OK, dya wanna try Libreoffice 4 again, or openoffice ?
Maybe you can give me all the instructions, and expected output, and I’ll yell if I have any problems.
Did they change anything from 1 month ago? Yes they changed the depository I first used and apparently second isn’t complete. Unless you know another.
Lets try Open Office.
OK, what happens if you run:
sudo apt-get install openoffice.org-writer
I have no repositories for it now, but I think I did before.
Eh … openoffice-writer should be in the default 10.04 repo
IS it in Synaptic ? … if so install it … not the whole openoffice, just writer
This is what happened before we did all this cleaning: Are we in a new world now?
---- Removed libre-writer. Tried installing openoffice.org-writer, got this:
Oh, gotta add that PPA- that gets purged too?
root@mak4-laptop:/home/mako4# apt-get install openoffice.org-writer
Reading package lists… Done
Building dependency tree
The following packages have unmet dependencies:
openoffice.org-writer: Depends: openoffice.org-core (= 1:3.2.0-7ubuntu4.4) but it is not going to be installed
Depends: openoffice.org-base-core (= 1:3.2.0-7ubuntu4.4) but it is not going to be installed
Recommends: openoffice.org-emailmerge but it is not going to be installed
Recommends: openoffice.org-math but it is not going to be installed
E: Broken packages
OK, run:
sudo apt-get install openoffice.org-core openoffice.org-base-core openoffice.org-emailmerge openoffice.org-math openoffice.org-writer
Any errors ?
[edit]
Theres’ a PPA with LibreOffice 3.5.7 for 10.04 if you’d prefer to try that ?
Checked Open Office writer and got same:
unresolved dependencies (make sure needed repositories are added and enabled ):
Depends: openoffice.org-core but it is not going to be installed
Depends: openoffice.org-base-core but it is not going to be installed
See above
If it could install the OOo core, etc… it would have, n’est pas? So it needs another repository for OOo. I think.
Sure whats the ppa for 3.6 Libre, though I looked at it and seemed to have a bunch of bugs, probably less than what I had since it MADE to work with 10.4
Have you tried the command ?
No, I’d rather try Libre 3.57
OK, fire up synaptic, and remove the repositories for libreoffice-4
then send the output from:
for APT in `find /etc/apt/ -name *.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
done
ppa:transmissionbt/ppa
ppa:tualatrix/ppa
ppa:anonbeat/guayadeque
run:
sudo add-apt-repository ppa:libreoffice/libreoffice-3-5
sudo apt-get install libreoffice-writer
DOne- haven’t run it yet.
Got a few warnings. Are these crucial?:
/var/lib/dpkg/tmp.ci/preinst: 80: dpkg-maintscript-helper: not found
Selecting previously deselected package libreoffice-core.
Unpacking libreoffice-core (from …/libreoffice-core_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) …
rmdir: failed to remove /var/lib/libreoffice/basis3.4/program/': No such file or directory rmdir: failed to remove
/var/lib/libreoffice/basis3.4’: No such file or directory
Selecting previously deselected package libreoffice-base-core.
Unpacking libreoffice-base-core (from …/libreoffice-base-core_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) …
Selecting previously deselected package python-uno.
Unpacking python-uno (from …/python-uno_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) …
Seems OK. Thanks very much. Is the program updatable from inside it?
Is there a way to save the packages, so one doesn’t have to download them again from places that don’t have them? Like I could have done with the original or the OOo
Not as far as I know no
Is there a way to save the packages, so one doesn't have to download them again from places that don't have them? Like I could have done with the original or the OOo
Erm, yes, but you’d have to make sure you downloaded all the dependencies too (if any), and installing them may not be too easy
Theoretically you could clone the PPA, but my advice would be to switch to at least 12.04 or if you don’t like Unity, Mint or Peppermint as soon as possible … up to date software is going to get harder and harder to find for 10.04, and you’re no longer receiving security updates.
OK. Where are they- are they downloaded to one place? Figure if you just dump them back in that place, it will see them on subsequennt installation, not download them over, and also get any dependencies needed. Cause I want the space.
