good day dear community,
update issues - Update-Problems -
i have tried to update the mx-linux system for various times.
the Update could not get fetched
full actualization
reading the lits...
libokular5core8 (4:17.12.2-2.2+deb10u1)
Verwenden Sie »apt autoremove«, um es zu entfernen.
Die folgenden Pakete werden aktualisiert (Upgrade):
bluetooth (5.50-1.2~deb10u1 => 5.50-1.2~deb10u2)
bluez (5.50-1.2~deb10u1 => 5.50-1.2~deb10u2)
bluez-cups (5.50-1.2~deb10u1 => 5.50-1.2~deb10u2)
bluez-obexd (5.50-1.2~deb10u1 => 5.50-1.2~deb10u2)
firefox (90.0.2~mozillabinaries-1mx19+1 => 91.0~mozillabinaries-1mx19+1)
gazelle-installer-data-mx (21.01.02mx19 => 21.07.01mx19)
libbluetooth3 (5.50-1.2~deb10u1 => 5.50-1.2~deb10u2)
libexiv2-14 (0.25-4+deb10u1 => 0.25-4+deb10u2)
linux-kbuild-5.10 (5.10.46-3~mx19+1 => 5.10.46-4~mx19+1)
linux-libc-dev (5.10.46-3~mx19+1 => 5.10.46-4~mx19+1)
lo-main-helper (21.08.2mx19 => 21.08.3mx19)
mx-installer (21.7.05mx19 => 21.8.08mx19)
mx-packageinstaller (21.7.02 => 21.8)
mx-packageinstaller-pkglist (21.08.2mx19 => 21.08.3mx19)
vivaldi-stable (4.1.2369.11-1 => 4.1.2369.18-1)
15 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
we want to fetch 85,1 MB von 152 MB an
after the Operation more than 3.848 kB will get used .
do you want to continue [J/n]
Fehl:1 http://repo.vivaldi.com/stable/deb stable/main amd64 vivaldi-stable amd64 4.1.2369.18-1
404 Not Found [IP: 23.111.9.47 80]
E:issues with http://repo.vivaldi.com/stable/deb/pool/main/vivaldi-stable_4.1.2369.18-1_amd64.deb 404 Not Found [IP: 23.111.9.47 80]
E:the sources could not get fetched - try it with »apt-get update« »--fix-missing« probieren?
well i guess that the sources are quite outdated: 4.1.2369.18-1 - there is much time between 5.0.2497.24-1.
well i guess that i have to read the packages again - what do you say!?
well - i try out to achive this with this
sudo apt update
what do you say!?
look forward to hear from you
