After I dumped a long message on my Gnome sticky note that I’ve had for maybe a year or 2, I got a message saying it crashed and did I want to restart. DIdin’t since figured it’ll just come up when rebooted. But Ubuntu apparently uninstalls programs that crashed badly, and that’s what seems to have happened. Doesn’t show it installed on Synaptic or Ubuntu Software. Had Opera mysteriously uninstall too, though might have deleted PPA with Tweak. But I had a ton of info and links on that stickynote that I really want to get back. In the list of files related to sticky note, can’t find executable, and only new one from 2013 is:
$ dpkg | grep screenlet
dpkg: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use dselect' or aptitude’ for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating .deb files;
Type dpkg --license for copyright license and lack of warranty (GNU GPL) [].
Options marked [*] produce a lot of output - pipe it through less' or more’ !
I don’t usually open it- it is sticky- always on right side of screen to copy Urls, phrases etc for last 2 years. Wnen you you tried to close all windows, it would warn- if you close this, you will erase it (slightly tragic). But I think in accessories. Also had installed Tomboy Note, but isn’t persistent, and they say that sucks alot of resources, so haven 't used it. Does Gnome do any automatic backup somewhere?
Not exactly, but Notes is. Small yellow thing, not what I had. What I was most concerned with was getting back the info in it- can always reinstall some sticky note.
I was asking where that info (my info) might still be? Do these sticky things make a backup? According to the boards, screenlets are very heavy on resources, and it looks like I got 30-45meg of screenlet Python resource use now without anything installed. Was just looking for simple light auto-opening note that’s always there for copying anything. Actually really would like to hold 10 copy-paste items simultaneously.
Yes, it doesn’t work at all, doesn’t show up in applications- I found a few files, but the only new file “sticky note” (2013) I listed the contents of in the first post (presumably updated contents would be new). All others are from 2010-2012 . I think it was called Gnome Stickynote or Note, sorry- since it doesn’t show up anywhere (like Synaptic or Software), I don’t know, but it was a light simple always present note that I used to store alot.
So what was it called ? … you’re not giving me any clues that will steer me to the specific application, and without knowing that I can’t find out where it stores the notes.
According to this page it looks like it is part of the gnome-applets package.
To re-install (but I would try to re add it to the panel first):
sudo apt-get install gnome-applets
Then to add to the panel, right click on the place you want the Sticky notes applet to appear, select Add to panel…, Sticky notes.
It will appear as a yellow icon that looks like a block of post-it notes.
