Installing GIMP On 11.10
I am trying to RE-Install GIMP through the repo after it was removed by a partial upgrade.
I get this;
The following packages have unmet dependencies:
gimp-gmic: Depends: libc6 (>= 2.4) but 2.13-20ubuntu5.3 is to be installed
Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.1-9ubuntu3 is to be installed
Depends: libgdk-pixbuf2.0-0 (>= 2.22.0) but 2.24.0-1ubuntu1 is to be installed
Depends: libgimp2.0 (>= 2.4.0) but 2.6.11-2ubuntu4.2 is to be installed
Depends: libglib2.0-0 (>= 2.24.0) but 2.30.0-0ubuntu4 is to be installed
Depends: libgtk2.0-0 (>= 2.18.0) but 2.24.6-0ubuntu5 is to be installed
Depends: libstdc++6 (>= 4.1.1) but 4.6.1-9ubuntu3 is to be installed
Depends: zlib1g (>= 1:1.1.4) but 1:1.2.3.4.dfsg-3ubuntu3 is to be installed
Depends: gimp (>= 2.6) but 2.6.11-2ubuntu4.2 is to be installed
gimp-gutenprint: gimp-plugin-registry: Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.1-9ubuntu3 is to be installed
Depends: libjpeg62 (>= 6b1) but 6b1-1ubuntu2 is to be installed
Depends: libstdc++6 (>= 4.6) but 4.6.1-9ubuntu3 is to be installed
Any ideas?
What do you mean by a “partial upgrade” ?
Sorry, I can’t give you a screenshot as I didn’t take one.
I don’t need a screenshot … I just need you to TELL me what you mean.
Do you mean a partial OS upgrade to 12.04 ?
No as I dont want to pur 12.04 on the laptop. see other thread on LO
If you ran a partial upgrade, then there’s obviously a dependancy/repo issue somewhere. By reading the output you’ve posted as well, it looks like it needs a lot of liberies/dependancies too which aren’t installed.
You’re still on 11.10 right? You can check by running:
lsb_release -a
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 11.10
Release: 11.10
Codename: oneiric
Have you checked the if Backports are enabled.
There should be a later version of GIMP than 2.6 you got now,with matching dependencies.
Hold on … is this even a GIMP issue ?
It looks to me like it’s a gimp-gmic and gimp-gutenprint issue.
Is GIMP a more recent version being installed from a PPA ? … but gimp-gmic and gimp-gutenprint are the originals ?
Try:
sudo apt-get remove --purge gimp-gmic gimp-gutenprint
sudo apt-get install gimp
Reading package lists… Done
Building dependency tree
gimp : Depends: gimp-data (<= 2.6.11-z) but 2.7.5-2012020902~oo is to be installed
sudo apt-get remove --purge gimp-data
Alternatively … fire up Synaptic and select Edit>Fix Broken Packages
Somewhere you’ve installed gimp (and a load of other stuff) from a PPA that’s no longer available.
Have you got the GetDeb repository added by any chance ?
What’s the contents of:
gedit /etc/apt/sources.list
and the output from:
ls -a /etc/apt/sources.list.d
I run
And it goes through the install of Gimp but when I try and run Gimp, it shows up at the bottom as starting and then just vanishes with no error report.
I don’t think the ‘GetDeb’ repo is on here! not heard of that before…
Can I get it from the Ubuntu Software Centre?
[spoiler]# deb cdrom:[Ubuntu 11.10 Oneiric Ocelot - Release amd64 (20111012)]/ dists/oneiric/main/binary-i386/
deb cdrom:[Ubuntu 11.10 Oneiric Ocelot - Release amd64 (20111012)]/ oneiric main restricted
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu oneiric main restricted
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu oneiric-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu oneiric universe
deb Index of /ubuntu oneiric-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu oneiric multiverse
deb Index of /ubuntu oneiric-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu oneiric-backports main restricted universe multiverse
deb Index of /ubuntu oneiric-security main restricted
deb Index of /ubuntu oneiric-security universe
deb Index of /ubuntu oneiric-security multiverse
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu oneiric partner
deb-src Index of /ubuntu oneiric partner
This software is not part of Ubuntu, but is offered by third-party
developers who want to ship their latest software.
deb-src Index of /ubuntu oneiric main
[/spoiler]
alex-p-notesalexp-precise-oneiric.list
alex-p-notesalexp-precise-oneiric.list.save
banshee-team-ppa-oneiric.list
banshee-team-ppa-oneiric.list.save
fcctt-clt-scribus-oneiric.list
libreoffice-ppa-oneiric.list.save
n-muench-vlc2-oneiric.list
n-muench-vlc2-oneiric.list.save
oneiric-partner.list
oneiric-partner.list.save
openshot_developers-ppa-oneiric.list
openshot_developers-ppa-oneiric.list.save
pmjdebruijn-gimp-release-oneiric.list.save
webupd8team-gnome3-oneiric.list
webupd8team-gnome3-oneiric.list.save
webupd8team-jupiter-oneiric.list
webupd8team-jupiter-oneiric.list.save
webupd8team-shotwell-oneiric.list.save
webupd8team-y-ppa-manager-oneiric.list
webupd8team-y-ppa-manager-oneiric.list.save
Ign http://extras.ubuntu.com oneiric InRelease
Ign http://ppa.launchpad.net oneiric InRelease
Ign http://archive.canonical.com oneiric InRelease
Ign http://security.ubuntu.com oneiric-security InRelease
Ign http://gb.archive.ubuntu.com oneiric InRelease
Ign http://gb.archive.ubuntu.com oneiric-updates InRelease
Ign http://gb.archive.ubuntu.com oneiric-backports InRelease
Get:1 http://security.ubuntu.com oneiric-security Release.gpg [198 B]
Get:2 http://extras.ubuntu.com oneiric Release.gpg [72 B]
Hit http://archive.canonical.com oneiric Release.gpg
Hit http://ppa.launchpad.net oneiric Release.gpg
Hit http://gb.archive.ubuntu.com oneiric Release.gpg
Get:3 http://security.ubuntu.com oneiric-security Release [40.8 kB]
Get:4 http://gb.archive.ubuntu.com oneiric-updates Release.gpg [198 B]
Hit http://extras.ubuntu.com oneiric Release
Hit http://gb.archive.ubuntu.com oneiric-backports Release.gpg
Get:5 http://gb.archive.ubuntu.com oneiric-updates Release [40.8 kB]
Hit http://extras.ubuntu.com oneiric/main Sources
Hit http://archive.canonical.com oneiric/partner amd64 Packages
Get:6 http://security.ubuntu.com oneiric-security/main amd64 Packages [238 kB]
Hit http://gb.archive.ubuntu.com oneiric/main amd64 Packages
Hit http://extras.ubuntu.com oneiric/main amd64 Packages
Hit http://extras.ubuntu.com oneiric/main i386 Packages
Hit http://archive.canonical.com oneiric/partner i386 Packages
Ign http://archive.canonical.com oneiric/partner TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric/universe amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric/main i386 Packages
Hit http://gb.archive.ubuntu.com oneiric/restricted i386 Packages
Hit http://gb.archive.ubuntu.com oneiric/universe i386 Packages
Ign http://extras.ubuntu.com oneiric/main TranslationIndex
Hit http://ppa.launchpad.net oneiric/main Sources
Hit http://gb.archive.ubuntu.com oneiric/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com oneiric/main TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric/restricted TranslationIndex
Hit http://ppa.launchpad.net oneiric/main amd64 Packages
Hit http://ppa.launchpad.net oneiric/main i386 Packages
Ign http://ppa.launchpad.net oneiric/main TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric/universe TranslationIndex
Get:7 http://gb.archive.ubuntu.com oneiric-updates/main amd64 Packages [430 kB]
Get:8 http://security.ubuntu.com oneiric-security/restricted amd64 Packages [3,995 B]
Get:9 http://security.ubuntu.com oneiric-security/universe amd64 Packages [64.8 kB]
Get:10 http://security.ubuntu.com oneiric-security/multiverse amd64 Packages [3,212 B]
Get:11 http://security.ubuntu.com oneiric-security/main i386 Packages [238 kB]
Ign http://archive.canonical.com oneiric/partner Translation-en_GB
Ign http://extras.ubuntu.com oneiric/main Translation-en_GB
Get:12 http://security.ubuntu.com oneiric-security/restricted i386 Packages [4,062 B]
Get:13 http://security.ubuntu.com oneiric-security/universe i386 Packages [64.9 kB]
Get:14 http://security.ubuntu.com oneiric-security/multiverse i386 Packages [3,382 B]
Hit http://security.ubuntu.com oneiric-security/main TranslationIndex
Hit http://security.ubuntu.com oneiric-security/multiverse TranslationIndex
Hit http://security.ubuntu.com oneiric-security/restricted TranslationIndex
Hit http://security.ubuntu.com oneiric-security/universe TranslationIndex
Get:15 http://gb.archive.ubuntu.com oneiric-updates/restricted amd64 Packages [6,651 B]
Get:16 http://gb.archive.ubuntu.com oneiric-updates/universe amd64 Packages [145 kB]
Hit http://security.ubuntu.com oneiric-security/main Translation-en
Hit http://security.ubuntu.com oneiric-security/multiverse Translation-en
Hit http://security.ubuntu.com oneiric-security/restricted Translation-en
Hit http://security.ubuntu.com oneiric-security/universe Translation-en
Get:17 http://gb.archive.ubuntu.com oneiric-updates/multiverse amd64 Packages [6,228 B]
Get:18 http://gb.archive.ubuntu.com oneiric-updates/main i386 Packages [430 kB]
Ign http://ppa.launchpad.net oneiric/main Translation-en_GB
Get:19 http://gb.archive.ubuntu.com oneiric-updates/restricted i386 Packages [6,645 B]
Get:20 http://gb.archive.ubuntu.com oneiric-updates/universe i386 Packages [145 kB]
Get:21 http://gb.archive.ubuntu.com oneiric-updates/multiverse i386 Packages [6,378 B]
Hit http://gb.archive.ubuntu.com oneiric-updates/main TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-updates/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-updates/restricted TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-updates/universe TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-backports/main amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/universe amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/main i386 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/restricted i386 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/universe i386 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com oneiric-backports/main TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-backports/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-backports/restricted TranslationIndex
Hit http://gb.archive.ubuntu.com oneiric-backports/universe TranslationIndex
Get:22 http://gb.archive.ubuntu.com oneiric/main Translation-en_GB [69.0 kB]
Hit http://gb.archive.ubuntu.com oneiric/main Translation-en
Get:23 http://gb.archive.ubuntu.com oneiric/multiverse Translation-en_GB [68.5 kB]
Hit http://gb.archive.ubuntu.com oneiric/multiverse Translation-en
Get:24 http://gb.archive.ubuntu.com oneiric/restricted Translation-en_GB [1,937 B]
Hit http://gb.archive.ubuntu.com oneiric/restricted Translation-en
Get:25 http://gb.archive.ubuntu.com oneiric/universe Translation-en_GB [4,365 B]
Hit http://gb.archive.ubuntu.com oneiric/universe Translation-en
Hit http://gb.archive.ubuntu.com oneiric-updates/main Translation-en
Hit http://gb.archive.ubuntu.com oneiric-updates/multiverse Translation-en
Hit http://gb.archive.ubuntu.com oneiric-updates/restricted Translation-en
Hit http://gb.archive.ubuntu.com oneiric-updates/universe Translation-en
Hit http://gb.archive.ubuntu.com oneiric-backports/main Translation-en
Hit http://gb.archive.ubuntu.com oneiric-backports/multiverse Translation-en
Hit http://gb.archive.ubuntu.com oneiric-backports/restricted Translation-en
Hit http://gb.archive.ubuntu.com oneiric-backports/universe Translation-en
Fetched 2,022 kB in 13s (150 kB/s)
OK, post the output from:
for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; done
[spoiler]
** /etc/apt/sources.list.d/alex-p-notesalexp-precise-oneiric.list:
deb http://ppa.launchpad.net/alex-p/notesalexp-precise/ubuntu oneiric main
deb-src http://ppa.launchpad.net/alex-p/notesalexp-precise/ubuntu oneiric main
** /etc/apt/sources.list.d/alex-p-notesalexp-precise-oneiric.list.save:
** /etc/apt/sources.list.d/banshee-team-ppa-oneiric.list:
deb Index of /banshee-team/ppa/ubuntu oneiric main
deb-src Index of /banshee-team/ppa/ubuntu oneiric main
** /etc/apt/sources.list.d/banshee-team-ppa-oneiric.list.save:
** /etc/apt/sources.list.d/fcctt-clt-scribus-oneiric.list:
deb http://ppa.launchpad.net/fcctt-clt/scribus/ubuntu oneiric main
deb-src http://ppa.launchpad.net/fcctt-clt/scribus/ubuntu oneiric main
** /etc/apt/sources.list.d/libreoffice-ppa-oneiric.list.save:
deb Index of /libreoffice/ppa/ubuntu oneiric main
deb-src Index of /libreoffice/ppa/ubuntu oneiric main
** /etc/apt/sources.list.d/n-muench-vlc2-oneiric.list:
deb Index of /n-muench/vlc2/ubuntu oneiric main
deb-src Index of /n-muench/vlc2/ubuntu oneiric main
** /etc/apt/sources.list.d/n-muench-vlc2-oneiric.list.save:
** /etc/apt/sources.list.d/oneiric-partner.list:
deb Index of /ubuntu oneiric partner #Added by software-center
** /etc/apt/sources.list.d/oneiric-partner.list.save:
** /etc/apt/sources.list.d/openshot_developers-ppa-oneiric.list:
deb Index of /openshot.developers/ppa/ubuntu oneiric main
deb-src Index of /openshot.developers/ppa/ubuntu oneiric main
** /etc/apt/sources.list.d/openshot_developers-ppa-oneiric.list.save:
** /etc/apt/sources.list.d/pmjdebruijn-gimp-release-oneiric.list.save:
deb http://ppa.launchpad.net/pmjdebruijn/gimp-release/ubuntu oneiric main
deb-src http://ppa.launchpad.net/pmjdebruijn/gimp-release/ubuntu oneiric main
** /etc/apt/sources.list.d/webupd8team-gnome3-oneiric.list:
deb Index of /webupd8team/gnome3/ubuntu oneiric main
deb-src Index of /webupd8team/gnome3/ubuntu oneiric main
** /etc/apt/sources.list.d/webupd8team-gnome3-oneiric.list.save:
** /etc/apt/sources.list.d/webupd8team-jupiter-oneiric.list:
deb http://ppa.launchpad.net/webupd8team/jupiter/ubuntu oneiric main
deb-src http://ppa.launchpad.net/webupd8team/jupiter/ubuntu oneiric main
** /etc/apt/sources.list.d/webupd8team-jupiter-oneiric.list.save:
** /etc/apt/sources.list.d/webupd8team-shotwell-oneiric.list.save:
deb http://ppa.launchpad.net/webupd8team/shotwell/ubuntu oneiric main
deb-src http://ppa.launchpad.net/webupd8team/shotwell/ubuntu oneiric main
** /etc/apt/sources.list.d/webupd8team-y-ppa-manager-oneiric.list:
deb Index of /webupd8team/y-ppa-manager/ubuntu oneiric main
deb-src Index of /webupd8team/y-ppa-manager/ubuntu oneiric main
** /etc/apt/sources.list.d/webupd8team-y-ppa-manager-oneiric.list.save:
deb-src Index of /webupd8team/y-ppa-manager/ubuntu oneiric main[/spoiler]
This is a %^*ing mess …
You have PPA’s (granted disabled ones) that contain stuff for the GIMP that’s backported from 12.10 to 12.04 … yet you say you’re on 11.10
You also have PPA’s that are for 12.04
and disabled PPA’s for LibreOffice and GIMP … which probably installed a load of stuff before being disabled.
If you are going to add PPA’s … make sure they are single package PPA’s … and always ppa-purge them before disabling them and installing software that is contained in them from another source.
OK, lets try to sort this mess out.
Fire up Synaptic Package Manager, and go to Settings>Repositories>Other Software (tab)
Make sure these repositories are ticked (don’t change any others, just tick these if they aren’t already)
http://ppa.launchpad.net/pmjdebruijn/gimp-release/ubuntu oneiric main (Source Code)
Once those are enabled, close Synaptic.
Open a terminal and run:
sudo ppa-purge ppa:pmjdebruijn/gimp-release
sudo ppa-purge ppa:alex-p/notesalexp-precise
sudo apt-get remove --purge babl gegl gimp gimp-plugin-registry gmic ufraw libbabl
sudo apt-get autoremove
sudo apt-get clean
Then go back into Synaptic Package Manager, and if not greyed out click Edit>Fix Broken Packages
Close Synaptic again … and back in the terminal run
sudo apt-get install babl gegl gimp gimp-plugin-registry gmic ufraw libbabl
Any errors, post them … no errors, try GIMP.
Can’t find them!!!
Do everything after that bit.
