I would like to install lightburn on my linux computer, it comes with the following info.
Linux Installation
- Open a terminal and run the following command:
sudo adduser $USER dialout && sudo adduser $USER tty - IMPORTANT! Log out and log back in (this refreshes the permissions we just added)
- Download the Linux 64-bit version
- Extract the folder wherever you want Lightburn to exist
- Double click AppRun inside your Lightburn folder
Is this ok to install ?? I don’t like to install anything and then come back here to get un-install advice when it doesn’t work, or should I just try and see what happens ??
Don W
