If you own DVDs that are bought in stores and you are not reselling them, and require them to be copied just in case your original DVD
s become of no use, apart from being used as coasters, then what`s the answer?
I used to use K9Copy until it was no longer maintained. There was rumours of someone else taking it over, but that seems like a long time ago. Pauline Martin restarted the development, but only as tarballs. Quite tricky for someone with my capabilities, then I came across this >
http://tomtomtom.org/k9copy-reloaded/en.html
Nice & easy .deb files to download. Works a treat on my Mint 17, thanks to tom 8).
Please remember that it`s use is only for personal use not for profit or gain.
