iPad causing system crash (SOLVED)
There appears to be something very unstable about your system … did you every run a memory test ? … and check the HDD’ss SMART data ?
Doubt if this’ll make a difference, but try turning off IPv6
run:
sudo gedit /etc/sysctl.conf
add these lines at the bottom:
#IPv6 configuration
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
SAVE the file and exit gedit
reload sysctl:
sudo sysctl -p
you can check if IPv6 is disabled with either
ip addr
ifconfig
Thanks again Mark. My hard-drive is fine after SMART, haven’t checked the memory yet.
I edited the sysctl.conf file like you said and plugged-in my iPad. Success! Whether or not it was a fluke or a fix time will tell. I think you’re right though, there’s something not right with my system (curiously, though, it was fine under XP until two weeks ago).
there's something not right with my system (curiously, though, it was fine under XP until two weeks ago).
I would still run memtest (considering you have already discarded one stick) as the remaining memory module could be faulty too.
As for the difference between XP and Linux, I read it somewhere that Linux uses the memory more aggressively (compared to MS) hence the faulty ram will show up more readily.
That’s interesting, SeZo. I ran memtest and my RAM is error-free.
Plugged my iPad in this lunchtime, boom. Knowing that my system will boot with it connected is something I can live with though.
Mark, should I switch IPv6 back on? Is it simply a case of deleting those lines I added to the sysctl.conf file and saving it?
Yeah, just delete those lines, save the file, and run:
sudo sysctl -p
or reboot.
Cheers.
Just a heads-up for anyone experiencing similar issues - it was my RAM. Or, should I say a lack of it. :slight_smile:
Fitted another stick this week and my iPad is playing ball.
Great news … and thanks for the update :slight_smile:
