iPad causing system crash (SOLVED)
Well, one or two here will recall my iPad problems from a few days ago. To refresh, what’s happening is that when I connect my iPad to my Mint 16 (Mate) system, it will occasionally work but more often than not cause an abrupt power-down. Sometimes it will reboot, other times it will require me to switch off my computer power before I can restart it with the power button on the tower.
Anyway, it was starting to cause all sorts of problems with my USB wifi adaptor dongle which led to much frustration. I changed to Ubuntu yesterday and had the same problem, so you’d think it’s hardware related. The funny thing is, though, that I’d been using my iPad before on this same system (on XP) for months without any problem. So, I guess my question is, could there be an issue with how Linux deals with the USB ports? Am I “overloading” it or something?
I’m back on Mint now, as I love the distro but I’m reluctant to try the iPad for obvious reasons. I feel like I’ve been installing/un-installing Linux for a whole week and never really getting to the nub of the problem. The only other case I’ve read about online was someone whose Windows install was doing the same, turned out to be a driver conflict.
Unlikely to be a hardware problem … but could be a driver issue.
What software have you installed for managing the iPad in Linux ?
The libimobiledevice utilities came packaged with Mint 16, been using those.
Next time you plug in the iPad and it crashes, reboot however you need to, then attach the files
/var/log/dmesg.0
to your next reply.
Just as a matter of interest … what happens if you boot with the iPad attached ?
I’m guessing this is something to do with the way libimobiledevice (or fuse) is mounting the iPad.
Does your iPad register as a USB mass storage device, or an MTP device
Ok, I’ll just do that now. Not sure if it’s a USB Mass Storage Device but two dark monitor-style icons appear as mounted items on my desktop and in my “Computer” folder, alongside my drive. One appears to function as a camera would (ie, it asks if I want to import photos from the iPad) and the other functions like a stripped-down iTunes where I have access to files used by selected Apps.
Sounds like it’s mounting as an MTP device.
Would be handy to knw if the system will boot with the iPad already attached
And, just like that (first attempt with today’s fresh Mint 16 install), it works fine. Typical! :o
This has happened before. The first couple of times it’s OK, then problems. When (and, if) it does it again, I’ll post that dmesg file. I’ll also see what happens if I boot with the iPad connected. It’s late, so cheers for now Mark.
Forgot to add, there was no notification of a USB Mass Storage Device having been added.
I’m still convinced it was that stupid UFW thing but I could be proved wrong. This is the first time I haven’t installed it before using my iPad and I’m not going to this time. ;D
When it works without crashing, pst the output from:
mount
and if possible, unplug it … replug it … then send the output from:
dmesg | tail -n 30
Ok, Mark, the iPad mounted fine again this lunchtime. Here are the output messages:
From “mount”
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/pstore type pstore (rw)
/dev/sda5 on /home type ext4 (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=lee)
From “dmesg | tail -n 30”
[   65.210236] agpgart-intel 0000:00:00.0: putting AGP V3 device into 8x mode
[   65.210279] nvidia 0000:01:00.0: putting AGP V3 device into 8x mode
[   65.348868] wlan0: send auth to 5c:35:3b:d1:d0:ff (try 1/3)
[   65.350882] wlan0: authenticated
[   65.356062] wlan0: associate with 5c:35:3b:d1:d0:ff (try 1/3)
[   65.359833] wlan0: RX AssocResp from 5c:35:3b:d1:d0:ff (capab=0x411 status=0 aid=2)
[   65.371041] wlan0: associated
[   65.371103] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[18157.512026] usb 1-7: new high-speed USB device number 7 using ehci-pci
[18157.647931] usb 1-7: New USB device found, idVendor=05ac, idProduct=129a
[18157.647939] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18157.647943] usb 1-7: Product: iPad
[18157.647947] usb 1-7: Manufacturer: Apple Inc.
[18157.647951] usb 1-7: SerialNumber: 9d9a52e50e54fa3e336b992cbddb1a618fe845e6
[18159.018841] ipheth 1-7:4.2: Apple iPhone USB Ethernet device attached
[18159.023866] usbcore: registered new interface driver ipheth
[18159.067342] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[18159.074046] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[18359.193600] usb 1-7: USB disconnect, device number 7
[18359.197427] ipheth 1-7:4.2: ipheth_rcvbulk_callback: urb status: -71
[18359.208436] ipheth 1-7:4.2: Apple iPhone USB Ethernet now disconnected
[18368.444027] usb 1-7: new high-speed USB device number 8 using ehci-pci
[18368.580742] usb 1-7: New USB device found, idVendor=05ac, idProduct=129a
[18368.580750] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18368.580755] usb 1-7: Product: iPad
[18368.580759] usb 1-7: Manufacturer: Apple Inc.
[18368.580763] usb 1-7: SerialNumber: 9d9a52e50e54fa3e336b992cbddb1a618fe845e6
[18368.661309] ipheth 1-7:4.2: Apple iPhone USB Ethernet device attached
[18368.728361] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[18368.730239] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Is everything behaving as it should here?
You get a single USB disconnect on the iPad, but that’s’ not uncommon.
Now it would be handy to see the dmesg.0 log file after a crash for comparison.
Ok, this is new. I normally use a program called gThumb to import my photos from a USB card reader. As of this afternoon, gThumb will no longer import my photos (even though the option dialog box appears as normal). In fact, gThumb won’t start at all. I only mention this as it is USB-related, it might be unrelated to the iPad problem. I’ve removed and purged gThumb from my computer and re-installed it but it is still unresponsive.
what happens if you run gthumb from the command line:
gthumb
Ok, so the inevitable happened and it crashed. Here’s the /var/log/dmesg.0 file:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.11.0-12-generic (buildd@komainu) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu7) ) #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013 (Ubuntu 3.11.0-12.19-generic 3.11.3)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ff3ffff] usable
[    0.000000] BIOS-e820: [mem 0x000000003ff40000-0x000000003ff4ffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000003ff50000-0x000000003fffffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff380000-0x00000000ffffffff] reserved
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI:          P4i65G/P4i65G, BIOS P1.30 09/08/2006
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x3ff40 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-DFFFF uncachable
[    0.000000]   E0000-EFFFF write-through
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FC0000000 write-back
[    0.000000]   1 disabled
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] initial memory mapped: [mem 0x00000000-0x01ffffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] init_memory_mapping: [mem 0x37800000-0x379fffff]
[    0.000000]  [mem 0x37800000-0x379fffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x34000000-0x377fffff]
[    0.000000]  [mem 0x34000000-0x377fffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x33ffffff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x33ffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x37a00000-0x37bfdfff]
[    0.000000]  [mem 0x37a00000-0x37bfdfff] page 4k
[    0.000000] BRK [0x01b39000, 0x01b39fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35000000-0x367f7fff]
[    0.000000] ACPI: RSDP 000fa550 00014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 3ff40000 00030 (v01 A M I  OEMRSDT  09000608 MSFT 00000097)
[    0.000000] ACPI: FACP 3ff40200 00081 (v02 A M I  OEMFACP  09000608 MSFT 00000097)
[    0.000000] ACPI: DSDT 3ff40370 03B3B (v01  P4i6G P4i6G122 00000122 INTL 02002026)
[    0.000000] ACPI: FACS 3ff50000 00040
[    0.000000] ACPI: APIC 3ff40300 0006C (v01 A M I  OEMAPIC  09000608 MSFT 00000097)
[    0.000000] ACPI: OEMB 3ff50040 0003F (v01 A M I  OEMBIOS  09000608 MSFT 00000097)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 131MB HIGHMEM available.
[    0.000000] 891MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 37bfe000
[    0.000000]   low ram: 0 - 37bfe000
[    0.000000] BRK [0x01b3a000, 0x01b3afff] PGTABLE
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00001000-0x00ffffff]
[    0.000000]   Normal   [mem 0x01000000-0x37bfdfff]
[    0.000000]   HighMem  [mem 0x37bfe000-0x3ff3ffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00001000-0x0009efff]
[    0.000000]   node   0: [mem 0x00100000-0x3ff3ffff]
[    0.000000] On node 0 totalpages: 261854
[    0.000000] free_area_init_node: node 0, pgdat c1948bc0, node_mem_map f73fe020
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 1752 pages used for memmap
[    0.000000]   Normal zone: 224254 pages, LIFO batch:31
[    0.000000]   HighMem zone: 263 pages used for memmap
[    0.000000]   HighMem zone: 33602 pages, LIFO batch:7
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[    0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 4 CPUs, 3 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[    0.000000] e820: [mem 0x40000000-0xfedfffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 14 pages/cpu @f73bf000 s36288 r0 d21056 u57344
[    0.000000] pcpu-alloc: s36288 r0 d21056 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260070
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-12-generic root=UUID=a47504c5-62fb-49c8-a934-9ec1763b6c74 ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] allocated 2095608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (00037bfe:0003ff40)
[    0.000000] Memory: 1000008K/1047416K available (6351K kernel code, 607K rwdata, 2640K rodata, 880K init, 908K bss, 47408K reserved, 134408K highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff14000 - 0xfffff000   ( 940 kB)
[    0.000000]     pkmap   : 0xffc00000 - 0xffe00000   (2048 kB)
[    0.000000]     vmalloc : 0xf83fe000 - 0xffbfe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf7bfe000   ( 891 MB)
[    0.000000]       .init : 0xc1962000 - 0xc1a3e000   ( 880 kB)
[    0.000000]       .data : 0xc16341e4 - 0xc1961e00   (3255 kB)
[    0.000000]       .text : 0xc1000000 - 0xc16341e4   (6352 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] NR_IRQS:2304 nr_irqs:712 16
[    0.000000] CPU 0 irqstacks, hard=f6c08000 soft=f6c0a000
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2396.947 MHz processor
[    0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4793.89 BogoMIPS (lpj=9587788)
[    0.004011] pid_max: default: 32768 minimum: 301
[    0.004073] Security Framework initialized
[    0.004114] AppArmor: AppArmor initialized
[    0.004118] Yama: becoming mindful.
[    0.004209] Mount-cache hash table entries: 512
[    0.004604] Initializing cgroup subsys memory
[    0.004628] Initializing cgroup subsys devices
[    0.004634] Initializing cgroup subsys freezer
[    0.004638] Initializing cgroup subsys blkio
[    0.004642] Initializing cgroup subsys perf_event
[    0.004648] Initializing cgroup subsys hugetlb
[    0.004694] CPU0: Hyper-Threading is disabled
[    0.004701] mce: CPU supports 4 MCE banks
[    0.004717] CPU0: Thermal monitoring enabled (TM1)
[    0.004743] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
[    0.004743] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64
[    0.004743] tlb_flushall_shift: 6
[    0.030242] ACPI: Core revision 20130517
[    0.033489] ACPI: All ACPI Tables successfully acquired
[    0.033710] ftrace: allocating 27134 entries in 53 pages
[    0.048217] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.048575] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.090821] smpboot: CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz (fam: 0f, model: 02, stepping: 04)
[    0.092000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[    0.092000] ... version:                0
[    0.092000] ... bit width:              40
[    0.092000] ... generic registers:      18
[    0.092000] ... value mask:             000000ffffffffff
[    0.092000] ... max period:             0000007fffffffff
[    0.092000] ... fixed-purpose events:   0
[    0.092000] ... event mask:             000000000003ffff
[    0.092000] Brought up 1 CPUs
[    0.092000] smpboot: Total of 1 processors activated (4793.89 BogoMIPS)
[    0.092000] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.092000] devtmpfs: initialized
[    0.092246] EVM: security.selinux
[    0.092249] EVM: security.SMACK64
[    0.092252] EVM: security.capability
[    0.092399] PM: Registering ACPI NVS region [mem 0x3ff50000-0x3fffffff] (720896 bytes)
[    0.094519] regulator-dummy: no parameters
[    0.094561] RTC time: 19:37:26, date: 04/17/14
[    0.094645] NET: Registered protocol family 16
[    0.094928] EISA bus registered
[    0.095054] ACPI: bus type PCI registered
[    0.095061] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.095261] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=2
[    0.095264] PCI: Using configuration type 1 for base access
[    0.097534] bio: create slab <bio-0> at 0
[    0.097820] ACPI: Added _OSI(Module Device)
[    0.097825] ACPI: Added _OSI(Processor Device)
[    0.097829] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.097832] ACPI: Added _OSI(Processor Aggregator Device)
[    0.098788] ACPI: EC: Look up EC in DSDT
[    0.100238] ACPI: Executed 1 blocks of module-level executable AML code
[    0.103365] ACPI: Interpreter enabled
[    0.103389] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130517/hwxface-571)
[    0.103397] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20130517/hwxface-571)
[    0.103416] ACPI: (supports S0 S1 S4 S5)
[    0.103420] ACPI: Using IOAPIC for interrupt routing
[    0.103483] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.103610] ACPI: No dock devices found.
[    0.113080] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.113092] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[    0.113098] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[    0.113259] acpi PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.113264] acpi PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.113268] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.113273] acpi PNP0A03:00: host bridge window [mem 0x40000000-0xffefffff] (ignored)
[    0.113277] PCI: root bus 00: using default resources
[    0.113283] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[    0.113423] PCI host bridge to bus 0000:00
[    0.113430] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.113435] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.113439] pci_bus 0000:00: root bus resource [mem 0x00000000-0xfffffffff]
[    0.113463] pci 0000:00:00.0: [8086:2570] type 00 class 0x060000
[    0.113471] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[    0.113485] pci 0000:00:00.0: reg 0x10: [mem 0xf8000000-0xfbffffff pref]
[    0.113645] pci 0000:00:01.0: [8086:2571] type 01 class 0x060400
[    0.113774] pci 0000:00:06.0: [8086:2576] type 00 class 0x088000
[    0.113790] pci 0000:00:06.0: reg 0x10: [mem 0xfecf0000-0xfecf0fff]
[    0.113954] pci 0000:00:1d.0: [8086:24d2] type 00 class 0x0c0300
[    0.114008] pci 0000:00:1d.0: reg 0x20: [io  0xe000-0xe01f]
[    0.114089] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.114148] pci 0000:00:1d.1: [8086:24d4] type 00 class 0x0c0300
[    0.114202] pci 0000:00:1d.1: reg 0x20: [io  0xe400-0xe41f]
[    0.114280] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.114336] pci 0000:00:1d.2: [8086:24d7] type 00 class 0x0c0300
[    0.114389] pci 0000:00:1d.2: reg 0x20: [io  0xe800-0xe81f]
[    0.114470] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.114529] pci 0000:00:1d.3: [8086:24de] type 00 class 0x0c0300
[    0.114582] pci 0000:00:1d.3: reg 0x20: [io  0xec00-0xec1f]
[    0.114659] pci 0000:00:1d.3: System wakeup disabled by ACPI
[    0.114730] pci 0000:00:1d.7: [8086:24dd] type 00 class 0x0c0320
[    0.114758] pci 0000:00:1d.7: reg 0x10: [mem 0xf7fffc00-0xf7ffffff]
[    0.114867] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.114929] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.114997] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[    0.115090] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.115144] pci 0000:00:1f.0: [8086:24d0] type 00 class 0x060100
[    0.115219] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[    0.115232] pci 0000:00:1f.0: address space collision: [io  0x0800-0x087f] conflicts with ACPI CPU throttle [??? 0x00000810-0x00000815 flags 0x80000000]
[    0.115240] pci 0000:00:1f.0: quirk: [io  0x0480-0x04bf] claimed by ICH4 GPIO
[    0.115335] pci 0000:00:1f.1: [8086:24db] type 00 class 0x01018a
[    0.115354] pci 0000:00:1f.1: reg 0x10: [io  0x0000-0x0007]
[    0.115368] pci 0000:00:1f.1: reg 0x14: [io  0x0000-0x0003]
[    0.115381] pci 0000:00:1f.1: reg 0x18: [io  0x0000-0x0007]
[    0.115394] pci 0000:00:1f.1: reg 0x1c: [io  0x0000-0x0003]
[    0.115407] pci 0000:00:1f.1: reg 0x20: [io  0xfc00-0xfc0f]
[    0.115420] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff]
[    0.115530] pci 0000:00:1f.3: [8086:24d3] type 00 class 0x0c0500
[    0.115583] pci 0000:00:1f.3: reg 0x20: [io  0x0400-0x041f]
[    0.115702] pci 0000:00:1f.5: [8086:24d5] type 00 class 0x040100
[    0.115724] pci 0000:00:1f.5: reg 0x10: [io  0xd800-0xd8ff]
[    0.115737] pci 0000:00:1f.5: reg 0x14: [io  0xdc00-0xdc3f]
[    0.115749] pci 0000:00:1f.5: reg 0x18: [mem 0xf7fff800-0xf7fff9ff]
[    0.115761] pci 0000:00:1f.5: reg 0x1c: [mem 0xf7fff400-0xf7fff4ff]
[    0.115817] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[    0.115963] pci 0000:01:00.0: [10de:0221] type 00 class 0x030000
[    0.115984] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[    0.116011] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff pref]
[    0.116023] pci 0000:01:00.0: reg 0x18: [mem 0xf5000000-0xf5ffffff]
[    0.116054] pci 0000:01:00.0: reg 0x30: [mem 0xf7de0000-0xf7dfffff pref]
[    0.116165] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.116174] pci 0000:00:01.0:   bridge window [mem 0xf3d00000-0xf7dfffff]
[    0.116182] pci 0000:00:01.0:   bridge window [mem 0xd3c00000-0xf3bfffff pref]
[    0.116242] pci 0000:02:05.0: [10ec:8139] type 00 class 0x020000
[    0.116265] pci 0000:02:05.0: reg 0x10: [io  0xb800-0xb8ff]
[    0.116278] pci 0000:02:05.0: reg 0x14: [mem 0xf7eefc00-0xf7eefcff]
[    0.116351] pci 0000:02:05.0: supports D1 D2
[    0.116356] pci 0000:02:05.0: PME# supported from D1 D2 D3hot D3cold
[    0.116445] pci 0000:00:1e.0: PCI bridge to [bus 02] (subtractive decode)
[    0.116453] pci 0000:00:1e.0:   bridge window [io  0xb000-0xbfff]
[    0.116461] pci 0000:00:1e.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.116468] pci 0000:00:1e.0:   bridge window [io  0x0000-0xffff] (subtractive decode)
[    0.116472] pci 0000:00:1e.0:   bridge window [mem 0x00000000-0xfffffffff] (subtractive decode)
[    0.116488] pci_bus 0000:00: on NUMA node 0
[    0.117813] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.117928] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[    0.118041] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.118155] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.118268] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.118382] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.118498] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.118612] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.118786] ACPI: \_SB_.PCI0: notify handler is installed
[    0.118833] Found 1 acpi root devices
[    0.119066] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.119070] vgaarb: loaded
[    0.119072] vgaarb: bridge control possible 0000:01:00.0
[    0.119490] SCSI subsystem initialized
[    0.119496] ACPI: bus type ATA registered
[    0.119593] libata version 3.00 loaded.
[    0.119631] ACPI: bus type USB registered
[    0.119675] usbcore: registered new interface driver usbfs
[    0.119694] usbcore: registered new interface driver hub
[    0.119735] usbcore: registered new device driver usb
[    0.119947] PCI: Using ACPI for IRQ routing
[    0.119956] PCI: pci_cache_line_size set to 64 bytes
[    0.120036] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.120042] e820: reserve RAM buffer [mem 0x3ff40000-0x3fffffff]
[    0.120229] NetLabel: Initializing
[    0.120233] NetLabel:  domain hash size = 128
[    0.120236] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.120255] NetLabel:  unlabeled traffic allowed by default
[    0.120562] hpet clockevent registered
[    0.120568] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.120575] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.120583] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    0.122681] Switched to clocksource hpet
[    0.132478] AppArmor: AppArmor Filesystem Enabled
[    0.132558] pnp: PnP ACPI init
[    0.132587] ACPI: bus type PNP registered
[    0.132701] pnp 00:00: [dma 4]
[    0.132748] pnp 00:00: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.132822] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.132867] pnp 00:02: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.132920] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.133545] pnp 00:04: [dma 2]
[    0.133636] pnp 00:04: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.134337] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.134344] system 00:05: [io  0x0800-0x087f] could not be reserved
[    0.134350] system 00:05: [io  0x0480-0x04bf] has been reserved
[    0.134357] system 00:05: [mem 0xfed20000-0xfed8ffff] has been reserved
[    0.134362] system 00:05: [mem 0xff380000-0xffefffff] has been reserved
[    0.134368] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.134500] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.134506] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.134513] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.134927] pnp 00:07: [dma 0 disabled]
[    0.135042] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.135193] system 00:08: [io  0x0680-0x06ff] has been reserved
[    0.135199] system 00:08: [io  0x0295-0x0296] has been reserved
[    0.135206] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.136259] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.136265] system 00:09: [mem 0x000c0000-0x000dffff] could not be reserved
[    0.136272] system 00:09: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.136277] system 00:09: [mem 0x00100000-0x3fffffff] could not be reserved
[    0.136282] system 00:09: [mem 0xfff00000-0xffffffff] has been reserved
[    0.136288] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.136572] pnp: PnP ACPI: found 10 devices
[    0.136576] ACPI: bus type PNP unregistered
[    0.136582] PnPBIOS: Disabled by ACPI PNP
[    0.173911] pci 0000:00:1f.0: BAR 13: [io  0x0800-0x087f] has bogus alignment
[    0.173927] pci 0000:00:1f.1: BAR 5: assigned [mem 0x40000000-0x400003ff]
[    0.173939] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.173947] pci 0000:00:01.0:   bridge window [mem 0xf3d00000-0xf7dfffff]
[    0.173954] pci 0000:00:01.0:   bridge window [mem 0xd3c00000-0xf3bfffff pref]
[    0.173962] pci 0000:00:1e.0: PCI bridge to [bus 02]
[    0.173968] pci 0000:00:1e.0:   bridge window [io  0xb000-0xbfff]
[    0.173976] pci 0000:00:1e.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.174003] pci 0000:00:1e.0: setting latency timer to 64
[    0.174010] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    0.174014] pci_bus 0000:00: resource 5 [mem 0x00000000-0xfffffffff]
[    0.174019] pci_bus 0000:01: resource 1 [mem 0xf3d00000-0xf7dfffff]
[    0.174024] pci_bus 0000:01: resource 2 [mem 0xd3c00000-0xf3bfffff pref]
[    0.174029] pci_bus 0000:02: resource 0 [io  0xb000-0xbfff]
[    0.174033] pci_bus 0000:02: resource 1 [mem 0xf7e00000-0xf7efffff]
[    0.174037] pci_bus 0000:02: resource 4 [io  0x0000-0xffff]
[    0.174042] pci_bus 0000:02: resource 5 [mem 0x00000000-0xfffffffff]
[    0.174113] NET: Registered protocol family 2
[    0.174389] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.174449] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.174494] TCP: Hash tables configured (established 8192 bind 8192)
[    0.174568] TCP: reno registered
[    0.174575] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.174589] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.174706] NET: Registered protocol family 1
[    0.175524] pci 0000:01:00.0: Boot video device
[    0.175534] PCI: CLS 0 bytes, default 64
[    0.175633] Trying to unpack rootfs image as initramfs...
[    0.980966] Freeing initrd memory: 24544K (f5000000 - f67f8000)
[    0.981253] Scanning for low memory corruption every 60 seconds
[    0.981694] Initialise module verification
[    0.981782] audit: initializing netlink socket (disabled)
[    0.981810] type=2000 audit(1397763446.980:1): initialized
[    1.011989] bounce pool size: 64 pages
[    1.012050] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.014163] zbud: loaded
[    1.014309] VFS: Disk quotas dquot_6.5.2
[    1.014397] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.015301] fuse init (API version 7.22)
[    1.015442] msgmni has been set to 1738
[    1.016105] Key type asymmetric registered
[    1.016111] Asymmetric key parser 'x509' registered
[    1.016184] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.016238] io scheduler noop registered
[    1.016242] io scheduler deadline registered (default)
[    1.016298] io scheduler cfq registered
[    1.016504] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.016538] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.016784] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    1.016796] ACPI: Power Button [PWRB]
[    1.016864] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    1.016870] ACPI: Power Button [PWRF]
[    1.017013] GHES: HEST is not enabled!
[    1.017205] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.037678] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.037755] isapnp: Scanning for PnP cards...
[    1.088969] Linux agpgart interface v0.103
[    1.089078] agpgart-intel 0000:00:00.0: Intel 865 Chipset
[    1.092694] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[    1.094988] brd: module loaded
[    1.096252] loop: module loaded
[    1.096493] ata_piix 0000:00:1f.1: version 2.13
[    1.096692] ata_piix 0000:00:1f.1: setting latency timer to 64
[    1.097186] scsi0 : ata_piix
[    1.098058] scsi1 : ata_piix
[    1.098941] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[    1.098945] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[    1.099512] libphy: Fixed MDIO Bus: probed
[    1.099694] tun: Universal TUN/TAP device driver, 1.6
[    1.099698] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.099805] PPP generic driver version 2.4.2
[    1.099883] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.099887] ehci-pci: EHCI PCI platform driver
[    1.100080] ehci-pci 0000:00:1d.7: setting latency timer to 64
[    1.100095] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    1.100107] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.100130] ehci-pci 0000:00:1d.7: debug port 1
[    1.104057] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    1.104409] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf7fffc00
[    1.148019] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.148081] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.148086] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.148090] usb usb1: Product: EHCI Host Controller
[    1.148094] usb usb1: Manufacturer: Linux 3.11.0-12-generic ehci_hcd
[    1.148098] usb usb1: SerialNumber: 0000:00:1d.7
[    1.148295] hub 1-0:1.0: USB hub found
[    1.148304] hub 1-0:1.0: 8 ports detected
[    1.148570] ehci-platform: EHCI generic platform driver
[    1.148593] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.148596] ohci-platform: OHCI generic platform driver
[    1.148614] uhci_hcd: USB Universal Host Controller Interface driver
[    1.148748] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    1.148754] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.148764] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.148811] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000e000
[    1.148864] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.148869] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.148873] usb usb2: Product: UHCI Host Controller
[    1.148877] usb usb2: Manufacturer: Linux 3.11.0-12-generic uhci_hcd
[    1.148880] usb usb2: SerialNumber: 0000:00:1d.0
[    1.149075] hub 2-0:1.0: USB hub found
[    1.149084] hub 2-0:1.0: 2 ports detected
[    1.149288] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    1.149294] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.149304] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.149347] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e400
[    1.149398] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.149403] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.149407] usb usb3: Product: UHCI Host Controller
[    1.149411] usb usb3: Manufacturer: Linux 3.11.0-12-generic uhci_hcd
[    1.149414] usb usb3: SerialNumber: 0000:00:1d.1
[    1.149574] hub 3-0:1.0: USB hub found
[    1.149582] hub 3-0:1.0: 2 ports detected
[    1.149773] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    1.149780] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.149793] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.149836] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e800
[    1.149890] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.149894] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.149898] usb usb4: Product: UHCI Host Controller
[    1.149902] usb usb4: Manufacturer: Linux 3.11.0-12-generic uhci_hcd
[    1.149906] usb usb4: SerialNumber: 0000:00:1d.2
[    1.150062] hub 4-0:1.0: USB hub found
[    1.150071] hub 4-0:1.0: 2 ports detected
[    1.150264] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[    1.150270] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[    1.150280] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[    1.150309] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000ec00
[    1.150360] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.150365] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.150369] usb usb5: Product: UHCI Host Controller
[    1.150373] usb usb5: Manufacturer: Linux 3.11.0-12-generic uhci_hcd
[    1.150376] usb usb5: SerialNumber: 0000:00:1d.3
[    1.150529] hub 5-0:1.0: USB hub found
[    1.150538] hub 5-0:1.0: 2 ports detected
[    1.150778] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.328806] ata1.00: ATA-6: ST3160022ACE, 9.51, max UDMA/100
[    1.328812] ata1.00: 312581808 sectors, multi 16: LBA48
[    1.329323] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.329332] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.329482] mousedev: PS/2 mouse device common for all mice
[    1.329668] rtc_cmos 00:01: RTC can wake from S4
[    1.329816] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.329847] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    1.329970] device-mapper: uevent: version 1.0.3
[    1.330086] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com
[    1.330129] platform eisa.0: Probing EISA bus 0
[    1.330164] platform eisa.0: EISA: Detected 0 cards
[    1.330181] cpufreq-nforce2: No nForce2 chipset.
[    1.330187] cpuidle: using governor ladder
[    1.330191] cpuidle: using governor menu
[    1.330214] ledtrig-cpu: registered to indicate activity on CPUs
[    1.330383] TCP: cubic registered
[    1.330550] NET: Registered protocol family 10
[    1.330875] NET: Registered protocol family 17
[    1.330896] Key type dns_resolver registered
[    1.331407] ata2.00: ATAPI: LITEON  DVD-ROM LTD163, GIH3, max UDMA/33
[    1.331425] ata2.01: ATAPI: CW088D ATAPI CD-R/RW, V110F, max UDMA/33
[    1.331737] Using IPI No-Shortcut mode
[    1.331888] PM: Hibernation image not present or could not be loaded.
[    1.331898] Loading module verification certificates
[    1.339525] MODSIGN: Loaded cert 'Magrathea: Glacier signing key: 4b7c2664fb134f99aaf5e09f5b6d30d43b5eac95'
[    1.339550] registered taskstats version 1
[    1.427266] isapnp: No Plug & Play device found
[    1.431742] Key type trusted registered
[    1.436159] Key type encrypted registered
[    1.440732] AppArmor: AppArmor sha1 policy hashing enabled
[    1.441086]   Magic number: 10:860:647
[    1.441112] scsi_host host1: hash matches
[    1.441117] scsi host1: hash matches
[    1.441197] acpi LNXCPU:00: hash matches
[    1.441237] rtc_cmos 00:01: setting system clock to 2014-04-17 19:37:27 UTC (1397763447)
[    1.441349] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.441352] EDD information not available.
[    1.441650] ata2.00: configured for UDMA/33
[    1.442138] ata1.00: configured for UDMA/100
[    1.442339] scsi 0:0:0:0: Direct-Access     ATA      ST3160022ACE     9.51 PQ: 0 ANSI: 5
[    1.442608] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.442740] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[    1.442840] sd 0:0:0:0: [sda] Write Protect is off
[    1.442845] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.442889] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.448250] ata2.01: configured for UDMA/33
[    1.450019] scsi 1:0:0:0: CD-ROM            LITEON   DVD-ROM LTD163   GIH3 PQ: 0 ANSI: 5
[    1.450899] sr0: scsi3-mmc drive: 0x/48x cd/rw xa/form2 cdda tray
[    1.450904] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.451074] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.451168] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    1.452136] scsi 1:0:1:0: CD-ROM            CyberDrv CW088D CD-R/RW   110F PQ: 0 ANSI: 5
[    1.453383] sr1: scsi3-mmc drive: 4x/48x writer cd/rw xa/form2 cdda tray
[    1.453551] sr 1:0:1:0: Attached scsi CD-ROM sr1
[    1.453729] sr 1:0:1:0: Attached scsi generic sg2 type 5
[    1.511176]  sda: sda1 sda2 < sda5 sda6 >
[    1.511789] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.512961] Freeing unused kernel memory: 880K (c1962000 - c1a3e000)
[    1.513030] Write protecting the kernel text: 6356k
[    1.513160] Write protecting the kernel read-only data: 2644k
[    1.548476] systemd-udevd[97]: starting version 204
[    1.552082] usb 1-2: new high-speed USB device number 2 using ehci-pci
[    1.607541] floppy: module verification failed: signature and/or required key missing - tainting kernel
[    1.610652] Floppy drive(s): fd0 is 1.44M
[    1.627914] FDC 0 is a post-1991 82077
[    1.630541] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[    1.630580] 8139cp 0000:02:05.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[    1.631433] 8139too: 8139too Fast Ethernet driver 0.9.28
[    1.641489] 8139too 0000:02:05.0 eth0: RealTek RTL8139 at 0x0001b800, 00:13:8f:f4:ed:02, IRQ 22
[    1.700516] usb 1-2: New USB device found, idVendor=148f, idProduct=5572
[    1.700524] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.700529] usb 1-2: Product: 802.11 n WLAN
[    1.700533] usb 1-2: Manufacturer: Ralink
[    1.700537] usb 1-2: SerialNumber: 1.0
[    1.980083] tsc: Refined TSC clocksource calibration: 2396.863 MHz
[    2.364037] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[    2.546942] usb 3-1: New USB device found, idVendor=045e, idProduct=0027
[    2.546950] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.546954] usb 3-1: Product: Microsoft\xffffffc2\xffffffae SideWinder\xffffffc2\xffffffae Plug & Play Game Pad
[    2.546958] usb 3-1: Manufacturer: Microsoft\xffffffc2\xffffffae
[    2.573206] hidraw: raw HID events driver (C) Jiri Kosina
[    2.603410] usbcore: registered new interface driver usbhid
[    2.603417] usbhid: USB HID core driver
[    2.618012] input: Microsoft\xffffffc2\xffffffae Microsoft\xffffffc2\xffffffae SideWinder\xffffffc2\xffffffae Plug & Play Game Pad as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input2
[    2.619063] hid-generic 0003:045E:0027.0001: input,hidraw0: USB HID v1.00 Gamepad [Microsoft\xffffffc2\xffffffae Microsoft\xffffffc2\xffffffae SideWinder\xffffffc2\xffffffae Plug & Play Game Pad] on usb-0000:00:1d.1-1/input0
[    2.660039] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[    2.840935] usb 4-1: New USB device found, idVendor=045e, idProduct=00cb
[    2.840943] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.840948] usb 4-1: Product: Microsoft Basic Optical Mouse v2.0
[    2.840952] usb 4-1: Manufacturer: Microsoft
[    2.868905] input: Microsoft  Microsoft Basic Optical Mouse v2.0  as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input3
[    2.869134] hid-generic 0003:045E:00CB.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft  Microsoft Basic Optical Mouse v2.0 ] on usb-0000:00:1d.2-1/input0
[    2.980073] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[    2.980160] Switched to clocksource tsc
[    3.158873] usb 4-2: New USB device found, idVendor=045e, idProduct=0750
[    3.158881] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.158886] usb 4-2: Product: Wired Keyboard 600
[    3.158890] usb 4-2: Manufacturer: Microsoft
[    3.177799] input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.0/input/input4
[    3.177978] hid-generic 0003:045E:0750.0003: input,hidraw2: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-0000:00:1d.2-2/input0
[    3.209203] input: Microsoft Wired Keyboard 600 as /devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.1/input/input5
[    3.209485] hid-generic 0003:045E:0750.0004: input,hidraw3: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-0000:00:1d.2-2/input1
[   13.291298] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[   13.291306] vesafb: scrolling: redraw
[   13.291311] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[   13.291940] vesafb: framebuffer at 0xe0000000, mapped to 0xf8500000, using 3072k, total 3072k
[   13.293395] Console: switching to colour frame buffer device 128x48
[   13.327066] fb0: VESA VGA frame buffer device
[   14.378511] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   33.385585] Adding 3944444k swap on /dev/sda6.  Priority:-1 extents:1 across:3944444k FS
[   33.704913] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   33.953219] systemd-udevd[344]: starting version 204
[   34.430578] lp: driver loaded but no devices found
[   34.696333] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   34.822689] intel_rng: FWH not detected
[   34.956497] nvidia: module license 'NVIDIA' taints kernel.
[   34.956505] Disabling lock debugging due to kernel taint
[   34.982919] device-mapper: multipath: version 1.5.1 loaded
[   35.297062] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   35.301588] NVRM: loading NVIDIA UNIX x86 Kernel Module  173.14.37  Wed Mar  6 16:56:05 PST 2013
[   35.463076] microcode: CPU0 sig=0xf24, pf=0x4, revision=0x1e
[   35.616442] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[   35.940279] intel8x0_measure_ac97_clock: measured 55499 usecs (2674 samples)
[   35.940286] intel8x0: clocking to 48000
[   36.581064] cfg80211: Calling CRDA to update world regulatory domain
[   36.848471] usb 1-2: reset high-speed USB device number 2 using ehci-pci
[   36.989100] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 detected
[   37.017343] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 000f detected
[   37.027367] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   37.027978] usbcore: registered new interface driver rt2800usb
[   39.117324] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   40.421504] cfg80211: World regulatory domain updated:
[   40.421514] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   40.421518] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   40.421522] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   40.421525] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   40.421529] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   40.421532] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   44.884137] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   46.543600] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[   48.327596] init: failsafe main process (625) killed by TERM signal
[   49.788383] Bluetooth: Core ver 2.16
[   49.788520] NET: Registered protocol family 31
[   49.788524] Bluetooth: HCI device and connection manager initialized
[   49.790441] Bluetooth: HCI socket layer initialized
[   49.790452] Bluetooth: L2CAP socket layer initialized
[   49.790476] Bluetooth: SCO socket layer initialized
[   49.813880] Bluetooth: RFCOMM TTY layer initialized
[   49.813907] Bluetooth: RFCOMM socket layer initialized
[   49.813910] Bluetooth: RFCOMM ver 1.11
[   50.105429] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   50.105437] Bluetooth: BNEP filters: protocol multicast
[   50.105457] Bluetooth: BNEP socket layer initialized
[   50.992069] usb 4-1: USB disconnect, device number 2
[   51.984239] init: avahi-cups-reload main process (706) terminated with status 1
[   52.193674] ppdev: user-space parallel port driver
[   52.600036] usb 4-1: new low-speed USB device number 4 using uhci_hcd
[   52.780599] usb 4-1: New USB device found, idVendor=045e, idProduct=00cb
[   52.780607] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   52.780612] usb 4-1: Product: Microsoft Basic Optical Mouse v2.0
[   52.780616] usb 4-1: Manufacturer: Microsoft
[   52.808587] input: Microsoft  Microsoft Basic Optical Mouse v2.0  as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input6
[   52.809292] hid-generic 0003:045E:00CB.0005: input,hidraw1: USB HID v1.11 Mouse [Microsoft  Microsoft Basic Optical Mouse v2.0 ] on usb-0000:00:1d.2-1/input0
[   56.903359] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[   57.007309] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[   57.331627] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   57.333279] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   57.347207] 8139too 0000:02:05.0 eth0: link down
[   57.347352] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   57.348600] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mint booted fine with the iPad plugged-in and mounted on the desktop.
Ok, gThumb started but I couldn’t click any of the menus etc (gThumb is also the program which, by default, asks to import files from my iPad when it mounts).
Here’s the “mount” output after booting with the iPad attached, in case it’s any use:
Will gthumb start cleanly if the iPad is NOT attached ?
gThumb won’t start at all now, even from the terminal.
There may not be a link but I installed RawStudio yesterday (since removed), which performed a similar task to gThumb (but for RAW files rather than JPGs). gThumb still pops-up as the default photo importer in the dialog box, though, when I plug-in my USB card reader (even though it won’t start).
Ok, gThumb working properly today. Curious.
