installing fonts
Hi,
I have found a font I want to use in Inkscape on my Linux machine.
I think you can install the font to Peppermint 6 and it is then usable by any programme on the computer.
How do I install fonts ?
Probably not the best way, but I have always just created my own directory in /usr/share/fonts/truetype then dropped the font files into that.
They are available system wide. :slight_smile:
Thanks SeZo,
I will go and see what havoc I can spread with that :wink:
As I suspected, I can’t install that font. I will try the Inkscape forum, thanks SeZo.
Easiest system wide method (for Peppermint, and any other Ubuntu based distro … though obviously the file manager command may need adjusting)
run:
gksudo nemo /usr/share/fonts
in the resulting window if there isn’t already a truetype directory, create one … then enter it.
copy your font into that folder
Okay that’s the font in the right place, you now just have to make the system aware of it … so open a terminal and run:
sudo fc-cache -fv
the font should now be available to all apps … except ones that were already open which will need to be closed/reopened
The other option (user specific) is to put the font in the hidden .fonts folder in your home folder (if it doesn’t exist, create it) … and then run:
sudo fc-cache -fv
As long as the font is in either
~/.fonts
/usr/share/fonts
or a subdirectory of those two directories
and you update the font cache with
sudo fc-cache -fv
the fonts will become available
Thanks Mark,
I will do this later.
take care
Don W
Later
Thanks Mark your suggestions worked a treat. :wink:
When I ran ’ sudo fc-cache -fv’ it took a while to respond, no it didn’t, it responded but it took a while to appear on screen, I thought it had crashed. But all was well it just to a little while to react.
take care
Don W
No problem :slight_smile:
