HP Printer Drivers
Can any one point me in the right direction to find Printer Drivers for HP Deskjet 1220c. I’m new to Linux but having made the jump I want every thing to work on it printers scanners. Hope some one can help out Cheers :slight_smile:
Your printer is supported by the hplip drivers which are installed by default in most Linux distros, so your printer should “just work”… if it doesn’t, can you let us know which Linux distribution you are using (eg, Ubuntu, Fedora, openSUSE, etc.).
http://hplipopensource.com/hplip-web/models/deskjet/deskjet_1220c.html
BTW, do NOT download the drivers from the above link… if they were not installed by default, they WILL be available in your distributions software repositories, and should be installed from there… just tell us which distro you are using, and we’ll tell you how :slight_smile:
I have this issue with the printer and the scanner not being installed at the same time. I have the printer installed and not the scanner due to error something… I have this gimp and i dont know, when I print one, the page is blank… i have refilled ink cartridge and all… :frowning:
Which printer/scanner ? … and which Linux distro/version ?
What have you already tried ?
and what was the error message you mentioned ?
