-check[2273]: info: :ubuntu 11.10
hp-check[2273]: info: :[01mChecking Python version…[0m
hp-check[2273]: info: :OK, version 2.7.2 installed
hp-check[2273]: info: :[01mChecking PyQt 4.x version…[0m
hp-check[2273]: info: :OK, version 4.8.5 installed.
hp-check[2273]: info: :[01mChecking for CUPS…[0m
hp-check[2273]: info: :Status: scheduler is running
hp-check[2273]: info: :Version: 1.5.0
hp-check[2273]: info: :error_log is set to level: warn
hp-check[2273]: info: :[01mChecking for dbus/python-dbus…[0m
hp-check[2273]: info: :dbus daemon is running.
hp-check[2273]: info: :python-dbus version: 0.84.0
hp-check[2273]: info: :------------------------------------
hp-check[2273]: info: COMPILE AND RUNTIME DEPENDENCIES |
note: To check for compile-time only dependencies, re-run hp-check with the -c parameter (ie, hp-check -c).
note: To check for run-time only dependencies, re-run hp-check with the -r parameter (ie, hp-check -r).
hp-check[2273]: info: :[01mChecking for dependency: CUPS - Common Unix Printing System…[0m
hp-check[2273]: info: :OK, found.
hp-check[2273]: info: :[01mChecking for dependency: CUPS devel- Common Unix Printing System development files…[0m
hp-check[2273]: info: :[01mChecking for dependency: CUPS image - CUPS image development files…[0m
hp-check[2273]: info: :[01mChecking for dependency: DBus - Message bus system…[0m
hp-check[2273]: info: :[01mChecking for dependency: gcc - GNU Project C and C++ Compiler…[0m
hp-check[2273]: info: :[01mChecking for dependency: GhostScript - PostScript and PDF language interpreter and previewer…[0m
hp-check[2273]: info: :[01mChecking for dependency: libcrypto - OpenSSL cryptographic library…[0m
hp-check[2273]: info: :[01mChecking for dependency: libjpeg - JPEG library…[0m
hp-check[2273]: info: :[01mChecking for dependency: libnetsnmp-devel - SNMP networking library development files…[0m
hp-check[2273]: info: :[01mChecking for dependency: libpthread - POSIX threads library…[0m
hp-check[2273]: info: :[01mChecking for dependency: libtool - Library building support services…[0m
hp-check[2273]: info: :[01mChecking for dependency: libusb - USB library…[0m
hp-check[2273]: info: :[01mChecking for dependency: make - GNU make utility to maintain groups of programs…[0m
hp-check[2273]: info: :[01mChecking for dependency: PIL - Python Imaging Library (required for commandline scanning with hp-scan)…[0m
hp-check[2273]: info: :[01mChecking for dependency: PolicyKit - Administrative policy framework…[0m
hp-check[2273]: info: :[01mChecking for dependency: PyQt 4 DBus - DBus Support for PyQt4…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python DBus - Python bindings for DBus…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python devel - Python development files…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python libnotify - Python bindings for the libnotify Desktop notifications…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python XML libraries…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python 2.3 or greater - Required for fax functionality…[0m
hp-check[2273]: info: :[01mChecking for dependency: Python 2.2 or greater - Python programming language…[0m
hp-check[2273]: info: :[01mChecking for dependency: Reportlab - PDF library for Python…[0m
hp-check[2273]: info: :[01mChecking for dependency: SANE - Scanning library…[0m
hp-check[2273]: info: :[01mChecking for dependency: SANE - Scanning library development files…[0m
hp-check[2273]: info: :[01mChecking for dependency: scanimage - Shell scanning program…[0m
hp-check[2273]: info: :[01mChecking for dependency: xsane - Graphical scanner frontend for SANE…[0m
hp-check[2273]: info: HPLIP INSTALLATION |
hp-check[2273]: info: :[01mCurrently installed HPLIP version…[0m
hp-check[2273]: info: :HPLIP 3.11.10 currently installed in ‘/usr/share/hplip’.
hp-check[2273]: info: :[01mCurrent contents of ‘/etc/hp/hplip.conf’ file:[0m
hp-check[2273]: info: :# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.11.10
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-3.11.10
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp
Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
pp-build=no
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=no
foomatic-drv-install=no
foomatic-ppd-install=no
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.11.10
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=no
hpijs-only-build=no
lite-build=no
udev-acl-rules=yes
hpcups-only-build=no
hpijs-only-build=no
hp-check[2273]: info: :[01mCurrent contents of ‘/var/lib/hp/hplip.state’ file:[0m
hp-check[2273]: info: :# hplip.state - HPLIP runtime persistent variables.
[plugin]
installed=0
eula=0
hp-check[2273]: info: :[01mCurrent contents of ‘~/.hplip/hplip.conf’ file:[0m
hp-check[2273]: info: :[settings]
systray_visible = 0
systray_messages = 0
[last_used]
device_uri = “hp:/usb/Photosmart_320_series?serial=CN51I210T304BG”
printer_name =
working_dir = .
[commands]
scan = /usr/bin/simple-scan %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[installation]
date_time = 30/10/11 17:32:25
version = 3.11.10
hp-check[2273]: info: INSTALLED CUPS PRINTER QUEUES |
hp-check[2273]: info: :[01mDeskjet_3070_B611[0m
hp-check[2273]: info: :[01m-----------------[0m
hp-check[2273]: info: :Type: Printer
hp-check[2273]: info: :Device URI: hp:/usb/Deskjet_3070_B611_series?serial=CN17E3704305MQ
hp-check[2273]: info: :PPD: /etc/cups/ppd/Deskjet_3070_B611.ppd
hp-check[2273]: info: :PPD Description: HP Deskjet 3070 b611 Series, hpcups 3.11.10
hp-check[2273]: info: :Printer status: printer Deskjet_3070_B611 is idle. enabled since Sun 30 Oct 2011 01:40:08 BST
hp-check[2273]: info: :[01mPhotosmart-320-series[0m
hp-check[2273]: info: :[01m---------------------[0m
hp-check[2273]: info: :Device URI: hp:/usb/Photosmart_320_series?serial=CN51I210T304BG
hp-check[2273]: info: :PPD: /etc/cups/ppd/Photosmart-320-series.ppd
hp-check[2273]: info: :PPD Description: HP Photosmart 320 Series, hpcups 3.11.7
hp-check[2273]: info: :Printer status: printer Photosmart-320-series disabled since Fri 28 Oct 2011 19:33:26 BST -
reason unknown
hp-check[2273]: info: :[01mPhotosmart-D5400-series[0m
hp-check[2273]: info: :[01m-----------------------[0m
hp-check[2273]: info: :Device URI: hp:/usb/Photosmart_D5400_series?serial=MY88P791BM04V3
hp-check[2273]: info: :PPD: /etc/cups/ppd/Photosmart-D5400-series.ppd
hp-check[2273]: info: :PPD Description: HP Photosmart d5400 Series, hpcups 3.11.7
hp-check[2273]: info: :Printer status: printer Photosmart-D5400-series is idle. enabled since Sat 29 Oct 2011 18:29:18 BST
hp-check[2273]: info: SANE CONFIGURATION |
hp-check[2273]: info: :[01m’hpaio’ in ‘/etc/sane.d/dll.conf’…[0m
hp-check[2273]: info: :OK, found. SANE backend ‘hpaio’ is properly set up.
hp-check[2273]: info: :[01mChecking output of ‘scanimage -L’…[0m
hp-check[2273]: info: PYTHON EXTENSIONS |
hp-check[2273]: info: :[01mChecking ‘cupsext’ CUPS extension…[0m
hp-check[2273]: info: :[01mChecking ‘pcardext’ Photocard extension…[0m
hp-check[2273]: info: :[01mChecking ‘hpmudext’ I/O extension…[0m
error: NOT FOUND OR FAILED TO LOAD! Please reinstall HPLIP and check for the proper installation of hpmudext.
hp-check[2273]: info: :[01mChecking ‘scanext’ SANE scanning extension…[0m
hp-check[2273]: info: USER GROUPS |
hp-check[2273]: info: :peter adm lp dialout cdrom plugdev lpadmin admin sambashare
hp-check[2273]: info: :[32;01mUser member of group ‘lp’. Enables print/ scan/ fax.[0m
hp-check[2273]: info: :[32;01mUser member of group ‘lpadmin’.[0m
hp-check[2273]: info: SUMMARY |
error: 1 error or warning.
hp-check[2273]: info: :Please refer to the installation instructions at:
hp-check[2273]: info: :http://hplip.sourceforge.net/install/index.html
hp-check[2273]: info: :Done.[/spoiler]
